Breaker bar at the ready....
Discussion in 'UK Motorcycles' started by Nige, Feb 28, 2010.
  1. Nige
    Gyp Guest
    Can someone explain in simple terms why a split link is less robust than
    a rivitted link?
    Gyp, Mar 1, 2010
  2. Nige
    You get endless chains on the average pushbike nowadays.
    platypus, Mar 1, 2010
  3. Nige
    Pete Fisher Guest
    No. If each is fitted correctly there should probably be no issue with
    either. I'm guessing that it may be possible to put on the spring clip
    in such a way that it seems secure, but it isn't IYSWIM. Having never
    riveted a chain myself I can't comment on whether that scenario is
    equally likely. Though I suspect, without any real foundation, that the
    'loose' side plate on a riveted link is a tighter fit (hence the need
    for a tool or clamps etc.), and so play is less likely to develop.
    All I can say, is that going back to the pre o-ring chain days of 5/8 x
    3/8, the only time I had chains fail it was the split link. I've also
    found split links with very wobbly pins when doing sprocket changes and
    replaced them.
    | Pete Fisher at Home: |
    Pete Fisher, Mar 1, 2010
  4. Nige
    zymurgy Guest
    <fx: awaits 'I Lost my leg in freak chain accident' post > ;)
    Paul.
    zymurgy, Mar 1, 2010
  5. They really needed 'em, yes. My old CB750F1 was the last model Honda
    made with the old weedy chain - the K7 and the F2 got the beefed-up
    endless chains. A chain would last 5000 miles, tops, on my F1, and need
    adjustment every 300-400 miles.
    When they put big beefy chains on the bikes, they made the move to
    endless at the same time.
    The Older Gentleman, Mar 1, 2010
  6. On modern chains, they aren't, really. The sideplatesof the split link
    goes onto tapered pins - you really have to force the plate on. The clip
    is really belt & braces stuff.
    There's no lateral force on the sideplate, so little chance of knocking
    off the clip.
  7. Nige
    Nige Guest
    I was surprised how hard it was to get the fucking thing on!
    Round 2 about to commence, with beer.
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Mar 1, 2010
  8. Nige
    Pete Fisher Guest
    In communiqué <1jeow1w.tflenc1jhm4dgN%>,
    It wasn't on the one I've just fitted. Just normal thumb pressure
    required to put the plate on. It was bright yellow, which makes it easy
    to find when in a hurry in the paddock. Yes, I know, buy less pikey
    chain. The clip was much higher tech than they used to be though.
    Assuming the alignment is spot on perhaps? I suspect that when I was a
    callow youth on a Matchless G2 that wasn't always the case. The
    home-brewed Rotarini was not utterly perfect in that department, it has
    to be said.
  9. Nige
    Nige Guest
    Great tool, had it nailed in 5 minutes :)
    Nige,
    Land Rover 90
    Yamaha R1
    Range Rover Vogue
    Nige, Mar 1, 2010
  10. Nige
    Seriously Pete, it's a piece of piss to do it properly with a ball-pein
    hammer and a solid lump of steel behind the link. I use a panelbeaters
    dolly as the aforementioned solid lump of steel and it does the job
    fine.
    Lozzo, Mar 1, 2010
  11. Nige
    You won't get a racebike past scrutineering with a split link fitted if
    you're entering a tarmac event. I've only once used one on a carebike,
    and I siliconed the splitlink over to ensure it stayed put and put it
    on the wrong side of the chain so the scrutes didn't see it. That was
    on that piece of shit RGV250 Danny was meant to be racing - tbh the
    chance of the chain throwing itself off was the least of our concerns
    with that sack of crap.
    Lozzo, Mar 1, 2010
  12. Nige
    Pete Fisher Guest
    That's easy for you to say. I'd have to put my reading specs on for a
    start or I'd probably peen my pinkie[1].
    OK, I might have a go if it ever needs just a new chain, but I'd be
    tempted to get a chain and sprockets job done on the tart as part of a
    service.
    [1] No - my little finger.
  13. The first model CB750 was notorious for snapping 'em at the cost of a
    lot of crankcase damage, although this tended to happen earlier than it
    would have on a SOBB.
    A mate had his snapped by an MoT tester who couldn't resist taking it
    out for a spin around the block (it only being out a couple of years at
    that time and it was the first one he'd been on - big Jap fours were
    still a rarity Notb). Much sturm and drang ensued when the crankcase
    damage became known, but the MoT guy saved his bacon when he spotted
    that the chain was actually made of several pieces of shite old BSA
    /Norton/Triumph chains riveted together; the owner being a notoriously
    tight-arsed git.
    Not surprising it snapped.
    Grimly Curmudgeon, Mar 2, 2010
  14. Zimmer 350cc?
  15. Nige
    Well within the scope of Loz's description.
    Pip, Mar 2, 2010
  16. Nige
    Beav Guest
    I've got a splitter/riveter for chains and still use a "G" clamp and 2 4mm
    sockets to press the new plate home.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 2, 2010
  17. Nige
    Beav Guest
    And there aren't many fitting shops will take *proper* care to ensure a
    perfectly true wheel alignment. and not doing so results in a fucked new
    chaon and a fucked rear sprocket.
    I'll carry on doing my own.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 2, 2010
  18. Nige
    Beav Guest
    My pal's SV650 was >< that close to needing a crankcase when his split link
    "let go" and the chain bailed out. I riveted a replacement chain on and it
    didn't spit the new one off. It really put me off using split link
    fasteners.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 2, 2010
  19. Nige
    Beav Guest
    Well not unless the "garage" that fitted the chain made sure the run was
    true. If not, the side forces can be more than enough to pop a side plate
    off if it's held only by a split springy thingy.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 2, 2010
  20. Nige
    Beav Guest
    I bet you thought the holes weren't big enough and contemplated running a
    drill through 'em.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Mar 2, 2010
