Braking Was : Best way to travel 5 miles to a train station?
Discussion in 'UK Motorcycles' started by DavidR, Aug 19, 2004.
  1. DavidR
    Velvet Guest
    Indeed :) I think we've just agreed on something there! It's easy to
    forget all the good interactions that happen, in the face of an
    interaction where one or other (or maybe both?) are the sort we're
    talking about, which was my point - it's no use the ones that are
    arrogant and abusive etc then turning round and complaining that
    everyone else are wankers toward them on the roads... this is almost
    certainly not actually the case, and if the majority of interactions
    *are* like this, they *really* need to address their own attitude
    problems first.
    Velvet, Aug 20, 2004
  2. DavidR
    Peter Clinch Guest
    ITYM should /not/...
    You don't really need them, as anyone[1] who uses the roads much can see
    reasonably easily that if you want to categorise by quality of vehicle
    management then the sort of vehicle isn't really that important. There
    are tossers in or on every sort of vehicle, and same goes for good and
    considerate as well.
    Anyone who thinks everyone using their pet transport type is necessarily
    Good and everyone in another sort conforms to purely stereotypical bad
    behaviour is in need of a trip to the Land Of Clues.
    Pete.
    [1] not necessarily plain rude, arrogant, inattentive, careless and
    abusive arseholes who are probably exactly the sort of personality type
    that shouldn't be allowed on the roads
    Peter Clinch, Aug 20, 2004
  3. DavidR
    Clive George Guest
    I'm sort of trying for the middle one.
    I changed it a bit. What do you think would happen if I chucked a motorbike
    out of a helicopter from 250m up onto you? Would you be endangered?
    You're getting there, but from the wrong side. Champ's question needs
    conditions applying to it, otherwise it's trivially easy to answer - eg in
    the situation I was describing.
    cheers,
    clive
    Clive George, Aug 20, 2004
  4. DavidR
    Ginge Guest
    Question, due to it's reduced width why would a motorcycle have to stop
    if it could simply slow down and avoid a hazard?
    Ginge, Aug 20, 2004
  5. DavidR
    Dan White Guest
    eh?
    Or perhaps, just perhaps, "Make sure that our drivers are properly trained
    rather than reducing everyone to a crawl to accomodate talentless fuckwits".
    Dan White, Aug 20, 2004
  6. That was what I was taught too. And not to worry too much about stalling,
    concentrate on the braking and worry about the clutch once it's no longer
    an emergency.
    Alan Braggins, Aug 20, 2004
  7. Certainly when the engine mountings break and drop the engine on the ground
    you stop in a reasonably short distance. (I knew someone it happened to.)
    On the other hand you can have a Renault 6 put a conrod though the crankcase
    and still drive to a phone box to call the AA (that was my car).
  8. DavidR
    Gawnsoft Guest
    Not if it leads you to believe you can brake from 150mph in a shorter
    distance than 245feet. (Highway code, based on drum braked cars on
    cross-plies)
    In a modern sports bike, assuming its brakes are up to the job, will
    still be doing between 121 and 126mph when you hit the point that the
    Mark 1 cortina has come to a complete stop.
    As we've already pointed out, actual braking distances of modern
    sports bikes (taken from motor bike mag tests, so in skilled hands at
    their least mechanically sympathetic), from 100mph vary from
    320 feet to 363 feet.
    100mph - 0mph
    Suzuki Hayabusa @ 359.9ft = 109.7 m
    GSX-R1000 @ 320ft = 97.5 m
    BMW R1100S @ 332.8ft = 101.4m
    Ducati Multistrada @ 362.8ft = 110.6m
    Yamaha Fazer 1000 @ 327.5 = 99.8m
    Kawasaki ZRX1200S @ 383.2ft = 116.5m
    Honda VFR ABS @ 347.4 ft = 105m
    Triumph Sprint ST @ 320.5ft = 97.7m
    Ducati ST4S ABS @ 318.4ft = 97m
    Aprilia RST Futura @ 338.6ft = 103m
    And 150mph means it takes 2 and a quarter times as far to brake as
    100mph.
    So the distances from 150mph for modern sports bikes (assuming their
    brakes are beefy enough not to fade with the longer braking time are:
    720 to 812feet.
    i.e. once you hit the mark where the drum-braked, cross-ply tyred car
    has stopped, you're still doing, at best, between 121mph and 126mph.
    I can see why - after all, you've demonstrated graphically the depth
    of your ignorance about modern bikes' braking capability., and of the
    fact that there are brand new cars on the road now that cannot meet
    the Highway code stopping distances
    Check out http://www.movit.de/htm/tabstop.htm and look for anything
    that does 55m or worse at 60mph, or 73m or worse at 110km/h. (I've
    even worked out the comparisons for you.)
    And there's at least one recent motorbike that can't meet the Highway
    Code stopping distance. (A Honda Goldwing takes 16 feet more than
    than the drum-braked, cross-plied cars of yore (59.9m)
    Actually, yes we have. Your contention was that braking distances
    have become incredibly much shorter. And they haven't.
    (Although top Porsche 911 can stop from 60mph in about two/thirds the
    distance a drum-braked, cross-plied car of yore could. If there's
    only one occupant, and the tyres and brake diskcs are at optimum
    temperature).
    You carry on breaking them with such an incredible shedload of
    ignorance, misinformation, and arrogance, and it's bad news for the
    other road-users.
    Cheers,
    Euan
    Gawnsoft: http://www.gawnsoft.co.sr
    Symbian/Epoc wiki: http://html.dnsalias.net:1122
    Smalltalk links (harvested from comp.lang.smalltalk) http://html.dnsalias.net/gawnsoft/smalltalk
    Gawnsoft, Aug 20, 2004
  9. DavidR
    Gawnsoft Guest
    Yep - when he reaches the point in the road where the old car has
    stopped, he'll still be doing over 120mph...
    Cheers,
    Euan
  10. DavidR
    Jon Senior Guest
    On the bright side, he may try to prove himself right, and so long as
    the object he hits is large, heavy, and inanimate, he may just manage to
    increase the average IQ of the world.
    We live in hope eh? ;-)
    Jon
    Jon Senior, Aug 20, 2004
  11. DavidR
    DavidR Guest
    Yes, skill and experience certainly allows judgements on the spot. As all
    road users do from time to time - a motorbike throbbing between your legs
    doesn't give you any particular monopoly. Experience doesn't seem to stop a
    lot of road users talking complete rot..
    I wonder what kicks you get from continuing to post against overwhelming
    evidence and (no doubt) loads of your motorcycling chums giggling in the
    background.
    Eh. Your argument was...?
    DavidR, Aug 20, 2004
  12. DavidR
    TMack Guest
    message
    SNIP?
    I wonder what happened with the Renault Laguna W2,2 dt !!!
    TMack, Aug 20, 2004
  13. DavidR
    Catman Guest
    You know, I've nver seen a biker with his full beams on. I do accept that
    they can dazzle, and try to posotion myslef accordingly, but the dazzle is
    (IME as a car driver) caused by the fact that the lights are higher off the
    ground. And now we can't turn the things off even if we want to.
    www.cuore-sportivo.co.uk
    Catman, Aug 20, 2004
  14. DavidR
    Gunga Dan Guest
    Ahh yes. That would be it.
    Gunga Dan, Aug 20, 2004
  15. DavidR
    mb Guest
    My bike does a lot better than 0.77g when stopping from 60-0mph.
    mb, Aug 20, 2004
  16. DavidR
    mb says...
    You'll be banging your head against a brick wall trying to explain that
    to those know-all calculator tapping cunts over there.
    Lozzo, Aug 20, 2004
  17. DavidR
    TMack Guest
    And how did you measure the g ????
    TMack, Aug 20, 2004
  18. DavidR
    DavidR Guest
    Maybe. I would accept up to 1.2g as a reasonable ball park figure. Your
    original claim needed 3 to 4g. That's why *you* have been banging your head.
  19. DavidR
    mb Guest
    Somebody did it for me, I made another post refering to this:
    http://www.mts.net/~neelin/motorcycle/biblio.html
    Halfway down the page "Stop Action--Yesterday's today's and tomorrow's
    brakes"
    I own such a machine.
    mb, Aug 20, 2004
  20. DavidR
    Gunga Dan Guest
    Well, to be fair, unless he was travelling at the same speed or slower, he
    would have had to alter his speed.
    Oh, on a motorway. I had this image of you pulling out of a side turn and
    then dawdling.
    Are you mad? If he'd been doing 150mph, it would have taken him 245ft just
    to get down to 125!
    I don't think using a headlight in the daytime is necessarily a good idea -
    the theory being that it reduces the abilty of the onlooker to judge the
    distance/approach speed of the vehicle - but are you really dazzled or is
    it just a bit annoying? It's very unlikely full beam you're seeing. As
    Catman says, just the relative distance of the headlight from the ground.
    The rude and abusive arseholes are just a sub-set of the human race. As for
    being arrogant, using the one true mode of transport does tend to make us
    feel superior.
