Braking Problems
Discussion in 'UK Motorcycles' started by Trevor, Apr 11, 2005.
  1. Trevor
    Trevor Guest
    Any ideas folks,
    Got a '98 Blade, brakes were fine until one day over winter had to go to
    work on it and got caught in the snow and grit. Left it in the garage
    for a couple of weeks afterwards & the front brake was seized on. So
    took the front wheel out & cleaned all the pistons up etc. Went out on
    the bike & got terrible juddering under braking, when I got back I
    looked at the discs to see they had been eaten away where the pads had
    seized. So I've got a set of disc's off eBay & fitted them, same
    problem, bought new pads same problem. Just checked the discs tonight to
    see if they were warped & there is less than 1mm runout on them. I'm
    stuck now any help would be appreciated.
  2. Trevor
    <snip>
    Did you torque the caliper mounting bolts properly when you fitted them?
    Muck, Apr 11, 2005
  3. Trevor
    Trevor Guest
    Yep went round tonight with the wrench to make sure, spindle, the 2
    bolts at the front of each leg & the calipers were all tight. Went out
    for a spin & no better.
    I'm happy to go out & buy brand new discs but worried I'll still have
    same problem and £300 poorer
  4. In uk.rec.motorcycles, Trevor amazed us all with this pearl of wisdom:
    Bled the brakes? I can't see it helping tbh but it's the only thing left
    isn't it?!
    Whinging Courier, Apr 11, 2005
  5. 1mm run out is a lot.
    Right, here's what you need to do. Take off the discs completely from
    the wheel. Using a decent wire brush (and maybe a scraper, but be
    careful) remove all the corrosion from the disc mounting faces on the
    wheel hub. It only takes a few thou of corrosion/old paint etc to
    cause a lot of run out at the disc edge.
    Clean the mounting faces to a nice shine, then a very light smear (and
    only a smear) of coppaslip on the faces and remount the discs.
    I suspect that will solve the problem.
    Simon Atkinson, Apr 11, 2005
  6. Trevor
    Wheel bearings? I thought of a few things, but got reading a book and
    forgot most of them.
    Muck, Apr 11, 2005
  7. In uk.rec.motorcycles, Muck amazed us all with this pearl of wisdom:
    Never had that when I've had a wheel bearing go. I just tends to make
    squealy noises for a while and then give up completely after much
    crunching for a mile or two.
  8. Trevor
    Trevor Guest
    Thanks, that's tomorrow evening planned out then, I'll report back.
