braking on ball-bearings
Discussion in 'UK Motorcycles' started by darsy, Nov 18, 2004.
  1. darsy
    Close shave indeed, I wouldn't have wanted the caliper to get ripped off
    the end of the pipe.
    Didn't you need a new pair of boots too?
    Muck, Nov 19, 2004
  2. darsy
    Dan White Guest
    Well thankfully I was only doing <30mph at the time, and Mr. Back Brake was
    still in fairly good nick!
    No, somewhat bizarrely it had wedged itself in between the outside of the
    boot and the toe-slider. Nasty bruise on as couple of toes though.
    Dan White, Nov 19, 2004
  3. darsy
    Dan White says...
    I lost the rear brake caliper from my second ZZR1100, it just fell off.
    It got a bit mangled by the rear wheel so I just cut the brake hose with
    a Swiss Army knife, lobbed the old caliper in a pannier and carried on
    my journey.
    Lozzo, Nov 19, 2004
  4. darsy
    Hmm.. I feel compelled to go outside and double check all my bikes
    brakes... well, I did the clean the drums out thing on my CG125 the
    other day.
    I like my moto X boots. Things tend to bounce off them, and not hurt my
    toes, shins. :)
    Muck, Nov 20, 2004
  5. darsy
    Beav says...
    Bollocks, absolute and total bollocks.
    Lozzo, Nov 20, 2004
  6. What he said.
    The Older Gentleman, Nov 21, 2004
  7. What he said.[/QUOTE]
    Try riding Gertrude one day.
    EBC drilled disk plus Harrison billet mini-6 caliper = interesting
    whirr when the brakes are applied. I worried until I was certain that
    it's pad/disk interaction.
    Christopher Des Clayes, Nov 21, 2004
  8. Try riding Gertrude one day.
    it's pad/disk interaction.[/QUOTE]
    Yes, the Duke's discs whirr also. Sound effects are not the same as
    physical effects, IYSWIM.
  9. Champ wrote
    Yebbut so do I so there is your credibility right out of the window.
    steve auvache, Nov 21, 2004
  10. darsy
    And me, FWIW. I had drilled discs on the Black Thing, and they made the
    whizzy noise in use, but never felt in any way dodgy.
    platypus, Nov 21, 2004
  11. darsy
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, platypus
    AOL. I *love* that whizzy noise. It really makes you feel like you're
    slowing down.
    And on the ZZR, any reassurance on the matter is very welcome.
    Nigel Eaton, Nov 21, 2004
  12. darsy
    The whizzy sound also tells me how long I've got until another brake
    rebuild is due on my Bandit.
    Muck, Nov 21, 2004
  13. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Beav"
    The only phenomenom I've occasionally encountered from drilled or
    slotted discs is a whirring noise at low speeds; certainly never felt
    anything from it.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Nov 21, 2004
  14. darsy
    I think the whizzy noise is more a product of the type of brake pads
    rather than the holes.
    Oddly, unwisely, tightfistedly (your choice) I have OE Brembo sintered
    pads on one disk and standard cheapo EBC on the other.
    One side (Brembo) makes whizzy noises the other (EBC) doesn't; both disks
    are drilled. Bear in mind on the Guzzi I can apply each disk separately.
    sweller, Nov 22, 2004
  15. darsy
    It is - I recall it first happening when the japs introduced sintered
    pads.
    Champ, Nov 22, 2004
  16. darsy
    Beav says...
    More a case of "So I know", and "So everyone else but you knows"
    Lozzo, Nov 22, 2004
