Brakes; see sig
Discussion in 'Classic Motorbikes' started by Howard, Mar 5, 2004.
  1. Howard
    Howard Guest
    Model 1982, my front brake slowly but steadily seems to be applying
    itself. In the space of 2/3 miles the operating lever requires less and
    less movement to apply the pads. Bleeding relieves the pressure, but why
    does it happen and how can I fix it?
    TIA
    Howard, Mar 5, 2004
  2. Howard
    'Hog Guest
    Assuming you are talking about the Beemer? also assuming you have the pivot
    well greased and there is no binding on the pivit or pistons? sounds like a
    vapor lock or water contamination. Flush the system right through with a
    good 250-500ml of fresh fluid.
    'Hog, Mar 5, 2004
  3. Howard
    JB Guest
    If your using standard rubber brake hoses, look for any bulges or swellings
    (feedlines'R'us), as you may have partial collapse of the inner wall of the
    pipe. Had this on a RangeRover recently.
    HTH,
    JB
    JB, Mar 5, 2004
  4. Howard
    Howard Guest
    All fluids less than 6 months old. I'll try for the vapour lock and
    bleed them again. I have been running it OK for those 6 months, and now
    this .... damn!
    Howard, Mar 5, 2004
  5. Howard
    'Hog Guest
    Er yes and check the tubes as JB suggested. Stainless lines are a good
    investment on old Beemers anyway. Just make sure you haven't overfilled the
    reservoir either.
    'Hog, Mar 5, 2004
  6. Howard
    Howard Guest
    Motorworks?
    It has always been around Max(+)
    Howard, Mar 5, 2004
  7. Howard
    'Hog Guest
    Remember there needs to be an air gap above the rubber bellows in the
    reservoir. I've overfilled one just to see what hapened and sure enough the
    brake starts to bind on. 3/4 way up between +/- is my usual.
    'Hog, Mar 5, 2004
  8. Howard
    Howard Guest
    Have bled the buggers, and they still appear to want to bind. Off now to
    check prices of braided hoses. I guess that will be 3 of them (asking
    really).
    Howard, Mar 5, 2004
  9. Howard
    Guest Guest
    Two?
    Mine's a single disk:
    (1) Bars to manifold
    (manifold to outside of fairing is a pipe)
    (2) Fairing to back of fork leg
    (crossover to other fork is a pipe)
    Twin disk ought only to have a different crossover pipe, surely?
    Regards,
    Simonm.
    Guest, Mar 5, 2004
