Brake system problems
Discussion in 'Australian Motorcycles' started by Matt Palmer, Oct 9, 2003.
  1. Matt Palmer
    Matt Palmer Guest
    Aaargh. It's just not happening for me. I've pulled the CB's front brakes
    apart and had a nice inspection, and bled it until I can bleed no more
    (literally), and it's still soft. But I've got pressure through the system,
    just not enough.
    So, here's a question - has anyone ever seen a pressure gauge suitable for
    testing a bike's brake system, and (assuming such a beastie exists) what
    sort of pressure I'd be looking at getting? My plan is to run through the
    whole system with this pressure tester trying to work out whether it's the
    master cylinder not playing well, or what.
    - Matt
  2. Matt Palmer
    knobdoodle Guest
    Get a big cable-tie and zip your brake lever in to the 'bar and then leave it overnight.
    knobdoodle, Oct 9, 2003
  3. Matt Palmer
    Centurion Guest
    Can't help with the brakes but run down to Pirtek in Unanderra and ask them
    nicely to hook up a gauge for you. They did a similar thing for me with a
    problem I was having with my boat (needed to test the pressure of the
    cooling water to see if the pump was OK without dropping the gearbox).
    They are a pretty good crowd in my experience.
    --James
    ZZR250==>ZX9R
    __________________________________
    A random quote of nothing:
    Hello. Jim Rockford's machine, this is Larry Doheny's machine. Will you
    please have your master call my master at his convenience? Thank you.
    Thank you. Thank you. Thank you. Thank you. Thank you.
    -- "The Rockford Files"
    Centurion, Oct 10, 2003
  4. Matt Palmer
    vifer Guest
    You might also want to try bleeding the system from the master cylinder
    bango bolt or the junction split a couple of times before you move onto the caliper nipples.
    vifer, Oct 11, 2003
  5. the caliper nipples.
    Or you could just run the bike with no front pads or brake fluid (Police
    Camera Action last night)---disc completely rustcoated when the Pommy
    coppers pulled him over,so it'd obviously been without front brakes for some
    time...
    Postman Pat The Dastardly Scoundrel
    Pat Heslewood, Oct 12, 2003
  6. Matt Palmer
    Theo Bekkers Guest
    "Matt Palmer" wrote
    A couple of suggestions.
    Check in the master cylinder to make sure the piston returns far
    enough to uncover the tiny feed hole from the reservoir and that it's
    not blocked. If this is the problem you can't bleed the brakes as
    fluid will not flow through the system.
    I reverse bleed my brakes using a 60 ml syringe and a plastic hose to
    pump brake fluid into the system from the slave cylinder bleed screw.
    Air travels up the line much better than it flows down. Make sure you
    don't overflow the master cylinder reservoir.
    Theo
    Theo Bekkers, Oct 14, 2003
