brake problems??
Discussion in 'Motorbike Technical Discussion' started by zoot, Sep 8, 2008.
  1. zoot
    zoot Guest
    just got an 82 xj750 seca with 4,000 miles on it. rode it around for
    about a week and all of a sudden the front wheel is locked up. tried
    opening the bleeders and that did nothing. i gather that seca front
    breaks are problematic and costly. i'll try to reach the previous
    owner and find out if he did anything[ like a rebuild] that could have
    gotten parts put on wrong. pads look unworn from what i can see
    without taking stuff apart. any ideas???
    zoot, Sep 8, 2008
  2. zoot
    . Guest
    Take the master cylinder cap off and poke a pin or needle through the
    tiny air bleeder port in the bottom of the reservoir. That usually
    does the trick.
    If that doesn't fix the problem, remove the calipers and remove the
    dust caps
    from the pistons and clean the brake dust from around the piston(s).
    If there is only one piston on each caliper, there will be slider pins
    that the calipers slide sideways on. The pins have to be lubricated
    with a high temperature grease (or a waterproof grease if you ride on
    roads that are salted in winter).
    If a cursory external cleaning doesn't do the job, you'll need to pump
    the pistons out of the calipers by working the brake lever and then
    you can clean all the rubber particles and rust out of the brake
    piston bores.
    ., Sep 8, 2008
  3. zoot
    Guest Guest
    If the front brake lever is binding or hitting something, keeping it
    from fully releasing, pressure will build and cause the brakes to
    lock.
    One of the less likely causes, happens more often on dirt bikes with
    hand guards that just touch the lever when its released, but it
    happens now and then.
    Guest, Sep 8, 2008
  4. zoot
    ian field Guest
    WD40 will destroy any brake system rubber parts it comes into contact with!
    The best solution is to strip, clean and replace seals on the calliper and
    use silicone grease to lubricate and prevent corrosion during reassembly, if
    your automotive supplier doesn't have silicone grease get it from an
    electrical/electronics supplier.
    ian field, Sep 11, 2008
  5. zoot
    zoot Guest
    the book says use brake fluid to lube. i'll use calipers from my other
    seca till i get parts and go with what mark said. pistons and
    cylinders have caked on crud from siting so long. btw thanks everyone.
    i love this group.
    zoot, Sep 11, 2008
  6. zoot
    ian field Guest
    All the books say that! Brake fluid is hygroscopic which means that it
    readily absorbs water which in the fullness of time causes the crud and
    corrosion on exposed alloy parts that were 'lubricated' with brake fluid.
    Silicone grease is highly water repellent and is a better lube than fluid,
    it won't do any harm to the seals - in fact it protects them and it can be
    an effective barrier against brake dust getting between the piston and
    calliper bore.
    But they're your brakes and its your time spent servicing the brakes again
    sooner than you need to.
  7. Not in my experience.
    The Older Gentleman, Sep 11, 2008
  8. zoot
    . Guest
    WD40 is mostly a petroleum distillate with a specific gravity about
    the same as diesel. The distillate is supposed to evaporate and leave
    the secret proprietary ingredient on the metal part...
    WD40 acts as a solvent on rubber parts that are in intimate contact
    with metal.
    I got tired of the rim corrosion resulting from using liquid soap for
    a tire bead lubricant and had a spray can of WD40 handy, so I sprayed
    the tire beads and the rim with it.
    The tire mounted fine, but the bead was glued to the rim the next time
    I changed tires manually, using tire irons.
    Another rider confirmed the same experience.
    If I had used a tire changing machine to break the beads loose, I
    probably would never have noticed anything.
    I suppose WD40 would do the same thing to the rubber seals in brake
    calipers if the calipers were assembled and then the motorcycle wasn't
    ridden for a few months.
    ., Sep 11, 2008
  9. zoot
    paul c Guest
    No argument, just want to mention that I believe DOT 5 fluid is the
    exception. Not recommending it as I also believe it needs to be
    replaced more frequently.
    paul c, Sep 11, 2008
  10. zoot
    ian field Guest
    DOT5 has some other disadvantages, like - surprisingly its more compressible
    and has a lower temperature rating, but the brake seals do last pretty much
    forever.
  11. Dunno. I've used it in and around brake and all sorts of other rubber
    parts for years, and never had a problem. *Shrug*.
  12. And what makes you think that components used in brake systems are
    natural rubber?
    The Older Gentleman, Sep 12, 2008
  13. zoot
    . Guest
    Why don't you tell us what you have experienced and what you have
    learned, instead of trolling for a debate?
    The synthethic rubber in tires definitely contains an amber-brown
    colored oil, it's used to extend the dynamic range of elasticity, and
    recyclers got about half to one gallon of oil out of every old tire.
    ., Sep 12, 2008
  14. zoot
    TOG@Toil Guest
    What's that got to do with it? Do you really think exactly the same
    substance is used for brake components as for tyres? I rather doubt
    it.
    I'm just saying I've used WD40 for ages to clean brake parts (erm,
    except pads....) and I've never suffered a problem. Two posters here
    say it will destroy the rubber components used in brake systems. My
    own empirical experience, over 30-odd years, says it doesn't. Neither
    poster admits to having suffered brake failure from using WD40 around
    brake components, so I strongly doubt they have any direct experience.
    I'd be interested to know from someone who definitely knows[1],
    because if I've been doing something silly and dangerous all these
    years, I'd better stop. I'm not trolling for an argument - if anyone
    is, you are. I'd really like to know one way or the other.
    [1] ie: not you.
    TOG@Toil, Sep 12, 2008
  15. zoot
    . Guest
    Well, *so would I*...
    Stay out of those hot air balloons then.
    Bollocks. Trolling is your whole life.
    ., Sep 12, 2008
  16. zoot
    TOG@Toil Guest
    Actually, hot air balloons are the safest form of flight apart from a
    modern commercial jet. Way, way safer than private aircraft and
    especially helicopters. Fatal accidents are (thankfully) very rare.
    Would you like to display more of your ignorance?
    Nope. But keep playing.
  17. zoot
    . Guest
    Do you think you will do *anything* useful for your employer today?
    ., Sep 12, 2008
  18. zoot
    TOG@Toil Guest
    Oh, I reckon.
  19. zoot
    Anonymous Guest
    Well, I know that transmission fluid(FoMoCo) will definitely
    compromise brake internals. Don't ask me how I know this. <g>
    Anonymous, Sep 12, 2008
  20. zoot
    . Guest
    Oh, no! You've made an admission of guilt, at least in the mind of The
    Old Gasbag.
    There should be a law that states TOG has to mirandize newbies before
    he can sodomize them.
    ., Sep 12, 2008
