Brake problem, suggestions wanted...
Discussion in 'UK Motorcycles' started by Eddie, Apr 19, 2007.
  1. Eddie
    Eddie Guest
    I've bled my brakes. Many, many times.
    I've tied the lever back overnight.
    I've tied the lever back overnight, *then* bled the brakes.
    Tonight, I've replaced the master cylinder internals, bled the brakes,
    and tied the lever back.
    I just know that come tomorrow, it'll be the same story: they'll feel
    fine to start with, but they'll feel like they're losing pressure by the
    time I've got to work. When I leave work tomorrow afternoon, I'll
    probably be able to pull the lever right back to the bar.
    My guess is that air's getting in somewhere, but where?
    Any suggestions for how to cure it? (Preferably not involving £90
    deposit and 0% finance, thankyouverymuch.)
    Eddie, Apr 19, 2007
  2. Eddie
    In yer nipples, son. They bain't be seating roight.
    New nipples. Seriously. Don't overtighten 'em.
    Pip, Apr 19, 2007
  3. Eddie
    Eddie Guest
    <fx: peers down t-shirt>
    Oh, *those* nipples.
    Anyway, what leads you to that conclusion? And, if that's the case, how
    come the brake fluid doesn't seep out while the lever's tied back?
    Gah. Worth a try, I guess. Should have ordered some when I got the
    master cylinder rebuild kit.
    Eddie, Apr 20, 2007
  4. Eddie
    Molly Guest
    Air is much thinner than oil.
    Make sure the hole they are going into is clean.
    Molly, Apr 20, 2007
  5. Eddie
    AJ Peters Guest
    New copper washers as well
    AJ Peters, Apr 20, 2007
  6. Eddie
    Eddie Guest
    Do you think I'm made of money?
    Anyway, IIRC the ones that were used when the calipers were replaced
    were new.
    Eddie, Apr 20, 2007
