Brake fluid
Discussion in 'UK Motorcycles' started by Gyp, May 27, 2004.
  1. Gyp
    Gyp Guest
    HD says DOT 5, Halfords only stocks DOT 5.1
    For the purposes of slowing the tractor, are they the same thing?
    Gyp, May 27, 2004
  2. Gyp
    Gyp wrote in
    If you do not upgrade to 5.1 you may find that the tractor succumbs to
    attack by worms.
    wessie, May 27, 2004
  3. Gyp
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Gyp
    How much worse could the brakes be?
    Nigel Eaton, May 27, 2004
  4. Gyp
    platypus, May 27, 2004
  5. Gyp
    ß Ø ® G Guest
    you CAN NOT mix DOT 5 and 5.1, 5.1 is totally different and will gell
    up if you add it to any other DOT 1-2-3-4-5 . Urine is DOT 1 by the
    way :)
    so if you have had normal brake fluid in the pipes don't use DOT 5.1
    E-Mail Addy obet(ng)qfy(qbg)cvcrk(qbg)pbz <---Rot13 it
    watch out for spam trap in header
    Free Phone Unlocking http://unlockme.co.uk
    10p a Picture Message/MMS http://www.mmsit.co.uk/
    http://www.davessite.co.uk Trike Power the TRUE Trinity
    ß Ø ® G, May 28, 2004
  6. NO
    There's merkin logic for you.
    5.1 is not an upgrade of 5.
    Wrong, incorrect, not right, you muppet, and totally contratictory to
    your previous statement.
    DOT 5.1 is compatible with 3, 4 etc.
    DOT 5 is the silicon based one and should not be mixed with 3, 4 etc.
    ColonelTupperware
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/
    UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, May 28, 2004
  7. Gyp
    Gyp Guest
    So...
    If I put in 5.1 instead it will be OK, but I shouldn't top up 5 with
    5.1?
    That's how I read it anyway.
    Gyp, May 28, 2004
  8. Gyp
    mups Guest
    Gyp says...
    As others have said you cannot mix DOT 5 with DOT 5.1 unless you want
    your seals to go bye bye. I'm curious as to why HD use DOT 5 in the first
    place, anybody know why?
    mups, May 28, 2004
  9. Gyp
    Gyp Guest
    After the lid vibrated off on the way to Avebury a couple of weeks ago I
    pressure washed the bike to get all the fluid off so I'm basically
    running water in there at the moment. I suspect any sort of brake fluid
    would be better than that
    Gyp, May 28, 2004
  10. Gyp
    flash@work Guest
    Jesus, i'm still on dot 4. Bet my brakes aren't supported any more.
    flash@work, May 28, 2004
  11. Gyp
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, "flash@work"
    You think you're in trouble. My brakes are dot net. They don't work and
    no one understands why, or what they were supposed to do in the first
    place.
    Nigel Eaton, May 28, 2004
  12. Gyp
    flash@work Guest
    Dot.net rocks.
  13. Gyp
    flash@work Guest
    I can't see the point in any of the dot stuff.
  14. Gyp
    mups Guest
    Gyp says...
    No, once you've had DOT 5 in your brakes you can only use/top up with DOT
    5, you can't use DOT 3,4 or 5.1. It's a bit like mixing normal 2 stroke
    oil and Castrol R.
    mups, May 28, 2004
  15. Gyp
    As long as you've completely flushed out the whole system, yes.
    Ace, May 28, 2004
  16. Gyp
    Ginge Guest
    Dot net - Luxury! I once rode a bike with dot com brakes, they worked
    really well for a short while, then just collapsed.
    Ginge, May 28, 2004
  17. Gyp
    Gyp Guest
    Best I call in at the Harley dealer then for some Harley Davidson (tm)
    Screamin' Eagle (r) race brake fluid (r) at a price significantly
    different to the 5.1 in Halfords then
    Gyp, May 28, 2004
  18. Gyp
    ß Ø ® G Guest
    yes true I got them 2 the wrong way round I sit muppetfied
