Brake calipers
Discussion in 'Australian Motorcycles' started by Bill_h, Mar 10, 2010.
  1. Bill_h
    Bill_h Guest
    Anyone have any hints on disassembling single sided brake callipers? The
    front brake on the Revere is binding.
    Ta, Bill
  2. Bill_h
    Lars Chance Guest
    Just spray the crap out of everything with Silicone spray Bill. A few
    stops and it'll burn off the bits it's not s'posed to be on.
    Lars Chance, Mar 10, 2010
  3. Bill_h
    alx Guest
    You may avoid a complete disass. by just forcing the piston/s out far
    enough to clean the seals. (toothbrush and some cleaner..be gentle on
    the seals).
    Remove caliper off discs then pump brake to slowly move piston out.
    This will expose clean piston and allow you to get the grunge off the
    seal/piston interface.
    make sure the top reservoir does not go too low and allow air into the
    system.
    Then press piston back by hand and place on disc. Completely flush
    through new fluid.
    alx, Mar 10, 2010
  4. Bill_h
    atec 77 Guest
    Cleaning them with brake spray as they are stripped and an assembly with
    silicon spray or a smear of fresh fluid and then a good bleed usually
    sorts them , if they are going west you normally get a spongy feeling
    and a sick stomach about the same time :)
    If you are unsure then pay someone competent
    atec 77, Mar 11, 2010
  5. Bill_h
    Lars Chance Guest
    Pfft! Lever, piston, pipe, piston(s), pads, disk(s). What could be
    simpler?
    Has anyone you know ever suffered a genuine (problem-causing)
    brake-failure? (Apart from maybe a snapped cable on a drum)
    Lars Chance, Mar 11, 2010
  6. Bill_h
    GWD Guest
    Yes
    It's a sickening feeling - similar to accidentally opening the
    throttle wide as hell.
    I'm with Moike - don't play with this shit unless you know exactly
    what you are doing.
    GWD, Mar 11, 2010
  7. Bill_h
    Lars Chance Guest
    Plize exploin.
  8. Bill_h
    GWD Guest
    Erm... brake failure is no fun at any speed..?
    GWD, Mar 11, 2010
  9. George, I have to disagree with you there,
    In times gone by, and I am only going back 30 - 40 years, there was no such
    thing as a motorcycle mechanic, an owner had to do any repairs himself or
    take it to a motor car garage and get the mechanic there to fix the problem,
    or attempt to fix it.
    No-one knew knew exactly what they were doing, they learned along the way.
    Most repairs were done by the owner at home and that was where you learned
    about how the bloody thing worked, or didn't want to work.
    You madew a lot opf misteaks, but in all, you got your bike going one way or
    another.
    You pulled things apart and learned how it went together, you read up books
    written by others who had the same or similar problems and you fixed it.
    In saying that, I am, not suggesting that everyone starts fixing their
    broken or near broken bike, I am saying that look at and try to work things
    out yourself.
    You will save a lot of money that way and also learn about how bikes work
    and run.
    Also, given that, there are some riders out there who wouldn't have a clue
    how to fix anything
    George W Frost, Mar 11, 2010
  10. Bill_h
    Lars Chance Guest
    Neither are old wives' tales
  11. Bill_h
    GWD Guest
    Yeah fair enough George. I can relate to a lot of what you are saying.
    I also know that brake failure is bad for your health. Time bombs like
    using the wrong cleaners, wrong fluid, leaky joints, contaminated
    fluid (air or dirt et al) are all things that all too often creep up
    on you when you least expect them, ask anyone who has spent a decent
    amount of time in a repair shop. Then there are the mistakes that are
    just plain expensive like incorrect assembly, mis-wired electrics...
    I learned a lot of what I know through trial and error too, but I
    suggest that things like brakes should not be treated with cavalier
    arrogance (and ignorance) as suggested elsewhere in this thread.
    GWD, Mar 11, 2010
  12. In aus.motorcycles on Fri, 12 Mar 2010 10:45:32 +1100
    What?
    it is now 2010. 30 years ago was, I regret to inform you, 1980.
    Rather a lot of motorcycle mechanics around in 1982 when I started
    riding, can't believe they all sprung up in 2 years?
    Even 40 years was 1970. Now it might be that there weren't massive
    numbers of motorcycle shops with mechanics in Oz then, but considering
    there were ones in the 1920s there had to be some.
    Hey Theo, when did Ted Stolarski start? Pitmans in Adelaide dates
    from at least the mid 70s, ditto The Bike Factory. I'm pretty sure
    Central had been in business since the mid 50s.
    Then there's all the ads in my early 70s copies of 2 Wheels for shops
    and people offering service.
    Even in country towns!
    So better sigh, count the grey hairs, and change the whine to "50-60
    years, in country towns"
    (Because in those aforementioned 70s mags are ads for places
    announcing they've been in the motorcycle business for 20 years...)
    Zebee
    Zebee Johnstone, Mar 11, 2010
  13. Bill_h
    atec 77 Guest
    When I was living in Unzud in the 1960's the local bike shop in Petone
    had started just post war , the same owners until the retired around
    1970 and several of the larger shops in Wellington had traded from the
    1920's. I would expect the same in Au
    atec 77, Mar 12, 2010
  14. Bill_h
    theo Guest
    I bought my first Guzzi from Ted in 1976, but he was supplying
    scooters (real Italian ones) to Perth City parking Insoectors for at
    least 15 years before that.
    I can't agree with that Zebee. My country town, Northam, with a
    population of 8000, had two motorcycle shops, both with excellent
    mechanics, in the mid-fifties. That's 65 years ago and they were both
    well-established businesses.
    Theo
    theo, Mar 12, 2010
  15. Bill_h
    theo Guest
    I witnessed a sidecar race where a rotor shattered at Wanneroo
    raceway. The outfit didn't make the corner. I spoke to the driver
    afterwards, John Bertina, I worked with his Brother Hans for 25 years
    at NCR.
    Theo
    theo, Mar 12, 2010
  16. Bill_h
    theo Guest
    Pal & Panther in North Perth has been in business for three
    generations, since 1928.
    Theo
    theo, Mar 12, 2010
  17. I bought my first Guzzi from Ted in 1976, but he was supplying
    Theo
    Shit, what happened to the past 10 years?
    you have us in 2020 already Theo.
    George W Frost, Mar 12, 2010
  18. Maybe I should have explained what I meant,
    I presumed everyone would understand
    although there are some who don't want to understand or even try to
    What was meant, was that 30 - 40 years ago,
    there was no fully qualified motorcycle mechanics around, they were all self
    taught and learned from their experiences.
    Ands by fully qualified, I mean Trade School taught,
    there was no official training course for motorcycle mechanics.
    There may have been motorcycle shops and motorcycle repair shops, but they
    didn't have full Trade School training
  19. I witnessed a sidecar race where a rotor shattered at Wanneroo
    at NCR.
    Theo]
    That was luxury to ride in an outfit with hydraulic disk brakes
    I learned on a pre-unit Triumph with drum brakes and the luxury of the day,
    was to have twin leading shoes.
  20. Bill_h
    atec 77 Guest
    Of there were correctly trained bike mechanics , either ex factory or ex
    military remember many were European hence trained
