Brake caliper torque
Discussion in 'UK Motorcycles' started by Stonge, Jun 1, 2004.
  1. Stonge
    Stonge Guest
    Hi,
    Just got the bandit's tyre plugged, but in replacing the brake caliper, the
    bolts didn't want to torque up (supposed to be 25 lbs/ft).
    Didn't want to over do it, as they're only softish metal...
    Is this usual?
    Stonge
    AP50, YB100, GSX250, Z400J, CB250, GPz550, FJ1200, GSF600S
    http://www.brainbashers.com
    Stonge, Jun 1, 2004
  2. Stonge
    Mark Olson Guest
    Don't follow you. Are you saying they are stripped? My SV caliper
    mounting bolts are spec'ed at 28 ft-lb (39 N-m). Did you use a
    torque wrench?
    Mark Olson, Jun 1, 2004
  3. Stonge
    Stonge Guest
    No (at least I don't think so).
    Yes - but it didn't trigger it and it just felt wrong as I was tightening,
    so I stopped turning. Put the spanner back on and they feel tight.
    25 lbs/ft isn't far off hand tight with a spanner, so I'll probably leave
    them alone.
    Kev
    Stonge, Jun 2, 2004
  4. Stonge
    Stonge wrote in
    sounds like the torque wrench is fucked
    leave the setting the same and try it on a bolt with a higher setting[1] to
    see if it triggers before the bolt moves
    [1] axle?
    wessie, Jun 2, 2004
  5. Stonge
    Stonge Guest
    Definitely works...
    Torqued axle up to 100, and the tested on 25 - worked a treat.
    Stonge
    Stonge, Jun 2, 2004
  6. Stonge
    Mark Olson Guest
    Ooh, good call. My cheapie clicker wrench sometimes decides it isn't
    going to click...[1] so I've taken to clamping the square drive in the
    vise and testing it before doing up bolts. I suppose I should bin it
    and get a better one.
    [1] I suspect it happens if I've unwound the spring tension too far,
    so I've started leaving it set to at least 120 inch-lbs or so.
    Mark Olson, Jun 2, 2004
  7. Be feckin' careful. I've stripped bolts before when tightening them up
    to the recommended torque.
    And I've known Haynes manuals get the torque settings wrong.
    The Older Gentleman, Jun 2, 2004
  8. Stonge
    Eddie Guest
    Hmmm... you're generally supposed to leave them untensioned.
    It's probably fucked, or at least needs an overhaul and checking the
    calibration.
    Eddie, Jun 2, 2004
  9. Stonge
    Ovenpaa Guest
    That will shag it completely. When the spring is left compressed for any
    reasonable period of time it will give a lower poundage than shown.
    DAMHIKIJFK.............
    /d
    Ovenpaa, Jun 2, 2004
  10. Stonge
    John Heath Guest
    the
    Brake calliper mounting bolts on mine are 27Nm.
    I had one that wouldn't torque up, the first time that I had the calippers
    off. You can put so much leverage with a torque wrench - I didn't want to
    strip the threads - and it felt wrong.
    I tried the wrench at lower settings. It would click up to about 15Nm,
    after that it never reached the click point.
    So I took the bolt out and inspected it. It had been stretching - the
    centre part of the bolt was thinner than the rest. I reckon that the
    previous owner had over tightened it at some point.
    Rather worrying. I replaced all of the mounting bolts.
    John Heath, Jun 2, 2004
