Brake Caliper Mods
Discussion in 'Australian Motorcycles' started by Trips, Nov 13, 2003.
  1. Trips
    Trips Guest
    If you wanted better braking out of a bike and can't afford a new
    fancy brembo or whatever to fit the bike (seems bugger is made for
    mine :( ) would it be possible to take the caliper to a machine shop
    and get them to machine it out so you put in bigger pistons?
    Trips, Nov 13, 2003
  2. Trips
    Frank Warner Guest
    Anything is possible ... but I am certain it would cost more than going
    to the wreckers and geting secondhand items there.
    Any relation to James Mayfield?
    Frank Warner, Nov 13, 2003
  3. Trips
    RM Guest
    no really...it would be easier to get some 4 piston or such calipers from a
    wrecker and make adaptor plates...most likely need the master cyl to match
    RM, Nov 13, 2003
  4. Trips
    FuTAnT Guest
    And when you reply, give all your info to James so he can work out what to
    do with the ZX10 :)
    Cam
    '03 954
    FuTAnT, Nov 13, 2003
  5. Trips
    sharkey Guest
    Hey, speaking of which, any recommendations for 4-pot calipers
    to fit 21" spoke wheels :)
    -----sharks
    sharkey, Nov 13, 2003
  6. Trips
    RM Guest
    performance machine?
    RM, Nov 13, 2003
  7. Trips
    Trips Guest
    No, bet seriously trying to find a better performing caliper
    that can bolton to a CBR1000 in bloody impossible. There are very few
    wreckers here. We must crash bikes less often over here in the West.
    ;P
    Trips, Nov 13, 2003
  8. Trips
    Trips Guest
    300mm if I'm not mistaken. (Often am)
    Twin Piston Nissins. They year before they went for the DCBS. Not
    sure if I'm lucky or unlucky on that one. :)
    Had em, but some nast c*nt cut em with some side cutters or something
    when I parked it at the movies. Luckily I noticed the brake fluid
    puddle before I took off.
    EBC Green
    Trips, Nov 13, 2003
  9. Trips
    Trips Guest
    If you use adapter plates won't you get too much flex?
    If get a Master Cylinder with a bigger bore will it necessarily brake
    better or just lockup quicker?
    Trips, Nov 13, 2003
  10. Trips
    glitch1 Guest
    For a real quick-stopper?
    Piece of 2x4
    pete
    glitch1, Nov 13, 2003
  11. Trips
    RM Guest
    well if you are going to fit new calipers you will probably need to use the
    correct m/cyl
    flex?...no not if they are designed and made correctly
    RM, Nov 13, 2003
  12. Yeah, I wish I had them on the z13.
    I don¹t know how I manage.....
    Hammo
    Hamish Alker-Jones, Nov 13, 2003
  13. 'triffic. You want some old CX500 ones with new ish pads?
    Hammo
    Hamish Alker-Jones, Nov 14, 2003
  14. Trips
    sharkey Guest
    If Hammo doesn't take 'em, I will.
    -----sharks (still waiting for those TRX calipers that you can't
    _give_ away ...)
    sharkey, Nov 14, 2003
  15. Trips
    John Littler Guest
    :p
    You asked the TRX list lately ?
    JL
    (sorry I still can't find mine)
    John Littler, Nov 15, 2003
  16. Trips
    Frank Warner Guest
    People are using the brembo 4 pots off K11s on R80-100G/S bikes ..
    Frank Warner, Nov 17, 2003
  17. Trips
    Nope; normally they go on the disks.
    Clem
    Knobdoodle, Nov 18, 2003
  18. Trips
    geoff_m Guest
    Are they the same calipers used on other bikes of the same vintage?
    might be worth having a rmmage at your local wreckers.
    g
    geoff_m, Dec 19, 2003
  19. Trips
    John Littler Guest
    Yeah also used on the FZR1000, TDM, XJ900 of the same era and a bunch of others
    JL
    (who has a set he couldn't sell and now can't find - it's in one of the shed's
    somewhere)
    John Littler, Dec 20, 2003
