Brainwaves needed
Discussion in 'UK Motorcycles' started by Simes, Jun 5, 2005.
  1. Simes
    Simes Guest
    Ok...
    SR125 - been stood standing for a couple of years.
    Now it runs - but wont tickover - it's a mate's lad's bike and I've ben
    on the blower berating him for his cack-handed spannering skills, but
    he's actually done everything I would have done and it's still the same.
    He's drained the fuel tank and refilled with fresh. Had the carb off
    and cleaned it thoroughly - I've not seen it but he tells me there is
    no clag left in there - and he's actually an OK mechanic.
    He's changed the plug and plag cap - he's checked the timing and valve
    gaps. He's tried thrashing it round the block a few times.
    Any thoughts?
    Simes, Jun 5, 2005
  2. In uk.rec.motorcycles, Simes amazed us all with this pearl of wisdom:
    Err.. Idle screw?
    Whinging Courier, Jun 5, 2005
  3. Simes
    Simes scribbled on the back of a napkin:
    What did he use to clean the carb? If it was well gummed up then you
    can bet your backside that the nasty chemical cleaners didn't clear out
    some small air or fuel passage only needed at idle.
    Get it ultrasonically cleaned, see if that makes a difference,
    otherwise get him to buy a CG125.
    Timo Geusch, Jun 5, 2005
  4. Simes
    Colin Irvine Guest
    Perhaps when he's got it mended, as a reward?
    Colin Irvine, Jun 5, 2005
  5. Simes
    Ben Blaney Guest
    Only if his mate doesn't mind lending him the sofa for a few minutes.
    Ben Blaney, Jun 5, 2005
  6. Simes
    Wot 'e sed.
    Or maybe an air leak on the intake.
    Pip Luscher, Jun 5, 2005
  7. Simes
    mb Guest
    Cleaned/changed the air filter...?
    mb, Jun 5, 2005
  8. Simes
    Simes Guest
    Whinging said:
    Not at the minute thanks.
    Nope not that - The slide has to be lifted further than the idle screw
    will go just to keep it running. It's as if the pilot jet is blocked,
    but it's not.
    Simes, Jun 5, 2005
  9. Simes
    Simes Guest
    mb said:
    Yep.
    Simes, Jun 5, 2005
  10. Simes
    Ben Blaney emerged from their own little world to say
    or the seat of a Merc van
    wessie, Jun 5, 2005
  11. Simes
    Dan L Guest
    Has he really nipped up the nuts which attach the carb to the head. I had a
    similar problem with the TS50, and found that overtightening the two nuts
    caused the carb body to distort, and wouldn't let the widget inside slide up
    and down as it should.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Jun 5, 2005
  12. In uk.rec.motorcycles, Simes amazed us all with this pearl of wisdom:
    That's ok, I'm gonna empty my sack when I'm in the bath later...
    Well, apart from another dim suggestion of a blocked air filter I'm all
    out of ideas.
  13. In uk.rec.motorcycles, Whinging Courier amazed us all with this pearl of
    wisdom:
    Yeah, ok. TMI...
    Bugger, Ginged by mb.
  14. Simes
    Simes Guest
    Dan said:
    All widgets sliding in a very pleasant manner. I think perhaps it's
    just fucked.
    Simes, Jun 5, 2005
  15. Simes
    Dan L Guest
    Shit in the carb then (see if that helps).
    Dan L (Oldbloke)
    Dan L, Jun 5, 2005
  16. Simes
    Simes Guest
    Petel said:
    The shame!
    He tells me (the mate) that he's done the squirt with WD all round and
    it made no difference...
    Simes, Jun 5, 2005
  17. Simes
    petrolcan Guest
    HT lead?
    petrolcan, Jun 5, 2005
  18. Simes
    petrolcan says...
    I'm going with a partially blocked pilot jet or stuck choke mechanism.
    Lozzo, Jun 5, 2005
  19. Wot he said... The idle circuit is blocked.
    eric the brave, Jun 5, 2005
  20. Simes
    eatmorepies Guest
    My MZ125 manual suggests a 'bristle from Mother's broom' to clean the carb.
    John
    eatmorepies, Jun 5, 2005
