Braided hoses question.
Discussion in 'UK Motorcycles' started by Salad Dodger, Oct 23, 2004.
  1. Salad Dodger
    Salad Dodger Guest
    When fitting these is it customary to re-fit the little rubber boots
    that were on the original hoses?
    I'm getting there, other wise.
    Front offside caliper cleaned and stripped and refitted; front wheel's
    back in; air filter [1,2] cleaned and replaced; handlebars refitted (a
    job in itself) and one handlebar cover fitted, after about 6 attempts.
    [1] previously containing 5 wasps.
    [2] Accelerator pumps! Blimey.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
  2. Salad Dodger
    Robbo Guest
    Assuning you mean the ones that cover the ends of the connectors I reckon
    it's your choice if they look naff then leave em off.
    It's not rocket science
    Sounds like a productive job so far.
    Of course you've thoroughly bled the brakes.
    Robbo
    Trophy 1200 1998
    BMW K100 RS 1984
    B.O.S.M 2003, 2004
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Oct 23, 2004
  3. Salad Dodger
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Robbo
    On a Wing? Au contraire, surely?
    Nigel Eaton, Oct 23, 2004
  4. Salad Dodger
    Replace with chrome, Shirley.
    Pip, Oct 23, 2004
  5. Salad Dodger
    Salad Dodger Guest
    I was more concerned with the ones that go inside the frame clips,
    but, as I can't get the banjo bolts through them, they've "solved" the
    problem themselves.
    | ___ Salad Dodger
  6. Salad Dodger
    Salad Dodger Guest
    Not a chance.
    I have pad-free brake pads at the moment.
    | ___ Salad Dodger
