BOTAFOF now
Discussion in 'UK Motorcycles' started by darsy, Jul 10, 2005.
  1. darsy
    well, ish.
    9:15->9:30 at the petrol station at South Mimms services.
    darsy, Jul 10, 2005
  2. darsy
    Ben Blaney Guest
    400 Four?
    Ben Blaney, Jul 10, 2005
  3. darsy
    Catman Guest
    Bugger. Plans already in place
    www.cuore-sportivo.co.uk
    Catman, Jul 10, 2005
  4. darsy
    aye. It goes well, though once or twice the clutch slipped, not under
    load exactly, but being in too low a gear and then going over a bump in
    the road caused an short unexpected rise in revs.
    Also very frugal: did 68 fairly enthusiastic miles on 4.66l of fuel,
    which is over 66mpg, so pretty impressive.
    darsy, Jul 10, 2005
  5. darsy
    Ben Blaney Guest
    When you got to High Beech (or wherever), did you have naked women
    approaching you, demanding sex?
    Wonder what the tank-range is.
  6. darsy
    Salad Dodger Guest
    Ah. I suspect there may be issues on Saturday morning.
    IIRC, the CBX does around 25mpg.
    Trying to keep up with you and Simon, it'll probably be into the high
    teens.
    Oh, well, it's only 150 miles from Coquelles, only need one stop.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..75939.../...19198.../..30340.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR Clues: 24 Pts: 400 Miles: 1589
    Salad Dodger, Jul 10, 2005
  7. darsy
    that's crap.
    well, 150 miles is the motorway route, I'm not intending to go that
    way.
    Don't have a route planned yet, though - do you?
    darsy, Jul 10, 2005
  8. darsy
    unfortunately not, but I was there early (10:45 or so) and there
    weren't many people about.
    Spec says 14l, so theoretically something like just over 200 miles,
    which isn't bad at all. This was A and B roads hooning, lots of up and
    down changes; I suspect at a more steady pace on fast-ish A roads, it'd
    be even better.
    The spec also says 185kg, but it feels far lighter than that.
    Did you ever notice anything odd about the clutch yourself?
    darsy, Jul 10, 2005
  9. darsy
    Salad Dodger Guest
    I imagine that it can be tempted up into the thirties, with prudence.
    Just printed one off ViaMichelin, but it refuses to avoid motorways
    completely.
    I shall have a play with Mapsource.
    | ___ Salad Dodger
  10. darsy
    Ben Blaney Guest
    That's odd. Because - and I'm sure Ace will confirm this about his
    time as owner - it happened *all* the time to me.
    When riding it back to Basel, I think I stopped about every 120-ish
    miles. I wanted to err on the side of caution, having forgotten to
    ask Bruce the tank capacity (and wanting to take advantage of the
    aforementioned naked women).
    It surged a little about 6750rpm. I thought it was the carbs, though.
  11. Blimey. I average about 50-55mpg on mine, but that's generally cruising
    it at 80+. Worst I've ever got is 42mpg. The best is about 60.
    This is partly because it's so compact. It's not a light bike, but it is
    very small. The GPZ900R managed much the same trick, actually.
    The Older Gentleman, Jul 10, 2005
  12. darsy
    it's a bloody good trick, because it even feels light when pushing it
    around.
    darsy, Jul 10, 2005
  13. You're right. One of these days I must put the thing on a weighbridge to
    see what it really does mass. The perceived wisdom (and the stats) says
    it's the same as an early GSXR750, but like you say, it feels a damn
    sight lighter.
  14. darsy
    Out of interest, what sort of tank range do you get on yours?
    darsy, Jul 11, 2005
  15. darsy
    I think the problem yesterday was with the lack of naked women, rather
    than anything else.
    darsy, Jul 11, 2005
  16. darsy
    I'll see what I can come up with; it's not so much that the 400 four is
    not motorway compatible (it is, sort of, will sit at 80-90 easily) it's
    just I find motorway biking to be horrendously boring.
    darsy, Jul 11, 2005
  17. Usually about 125-130 miles to reserve, or thereabouts.
    Worst ever was 105. This tankful will be less because I forgot to shut
    off the fuel, and it's got the usual 400 Four leaky carb syndrome.
    Wept a pint or more of fuel onto the tarmac in our office car park.
    Copincidentally, where I park is "Smokers' Corner" and one of them came
    hot-footing it to alert me before he blew himself up. :)
    The Older Gentleman, Jul 11, 2005
  18. darsy
    Salad Dodger Guest
    Oh, I concur, old bean.
    I was just thinking that we don't want to be overdoing the braking for
    junctions bit, seeing as how haven't decent set of brakes between us.
    Judicious spacing of the convoy may be in order.
    | ___ Salad Dodger
    Salad Dodger, Jul 11, 2005
  19. darsy
    <panto>
    Oh yes we have!
    ...and a sharp eye for bits falling off.
    sweller, Jul 15, 2005
  20. darsy
    antonye Guest
    Can't you just add some kind of drag-net to the last bike in
    the convoy? That way you can empty it at every petrol stop and
    sort out the bits it picked up.
    antonye, Jul 15, 2005
