Book of the Week R4
Discussion in 'UK Motorcycles' started by Grimly Curmudgeon, Oct 30, 2004.
  1. Grimly Curmudgeon
    Mark Olson Guest
    John,
    How are you converting the Real Audio stream to mp3?
    I've located Streambox VCR which allows me to capture the RA stream to
    a file, but I'm casting about for a conversion utility.
    Mark Olson, Nov 5, 2004
  2. Grimly Curmudgeon
    John Higgins Guest
    I'm using Creative Recorder to capture the mixer output and then using
    J River Media Centre to convert the resulting .wav file to .mp3.
    I'm pretty sure there are dedicated tools to capture and convert
    streaming audio but this works well enough for me. Format conversion
    utilities are 10 a penny, I'm pretty sure Winamp does it too.
    John Higgins, Nov 5, 2004
  3. Grimly Curmudgeon
    Mark Olson Guest
    I knew there were utilities that would let you tee the sound card's output
    into a WAV file, but I would like a SW utility to do it without needing
    to involve any sound hardware, also I would like to avoid needing to
    perform the capture in real time. Streambox VCR lets me download the
    stream at a higher than 1x rate.
    Ideally I'd like to be able to do it all on a Linux box, by command line
    utilities, (although I can do X-based GUI stuff) which I can control
    remotely via ssh.
  4. Grimly Curmudgeon
    Ben Blaney Guest
    This is work now. SF and NY were vacation.
    I'm almost exactly on the other side.
    Ben Blaney, Nov 5, 2004
  5. Grimly Curmudgeon
    Ben Blaney Guest
    You are my favourite UKRMer.
  6. Grimly Curmudgeon
    It's repeated on Sky Travel at 9.30pm Wednesdays and around 9pm Sundays.
    ogden, Nov 5, 2004
  7. Grimly Curmudgeon
    John Higgins Guest
    Ta, time to go searching for the torrent.
  8. Grimly Curmudgeon
    John Higgins Guest
    Not much use to me as the signal doesn't get this far, but ta.
  9. Grimly Curmudgeon
    Ginge Guest
    You're a target?
    Ginge, Nov 5, 2004
  10. It was somewhere around Barstow, on the edge of the desert, when the
    Streambox Ripper works for me, but I don't know if there's a linux
    version.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Nov 5, 2004
  11. Grimly Curmudgeon
    Mark Olson Guest
    Sadly, the Streambox Ripper 2.009 component of the SVCR 2.0 suite that I
    downloaded doesn't work. I get a big error dialog box saying it can't
    find wmaudsdk.dll. The recorder bit seems to work well, at least for
    the Book of The Week bits I downloaded from BBC Radio 4 site.
    <time passes>
    I am a TC.
    "1/3/01
    If you receive a DLL error when trying to run Streambox Ripper,
    you probably need to install the windows media support pack,
    wmaudioredist.exe, located in the streambox ripper directory.
    thanks to rvalm for pointing out this problem."
    I also found numerous complaints about missing wmaudsdk.dll and places
    where I could download it...
  12. Grimly Curmudgeon
    Mark Olson Guest
    "I was born a poor black child."
    Did you read the snipped part of my post where I admitted my thickness
    and gave the resolution to the missing DLL prob?
    Obmoto: I rode the missus' EX250 to work today as I flattened the SV's
    battery by leaving the heated grips switched on for two days[1]... the
    EX is a fun little thing, but it sure does need a good caning to move
    on[2] down the road.
    [1] Particularly embarrassing given my profession...
    [2] 90 mph on the Sigma BC600
    Mark Olson, Nov 6, 2004
