BMW wiring question
Discussion in 'Australian Motorcycles' started by CrazyCam, Nov 3, 2008.
  1. CrazyCam
    CrazyCam Guest
    Hi folks.
    Well, first the good news, the fitting of the euro-type light switch
    worked perfectly.
    I can now switch on or off the head light.
    I have also lightened the BM by a fair amount, since they seem to use
    about a squillion cable-ties per inch of cabling. :)
    Now, the question..... I want to wire up two small (35watt) lights,
    thru a switch (from an RT) to be feed from one of the "spare" fuses in
    the fuse box.
    How do I find the output from the fuse box?
    I assume I'll have to wire in a relay, have the switch trigger the
    relay, to light the lights.
    Now, I could butcher a wire which is live when the ignition is switched
    on, feed that to the switch for the lights, then down to the relay and
    have it powered straight from the battery, but surely there is a more
    elegant way of doing it?
    regards,
    CrazyCam
