BMW R1200GS
Discussion in 'Australian Motorcycles' started by Boxer, Aug 16, 2003.
  1. Boxer
    Boxer Guest
    Boxer, Aug 16, 2003
  2. Boxer
    Sutton Guest
    I like that speed limit sign and story
    Sutton, Aug 17, 2003
  3. There goes the resale on Coneheads 1150
    Al
    Alan Pennykid, Aug 17, 2003
  4. Boxer
    Boxer Guest
    You are an evil bastard Al.
    (as if the twin plug head released recently did not do it already)
    Boxer
    Boxer, Aug 17, 2003
  5. 3.5 marks and a kickin zer knutz.
    Al
  6. I like the journos predictions from a simple picture(from various sites)
    -a new frame replacing the pressed steel frame (last time I looked the only
    thing you could call a frame was cast and the rear subframe is a tubular
    structure mostly)
    -All new engine (all new is a mighty claim considering BMW dont make many
    one bike only components, the Rocker covers, heads and barrels certainly
    look new though)
    -Ozzy GS riders won't like the cast alloy wheels much (as photographed)
    Al
    (next year a TDM900 or DL1000 I think)
  7. Boxer
    Manning Guest
    If you read IK's original post, he had factored that into his calculations.
    - Manning
    Manning, Aug 17, 2003
  8. Boxer
    Manning Guest
    Shouldn't that be 3.5 euros and ein tritt in den muttern?
    Manning
  9. Knobdoodle wrote:
    I was wondering what Mike and Doug were on about.
    Pisshead Pete, Aug 17, 2003
  10. Boxer
    alx Guest
    wot! they dropped the shaft drive eh?
    alx, Aug 17, 2003
  11. Boxer
    Fwoar Guest
    Since when does a litre of Fuel weigh in at 1.09kgs??
    Unless you are quoting Oil as well which still means that the fuel is alot
    heavier than Normal
    Didn't leaded fuel go out ages ago?
    Daron
    Fwoar, Aug 17, 2003
  12. I took the difference between wet and dry weights to be 24kg (225 vs the
    fully-wet 249kg quoted by BMW themselves)
    Fuel's, what, 0.875kg/L. 22L is then 19.25kg, leaving 4.75kg to make up. The
    R259's a chunky motor. It'll hold a bit of oil, and then there's always the
    gearbox oil, the oil for the transfer box on the rear hub (don't suppose
    they call that the diff? Nah, didn't think so...), the coolant...
    My bike's so highly tuned, it needs to run heavy water in the radiator...
    Intact Kneeslider, Aug 17, 2003
  13. No coolant, they're oil-cooled. Just ask Clem.
    The rear bit is normally called the bevel drive.
    Al
    Alan Pennykid, Aug 18, 2003
  14. Bloody hell... when I'd finished digging this hole, a couple of locals came
    sauntering by and remarked "That hole's not big enough to catch out more
    than one BMW rider, mate."
    I replied, "Nah, mate. I'm looking to snare some sportsbike pilot who
    fancies himself an expert on all things motorcycle. Those BMW cunts are
    usually too wily to fall for something this obvious, and their ABS usually
    lets them steer around it even if they do get suckered in initially"...
    Intact Kneeslider, Aug 18, 2003
  15. Boxer
    sharkey Guest
    You forgot to set your X-Troll: header though!
    -----sharks (... maybe you meant the K75 G/S?)
    sharkey, Aug 18, 2003
  16. Boxer
    Of course it did; I've seen it on the shelves! Little cans with "lighter
    fuel" written on them.
    WorkDoodle
    Knobdoodle, Aug 18, 2003
  17. There's a mutant chookie with a K motor now?
  18. Boxer
    glitch1 Guest
    Strom! :)
    pete
    glitch1, Aug 18, 2003
  19. Boxer
    Cameron Guest
    Intact Kneeslider wrote:
    Only one.
    regards,
    CrazyCam
    Cameron, Aug 18, 2003
  20. I know of three...
    Postman Pat
    Pat Heslewood, Aug 18, 2003
