BMW R1100S frame failure and repairs
Discussion in 'Australian Motorcycles' started by MJT, Apr 9, 2006.
  1. MJT
    MJT Guest
    As some of you may recall (and if you're still interested) on a ride
    back from Merimbula through to Orbost in February, a mate on his BMW
    R1100S ran wide through a right hander and ended up kissing the
    embankment.
    He wasn't hurt, just annoyed. However, when we checked the bike over, we
    couldn't find a scratch on it, except for slight damage to the left side
    rocker cover which caused an oil leak.
    It was when he sat on the bike that he discovered that the sub-frame
    that supports the seat, rear cowl, etc. was broken. It had snapped at
    its mounting points on the main frame.
    It was jerry rigged with wire rope and gaffer tape to allow him to ride
    to a mate's place, 3 hours away in Gippsland (the fellow lives near
    Shepparton). They trailered it to the BMW dealer in MEL (dunno which
    one).
    BMW refused to acknowledge that it was a design problem and therefore
    wouldn't look at it under any sort of warranty. BMW said that it
    probably broke due to the crash.
    Anyway, his insurer picked up the tab.
    The dealer did what it could to help out. But it needed BMW to come to
    the party, which it didn't.
    We don't know whether he went into the corner too hot (unlikely, given
    the guy's skill - he's an ex-250cc Proddy racer), or whether the frame
    failed as he was entering the corner and that forced him wide or to lose
    control. Thing is, the lads following didn't think that he was going
    that hard at the time.
    Whatever, the impact against the dirt bank was slight. The fairings,
    etc. had no damage to them whatsoever. Only thing was the left rocker
    cover, where it furrowed through the dirt.
    The mate's not too happy about this, but at this stage he's not sure
    whether it's worth it to pursue it further - at the very least get BMW
    to refund his insurance excess.
    It's a remarkable case. I thought that BMW prided itself on its
    engineering excellence. If it (the R1100S) can't handle the weight of
    the rider and his luggage (around 110 kilos, probably), or worse, him
    and a pillion and their combined luggage, then it speaks volumes of the
    quality of build for this particular model.
    http://home.austarnet.com.au/mtaylor/r1100s.jpg is a pic of the bike
    with the seat removed. As you can see, the darn thing looks unscratched
    and that's the side that would've hit the bank.
    MJT, Apr 9, 2006
  2. MJT
    justAL Guest
    Damn that sounds like a terrible story.
    Your mate crashed and walked away from it whilst the bike suffered damage
    from the crash.
    Live with it.
    justAL
    justAL, Apr 9, 2006
  3. MJT
    atec77 Guest
    Googling R100s frame faults brings up the fact its not the first to
    break like that
    atec77, Apr 9, 2006
  4. MJT
    Will_S Guest
    hey, an early contender for fuckwit of the year
    Will_S, Apr 9, 2006
  5. MJT
    justAL Guest
    It broke and although it's a fault that has occurred on the 1100s', unless
    some past history can be found that would lead to the current failure. I
    can't see how any company would allow this particular instance a warranty
    claim.
    Was there anything that seemed out of placed with the handling, seating,
    anything before and into the corner?
    justAL
    justAL, Apr 9, 2006
  6. MJT
    Jason Woods Guest
    Using "The Long Way Round" as a reference these BMWs are good for a few
    welds :)
    JasonW
    Jason Woods, Apr 9, 2006
  7. MJT
    Boxer Guest
    The long way round subframe failure was caused by severe overloading.
    My 1999 R1100S served me well for 4 years loaded within design specs and I
    never had a problem with the subframe attachment welds, although I am aware
    of 2 that failed during accidents.
    Boxer
    Boxer, Apr 9, 2006
  8. MJT
    Gary Woodman Guest
    Ha! The company has been run by marketing people for a long time now. I'm reminded of a mate
    who split a snowflake wheel on his R100RS (yes, just like mine) crossing a cattle grid on the
    Victoria Hwy, during a BMW Australia ad campaign which featured that very model perched on a
    clifftop at Arkaroola. And of course there was the eary R1100GS model, which was notorious for
    breaking frame mounts off the gearbox. I know two people who had this happen, one twice. BMW
    wasn't the slightest bit interested, declaring that all these examples (and many others) were
    used "beyond design criteria". So I'd say without some serious legal muscle, your mate doesn't
    have a snowball's chance of a satisactory outcome.
    Gary (who buys his Beemers pre-buggered)
    Gary Woodman, Apr 9, 2006
  9. MJT
    corks Guest
    take it up with bmw germany perhaps armed with as much info as possible
    corks, Apr 9, 2006
  10. MJT
    Burnie M Guest
    And pictures on a website with a story.
    Careful about libel but don't aviod the facts.
    Send them the URL and also post it on half a dozen BMW forums
    Burnie M, Apr 9, 2006
  11. MJT
    Burnie M Guest
    Design specs can be low
    Did you know that the maximum load for a Ventura pack rack is 9 kg
    Most people use them (quite reasonabley) with double or triple this.
    Gives Ventura an easy way out of warranty claims tho.
    Exactly what is the design spec (loading) for this model and is it
    reasonable.
  12. MJT
    MJT Guest
    As I said earlier, they're not sure. The fellow can't recall whether the
    overshooting the corner resulted from say, brain fade or if the frame
    broke causing him to lose control as it happened so quickly.
    If it did, it's a scary thing. The impact wasn't that hard, otherwise
    the bike would've copped more damage. Fairing was untouched.
    The excursion was a typical, run off the road, into the drainage ditch
    and running along it as left rocker cover furrows through dirt.
    He would've been lucky to be doing any more than 40 kays at the time.
    So's he. Well, himself and his gearsack, which isn't all that much of a
    load.
    MJT, Apr 10, 2006
  13. MJT
    MJT Guest
    The insurer must've thought so too, as it covered the bike repairs
    without any mention of "discussing" it with BMW.
    Anyway, the bike's back on the road. He just hopes that it won't happen
    again. If it does, well, there may be further repercussions. He does
    have a cheap avenue of redress via the Victorian Civil and
    Administrative Tribunal (small claims tribunal).
    Actually, if you're into that sort of thing, A Current Affair has a
    segment on such tribunals this week. Might be on tonight. (I happened to
    hear about it during the Mighty Pies thrashing of Hawthorn...)
    MJT, Apr 10, 2006
  14. MJT
    MJT Guest
    If you'd read what I said, you'd see that it's unclear. One instance
    he's negotiating the corner, the next thing he's running along the ditch
    fighting to control the bike.
    That the question of whether the frame broke going into the corner and
    contributing to the loss of control, or whether he had a brain fade and
    the bumps etc. of running off the road broke it is subject to
    conjecture.
    Quite simply, they don't know. And whichever way it went down, the fact
    remains that the subframe design is being questioned as to its
    robustness. And that BMW refused to address the problem at whatever
    level is somewhat disappointing.
    MJT, Apr 10, 2006
  15. MJT
    Jason Woods Guest
    Was funny to see them unload those heavy metal panniers after the failure
    hit a 2nd time... man they had some shit in there !!!
    JasonBW
    Jason Woods, Apr 10, 2006
  16. MJT
    Rod Bacon Guest
    Do you think maybe it was broken before he went into the corner ?
    *** Only kidding !
    Seriously, given the slight damage to the rest of the bike, I reckon
    you'd stand a good chance of getting BMW to refund the excess, at the
    very least.
    Unfortunately, I can't offer any real suggestions on how to progress,
    other than directly to BMW themselves, not via a dealer.
    Rod Bacon, Apr 10, 2006
  17. MJT
    Peter Guest
    Better yet, park the bike outside the dealer on the footpath with a sign on
    it that says "this bike is a lemon".
    They will pay more attention and probably contact the owner within 24 hours
    after they are informed by the police there is nothing they can do.
    :p
    Peter, Apr 10, 2006
  18. MJT
    atec77 Guest
    That works , I did similar with a wholesale computer parts dealer , 45
    minutes I had a refund .
    atec77, Apr 10, 2006
  19. MJT
    Will_S Guest
    you forget I was only runner up to you and didnt get a title
    Will_S, Apr 10, 2006
  20. MJT
    Will_S Guest
    They should investigate a hell of a lot more then they did.
    If it was me I would give BMW some free publicity by getting some low life
    outfit like Current Affair to do a story on it
