BMW luggage
Discussion in 'UK Motorcycles' started by Simon Wilson, May 10, 2011.
  1. Simon Wilson
    Paging Salad Dodger - better cancel the order for the GoldWing's Spa.
    Lozzo
    they churn out)
    Lozzo, May 10, 2011
  2. Simon Wilson
    Gyp Guest
    If you want some pics of the stock BMW fittings, let me know as I'll be
    visiting my '81 R65RS tomorrow and can magic some up
    Gyp, May 10, 2011
  3. Simon Wilson
    Hog. Guest
    I think I'd go for minimum hassle and find OEM frames and boxes. Plenty
    around. The frames are quite unobtrusive, unlike the Krauser kit.
    Hog., May 10, 2011
  4. I didn't find the old Krauser stuff obtrusive at all.
    The Older Gentleman, May 10, 2011
  5. Simon Wilson
    Gyp Guest
    Obtrusive, maybe not. **** ugly, definitely.
    If the panniers are on the bike all the time then it won't make any
    difference, but if you run with the panniers off then I'd go with the
    BMW frames every time
    Gyp, May 10, 2011
  6. Simon Wilson
    Hog. Guest
    Swot I meant
    Hog., May 10, 2011
  7. Simon Wilson
    Gyp Guest
    ****. I'm agreeing with Hog again. Nurse! Nurse!
    Gyp, May 10, 2011
  8. <snip>
    You should have received the set for perusal by now.
    If you haven't figured it out: the lower brackets fix to the footrest
    bracket or similar. The upper ones to the top shock mounts. The back
    brackets mount to the tail light/number plate bracket and are held
    together with a short bolt, nut, and a couple of large washers to clamp
    them up. Everything's very adjustable.
    The Older Gentleman, May 15, 2011
  9. Simon Wilson
    Simon Wilson Guest
    Got them ta. Too late/dark/knackered to look this evening, will try
    tomorrow. Thanks for the info tho because it wasn't obvious which bit
    goes where.
    Simon Wilson, May 15, 2011
