BMW K1200S mini review
Discussion in 'UK Motorcycles' started by Spete, Jul 6, 2005.
  1. Spete
    Spete Guest
    Looks:
    - very nice, although I'm not too sure about the rear-end...
    - I like the blue and white colourscheme
    - Sounds very nice
    - Does look very long
    Usability:
    - Sidestand would not be of much use in a lot of streets in the UK. A
    downslope of more than 1 degree will have the bike fall forwards and result
    in a quite a bruise on the lowerleg, trying to keep it up.
    - It's a bit like a very overpriced ZZR, can happily ride it for hundreds of
    miles, due to the riding position. Seating position is just good enough for
    me, higher than the ZZR. Not too sure about the shape of the seat, might get
    uncomfortable after a few hundred miles.
    - It does have a bit of torque, before you know it, you're doing xxx km/h
    and seeing one of the grey photograph type thingies will have you test the
    ABS. Feels strange and there are supposedly some issues in extreme
    conditions with the ABS, ie: not working.
    - Quite a bit of info in the screen. Gears are indicated. When you're
    approaching 65 km of fuel left in the tank, it will tell you and count down,
    which is nice....or disconcerting :).
    - Can't get used to the indicator buttons, especially the cancel button.
    Would I buy it? Probably, if it weren't for the extreme high price-tag.
    Basic price is ?17.700.. Can nearly buy two SV1000SZ's in the proper Suzuki
    coulour for that. So the next testride will more than likely be on the
    SV1000.
    Spete, Jul 6, 2005
  2. Spete
    Spete emerged from their own little world to say
    It becomes intuitive: so much so that you get disorientated on other bikes
    :S
    wessie, Jul 6, 2005
  3. Spete
    I found that day to day this is true. However, in an emergency the old
    habits can resurface.
    I recall when overtaking a line of cars, perhaps a tad too fast, a car
    suddenly turned right in order to do a U-turn. I hit the brakes and
    horn... and got silence. When my past life stopped flashing before my
    eyes, I found that I had given the dozy twat a damn' good left
    indicating.
    Pip Luscher, Jul 6, 2005
  4. Spete
    Pip Luscher emerged from their own little world to say
    I've done that on a couple of occasions.
    Some people have gone as far as swapping the wires between horn & indicator
    as it is easier to hit the orange flappy paddle in a hurry. When indicating
    you tend to be more deliberate so they find hitting the higher button is
    straightforward.
    Personally, I just adapt, eventually. My early work history involved
    driving hire vans and all sorts of cars in a Fiat garage so I have always
    been accustomed to turning left accompanied by screeching wiper blades.....
    wessie, Jul 6, 2005
  5. It's a bloody nuisance at times. After years of driving boxes with left
    stalk indicators and lights, this SOJC has the wipers on the left. A
    year on I'm still occasionally flashing someone with my wipers.
    Grimly Curmudgeon, Jul 6, 2005
  6. Spete
    Fr Jack Guest
    I'm pretty sure a lot of Harleys use a similar setup...
    Cheers!
    Fr Jack
    96 Tiger.
    FRJACKUKRM AT GMAIL DOT COM
    skype: fr.jack (without the dot)
    Open up your eyes, just to check that you're asleep, again
    Fr Jack, Jul 7, 2005
  7. Harleys used to have a system whereby the indicators only kept flashing
    as long as you pressed the button on either bar. If you were trying to
    blip the throttle, do a downchange, use the clutch, brake, etc at the
    same time, it was impossible to use.
    The Older Gentleman, Jul 7, 2005
  8. I have problems with the DT, as it's pre- press-to-cancel (but
    also thankfully pre- Yamaha's auto-cancel) and that action is engraved
    into my synapses. I think I might have caused some mayhem on the M25
    when I left the indicators running...
    GSX600F, RG250WD, DT175MX "You Porsche. Me pass!" DoD #484 JKLO# 003, 005
    Dr Ivan D. Reid, Jul 7, 2005
  9. Spete
    Steve Parry Guest
    Verdigris fumbled, fiddled and fingered:
    My F650 has a standard Jap style indicator switch (in fact I think
    theyre Honda switches) and the K has the one each side BMW ones, and
    true enough it takes some thinking about at times.
    Steve Parry
    K100RS SE & F650
    and a 520i SE Touring for comfort [temporarily scarred]
    (not forgetting the SK90PY)
    http://www.gwynfryn.co.uk
    Steve Parry, Jul 7, 2005
  10. Spete
    My SOJ4x4 is the wrong way round too. I too sometimes wash my
    windscreen at people.
    Pip Luscher, Jul 7, 2005
  11. Spete
    Eddie Guest
    I tend to find that flashing my headlights is remarkably ineffective at
    clearing the windscreen.
    Eddie, Jul 7, 2005
  12. Spete
    Catman Guest
    I do that when I was spwaaping from car to car. The Sprint has the horn on
    the stalk ffs. It was evens all around if someone would get washed,
    beeped, flashed or indicated at..........
    www.cuore-sportivo.co.uk
    Catman, Jul 7, 2005
  13. Spete
    Dr Ivan D. Reid says...
    I never had a problem with the auto-cancel on my RDs.
    Lozzo, Jul 7, 2005
  14. Spete
    Steve Parry Guest
    Lozzo fumbled, fiddled and fingered:
    nor I
    Steve Parry
    K100RS SE & F650
  15. I never, ever understood why Yamaha ditched those self-cancellers.
    Simple, and they worked.
  16. They fitted them to the whole range, I think. I certainly had them on
    the XS750 and 250 - I'm not sure about the 650. Quite reliable.
    Grimly Curmudgeon, Jul 7, 2005
  18. Just about every road (not dirt) Yamaha from 250cc upwards had them,
    yes. They were perfect: they always seemed to cancel at exactly the
    right moment, whereas the self-cancellers on my old Kawasaki GT750 never
    stayed on for long enough.
