BMW K100 Help Wanted.
Discussion in 'Classic Motorbikes' started by Dave Eades, Dec 13, 2003.
  1. Dave Eades
    Dave Eades Guest
    Well, the MOT is due next week, and my speedo is still not working.
    I read on the internet that this is a common problem on K100's and there is
    even a fix (which I have tried, but it didn't work)
    The rev counter, all panel lights including fuel level indicator etc are
    working, but the speedo and trip meter just refuse to work.
    Has anyone got any ideas, better still has anyone got a K100 speedo they
    want to sell?
    Regards
  2. Dave Eades
    I'm sorry, but is there any connection whatsoever between these two
    statements?
    Pip, Dec 13, 2003
  3. Dave Eades
    Steve Parry Guest
    http://www.ibmwr.org/ktech/speedo-repair3.shtml
    http://www.ibmwr.org/ktech/k-instrument-tips.shtml
    http://www.ibmwr.org/ktech/speedo-repair1.shtml
    http://skylands.ibmwr.org/tom/tech/speedo/speedo.html
    hth
    Steve Parry
    http://www.gwynfryn.co.uk
    http://wrexhamseals.tripod.com
    Steve Parry, Dec 13, 2003
  4. Dave Eades
    Dave Eades Guest
    Yes!
    I've been putting off the "fix the speedo" problem.
    Now the MOT is due and it won't pass with a fucked speedo.
  5. Dave Eades
    Why ever not? I don't recall the speedometer being a testable item,
    and I have never seen one tested.
    Pip, Dec 13, 2003
  6. Dave Eades
    deadmail Guest
    As long as the needle isn't stuck there won't be a problem.
    The K100 speedo will either be:
    - The pickup in the bevel box
    - THe connection from the pickup to the loom
    - The connection at the base of the clocks
    - The connections between circuit boards in the clocks.
    Try to fix by cleaning them all up, give up and fit a cycle speedo...
    deadmail, Dec 13, 2003
  7. Dave Eades
    ts Guest
    The speedo-, odo- and trip-meter work by picking up a signal from a
    magnet in the final drive gear box. You can see the lead emerging from
    the top of the drive box, and continuing forwards on top of the swing
    arm. Under the right side cover is a connector, from which the lead
    continues up to the instrument cluster. I would check the integrity of
    this circuit before thinking of replacing the instruments.
    Alternatively, you could fit a cycle computer (e.g. Sigma 800 or Targa
    [1]), which besides the mentioned functions also indicate max and
    average speed, and can also be set to indicate km/h if you also venture
    onto the continent. An easy £20-25 DIY job. Instructions on how to fit
    one are also posted somewhere on the www.ibmwr.org/ktech/ pages. Search
    for <sigma>.
    While at it, you may also consider fixing your signature separator as
    well - which should read "hyphen hyphen space". Almost equally important
    for some Usenet-users as a MoT for the wheels.
    [1] If considering other cycle computers, make sure they can record
    sufficient top speeds. The mentioned Sigmas read up to 300 km/h.
    Best of luck with the fixes!
    ts, Dec 13, 2003
  8. Dave Eades
    I'd ask for him to show you the requirement in his manual.
    The only problem I can think of is the need to see the odometer. Am I
    right in thinking, the digital type, if it doesn't work it doesn't show
    the mileage?
    sweller, Dec 13, 2003
  9. Afaik, the odometer reading isn't a requirement. Yes, there's a place
    for it to be written down, but a working odometer (or a missing one) is
    neither here nor there.
    GS 850 x2 / SE 6a
    SbS#6 DIAABTCOD#16 APOSTLE#16? FUB#3
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Dec 13, 2003
