BMW F650CS and fuel
Discussion in 'Australian Motorcycles' started by Tim, Oct 6, 2003.
  1. Tim
    Tim Guest
    I just had a look at this one on the BMW web site and it says the
    F650CS uses only 3 liters per 100Km. For a 15 liter tank that will
    give about 500Km range.
    Sounds good on both fronts. Can anyone confirm from experience.
    Tim.
    (BMW R1150GS)
    Tim, Oct 6, 2003
  2. Tim
    Smee Guest
    that would be full country cycle at 90 kmh not 110 kmh
    those figures are not entirely accurate as a lot depends on your riding habits.
    Smee, Oct 6, 2003
  3. Tim
    Manning Guest
    We had an '01 F650 GS (same engine) and got nothing like that - more around
    360 kms, or a shade over 4 L /100 kms.
    Manning
    Manning, Oct 6, 2003
  4. Tim
    Tim Guest
    BMW was quoting about 3.5L/100 Km for the small GS.
    It could have different gearing/aerodynamics to cause that difference
    since the engine is the same.
    FWIW I get on my big GS around 4 @ 100kph and about 5 in the city or @
    120kph
    Still if they get 3 on the highway thats pretty good I think?
    Tim.
    Tim, Oct 6, 2003
  5. Tim
    Stef Guest
    Fuel consumption figures quoted by OEM's are often understated - the
    testing procedure isn't realistic. How does the gearing ratios of the
    CS compare to the GS?
    My '99 Pegaso gets 5L/100km cruising at 110km/h, and 5.5L/100km
    fanging. 21L tank - good for almost 400km.
    Stef
    Stef, Oct 7, 2003
  6. Tim
    glitch1 Guest
    Yeah, theoretically :)) (and practically, most times)
    Remember of being on Mick's back to carry extra petrol for his Across on the
    6-peaks #2 and the first time he used it was when I ran dry, hehehe.
    Fanging the Peg (in the good old days when I didn't know what fear was :))
    with a weeks worth of gear on the back, she ran dry in the mountains after
    290km.
    Bone-dry that is...
    Musta been a load of shitty fuel from the last fill-up, I guess, mostly
    water :))
    cheers
    pete
    glitch1, Oct 7, 2003
  7. Tim
    Nev.. Guest
    ....and the second time was when the 23 litre tank of my XX ran dry, hehehe
    Nev..
    '03 ZX12R (almost)
    Nev.., Oct 7, 2003
  8. Tim
    Frank Warner Guest
    BMW use a DIN standard to test to, so comparing the bm bikes is very
    instructive. If other manufactures were to test (to the same standard)
    then we could compare their products ... of course there is no incentive
    for them to do so ... unless you ask when buying.
    The point of the standard to to get everyone doing the same thing so you
    can compare. True the standard won't represent you in real life... but
    them we are all different.
    Frank Warner, Oct 7, 2003
