BMW electrical problems.
Discussion in 'Australian Motorcycles' started by DaZZa, Feb 17, 2005.
  1. DaZZa
    DaZZa Guest
    Any BMW gurus out there?
    I am having a completely frustrating electrical problem with my 1988
    K100RS which is simply baffling me - so, as a last resort before
    outlaying the vast amounts an auto electrician will likely cost me, I
    thought I'd ask the collected wisdom if anyone had seen similar
    problems.
    After an indeterminate but varied period of riding, I get the following
    symptoms.
    1) Indicators stop working, or work erratically - for example, trying to
    turn on the right hand indicator may result in both indicators flashing,
    al-la hazard lights, or nothing flashing, or occasionally the LEFT
    indicator flashing.
    2) Horn doesn't work.
    3) Headlight doesn't work
    I can't see the tail/braoek light, as it always happens when I'm riding.
    The bike, however, keeps running, and the engine seems fine. However, if
    I stop the engine by stalling or turning it off {key or kill switch},
    the starter motor will not turn over - I hear a loud whiring from under
    the tank which I assume is the fuel pump or similar, but nothing from
    the starter. I can, however, start the bike by bump starting it.
    I have blown no fuses or bulbs recently, and when the stuff works it all
    works perfectly.
    My initial thought was that the battery had gone bad, so I eliminated
    this as a suspect by the simple expedient of replacing it with a brand
    new one. No joy.
    I've looked at the circuit diagram fromt he Hayes manual until I'm blue
    in the face and, beyond the battery, I can't see anything obvious that
    would stop all the bits listed from working at the same time. It *seems*
    to be related to heat somehow - the hotter the day, or the more
    stop/start traffic I get stuck in, the quicker the problem occurs.
    Has anyone come across this problem, or a problem with similar symptoms
    before and could shed some light on which bit I should look at? Or do I
    just bite the bullet & try to find an auto electrician to look at it for
    me?
    DaZZa
    DaZZa, Feb 17, 2005
  2. DaZZa
    Moike Guest
    I'm guessing a bit, most of my experience is with boxer electrics.
    I'd suspect an earthing problem. A dodgy connection might fail
    intermittently in an unpredictable but heat/moisture-related way.
    Probably in the way the instrument cluster/fairing/handlebar switches
    are earthed. There is probably a single earth return point for the part
    of the wiring harness that services the 'front' of the bike.
    This would explain the haphazard indicators, horn and headlight. The
    starting issue may be because one of the sensors that govern starting
    (sidestand switch? clutch switch, gearbox switch? uses the same earth
    return point.
    In your wiring diagram, see if you can detect a likely candidate point,
    then dive into the fairing/headlight area and look for a suspect
    connection. You may need to pull apart, clean and replug a few
    connectors. Do one at a time.
    It may be the battery earth connection, but since the ignition and fuel
    pump work, I doubt it.
    BMW have a habit of making 'odd' earth return arrangements.
    I think on some models, they can rely on a good electrical path through
    the steering head. An earth bypass wire may be called for.
    Have a look at the forum at http://www.motobins.com/
    It has a good signal to noise ratio, and a population of BMW owners
    skilled at diagnosing such difficulties.
    Moike
    Moike, Feb 17, 2005
  3. In aus.motorcycles on 17 Feb 2005 02:04:59 GMT
    My instant suspicion is a bad earth, track 'em all down and clean 'em
    all up.
    On a Guzzi, the startermotor no go is usually bad power to the relay or
    less usually bad relay.
    If you can't find it, try John at MotoCiclo in St Peters for electrical
    work, if he can get Brit and Italian electrics working, German ones will
    be nothing! 9557 7234. You are in Sydney or near to aren't you?
    Zebee
    Zebee Johnstone, Feb 17, 2005
  4. DaZZa
    atec Guest
    city ?
    I have a manual some where ( Im happy to say my k100 runs fine)
    check the conectors , plugs tend to corrode
    atec, Feb 17, 2005
  5. I concur with all previous advice. Fault will most likely be at a
    termination ( earth points. indicators, plug connectors) or where isulation
    has rubbed through. You will have to thoroughly inspect the wiring from
    front to back. Be patient and take your time....have a play and leave it for
    a while and come back to it, otherwise it will drive you nuts!!!
    Cheaper for you to spend a few hours on it than pay an auto lecky......he
    will just be doing the same thing anyway...
    Stephen
    Stephen Robinson, Feb 17, 2005
  6. DaZZa
    Johnnie5 Guest
    have you got the trusty multi meter out as yet for investigations ??
    that would be the 1st thing to be doing
    Johnnie5, Feb 17, 2005
  7. DaZZa
    Conehead Guest
    With anything electrical (since a problem with a Fairlane), I pull out all
    fuses & put them back, remove/unplug all relays & put them back, wriggle
    everything that can be wriggled that looks electrical, and find the earth
    and check that it's clean & tight.
    Worked every time (except once). I can't get the light behind my odometer
    to work on the EF Fairmont, and I'm too lousy to go to a sparky with such a
    trivial thing.
    Conehead, Feb 17, 2005
  8. DaZZa
    Johnnie5 Guest
    snip
    i think you might find that the light is a surface mount LED
  9. DaZZa
    Conehead Guest
    LED?! That would be a "LIGHT emitting diode", I presume J5. It may still
    be a diode, but it doesn't emit light, therefore it still doesn't work,
    whatever I call it (or whatever you call it).
    Having said that, do you have any idea what to do about it, or is your
    repertoire restricted to identification?
  10. DaZZa
    Maybe it's DED
    (Dark Emitting Diode)
    Clem
    Knobdoodle, Feb 17, 2005
  11. DaZZa
    Johnnie5 Guest
    snip
    yep thats about it
    it is prob a LED that is broken but of course it could just be a normal
    globe
    remove the intrument cluster and have a look if there is a globe to be
    changed
    I havent pulled one of those ford dash apart before but i am guessing it is
    a LED based on the
    fact that the EF has a digital odo
    Surface mount LEDs are available at Jaycar or to have it done take the PCB
    to a guy
    that does mobile phones , you know the dodgy asian guys that change LEDs to
    spanky blue
    ones , provided that its an LED and could be changed easily
  12. This might seem strange cause it did to me when the same happened.
    It's the starter motor brushes, get them replaced. Quite common on a K100,
    you can buy orig parts or most auto elecs can make brushes out of generic
    parts.
    Alan
    Alan Pennykid, Feb 17, 2005
  13. DaZZa
    Moike Guest
    Not saying I'd disbelieve you Al. I'd wager you've forgotten more than
    I have about bimmers. But how on earth do starter motor brushes cause
    the indicators to go feral?
    Moike
    Moike, Feb 17, 2005
  14. I know they are all saying bad earth, and to a certain extent that is true
    as many circuits on the K seem to rely on the starter for earth. But trust
    me, just take the starter motor out and have a look at the brushes, it is
    the problem. I've seen it already on two of the three K100s I've had(high
    mileage both of 'em). The reason some of your electrics are fading in and
    out is the worn brush making an intermittent contact with the armature, give
    the bike a big rev and sometimes some of kicks back in momentarily(vibes).
    There should be one long brush and one short brush, not even length. The
    long one wears out first.
    Al
  15. Thats why it was such a confusing problem Moike, it doesn' make any sense at
    all. They earth some circuits through the starter for some stupid reason,
    that' why it has a particularly long brush on that side, it's sacrificial.
    Like I said, it' happened to two of my own bikes, first time it drove me
    nuts, I was chasing connections etc, then I tapped the starter with a
    screwdriver and the lights came back on, that led me to further
    investigation. Second time it happened, I knew straight away, but had to
    stop on the central coast overnight due to no lights to get home.
    Al
  16. DaZZa
    Fred Guest
    If you havnt pulled one apart why talk shit then?
    Its a normal incandesant globe (plug in type) that backlights an LCD
    display.
    Fred, Feb 17, 2005
  17. It's the starter motor brushes, get them replaced. Quite common on a
    AAAHHH YES!!...that happened to me once
    The reason behind it is that when the starter is turning there is no
    earth through it for ancillary ccts...so headlights and stuff that you
    don't want on while cranking the engine.....aren't
    And when the brushes are worn enough for it to be a problem, the bike
    won't go
    I recall twas quite easy to fix, and not expensive...but an absolute
    bugger of a thing to diagnose
    Now, does anyone know about addressing the fast counter driver on a
    Festo 640 PLC?
    fulliautomatix, Feb 17, 2005
  18. DaZZa
    Johnnie5 Guest
    this is the internet its full of shit
    easy fix then
  19. DaZZa
    Moike Guest
    Clamp a set of vice-grips on it just tight enough to slow it down. Be
    careful, don't overdo it.
    Moike
    (festo what?)
    Moike, Feb 17, 2005
  20. DaZZa
    smack Guest
    no no no
    you address it same as you would address a golf ball. Wearing funny pants(
    and socks that only Pat would wear)
    smack, Feb 17, 2005
