Bloody computers
Discussion in 'UK Motorcycles' started by DangerScouse, Jan 10, 2004.
  1. DangerScouse
    DangerScouse Guest
    Right, before I go taking the other computer apart to try and find out
    what's wrong with it, can any of the enlightened IT buffs here suggest
    why a computer would go 'Phffft' and die (no smoke or smell of burning
    though). It's not the fuse in the plug, that was the first obvious port
    of call.
    It was built about 12 months ago, as the processor was a faster one than
    the previous the fan was also replaced as the original would not have
    been sufficient to cool the processor.
    It's been working fine until about 1 hour ago when it just decided to
    die..and I won't get *any* peace until it's working again.
    Lesley
    ZXR400SP
    "Not bad for a Scouser"
    SBS#11[with oak-leaf cluster]
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    Un-cork me to reply
  2. DangerScouse
    Sparkes Guest
    if it has packed in completely then it is most likley the power supply. The
    only way to tell is to open it. Send me a mail if you need help with how to
    test it
    Sparkes, Jan 10, 2004
  3. DangerScouse
    Ben Guest
    PSU going titsup. If you got a faster process and a bigger fan it may
    be that your old PSU wasn't powerful enough.
    Ben, Jan 10, 2004
  4. DangerScouse
    Catman Guest
    What he said: case=no lights, no fans inc PSU
    case=fan, some lights, no boot then CPU = fubar / unseated
    You might have a case of thermal creep where plugs can work their way
    out of their sockets. If the PSU connector has come loose, it will
    not sense the MOBO, and therefore not turn on (making it seem dead)
    The same *can* happen to the CPU though it's bloody unlikely. This
    can cause symptom set two.
    Top off, check all the plugs. Try to restart.
    It's always worth unplugging it for 10 mins or so. Sometimes helps.
    PSUs these days are really cheap though. I just got a 450w job for
    £15
    Alfa 116 Giulietta 3.0l. Really, Sprint 1.7
    www.cuore-sportivo.co.uk
    Catman, Jan 10, 2004
  5. DangerScouse
    DangerScouse Guest
    Ben says...
    Ta Ben, the original system was AT, we also got an ATX case complete
    with PSU when we got the other bits. Could be that though, and as luck
    would have it I have a spare PSU sitting around that I can use, if that
    doesn't work..
    That would certainly be easier than farting around with the old AT
    system replacing bits to get it up and running again.
    Lesley
    ZXR400SP
    BONY#54P BOB#18
    Un-cork me to reply
  6. DangerScouse
    Dan White Guest
    Was it a 'Phffft' or more like a 'Pop'? There was a *huuuuge* number of
    dodgy capacitors[1] made in the last couple of years, and they have been
    exploding for the last several months[2].
    On any modern system the computer will shut itself down if the motherboard
    detects the processor is overheating, so I doubt it's that.
    Well the fact that it made a noise and then died would imply a larger
    hardware problem (ie, not a chip blowing up). There is actually another fuse
    inside the power supply, so it could have been that which blew.
    You're not having electrical storms at the moment by any chance. I'd never
    known of it happening to anyone before last year, but then two people I know
    ended up with fried motherboards (and dead telephones) after a lightning
    strike.
    [1] Google for "capacitor stolen formula" for the whole hilarious story...
    [2] Electrolyte boils and pops the cap off the end IIRC.
    Dan White, Jan 10, 2004
  7. DangerScouse
    DangerScouse Guest
    Sparkes says...
    Thanks Steve. I'm not comfortable poking around with electrical stuff
    though so I think I'll plump for the chicken way out and see if the PSU
    we have spare gets it going.
    Lesley
    ZXR400SP
    BONY#54P BOB#18
    Un-cork me to reply
  8. DangerScouse
    Dan White Guest
    I have a spare ATX PSU sat here, but unless you're anywhere near Bristol
    it's probably cheaper to get a new one than have me post it!
    If you have to get a new one, go for a minimum of a 350W PSU.
  9. DangerScouse
    DangerScouse Guest
    Dan White says...
    As luck would have it, the spare PSU got it working, no idea what the
    fault is with the original one though, as the PSU fuse doesn't appear to
    be foobarred.
    Cheers all.
    Lesley
    ZXR400SP
    BONY#54P BOB#18
    Un-cork me to reply
  10. DangerScouse
    as Dan says, the phht was prolly a capacitor ejecting gas - have a look for
    the telltale white powdery stuff scattered about the place. It's aluminium
    oxidised during the explosion.
    the extra current being drawn was probably enough to take out one of the
    voltage regulators on the output side whereas the fuse is on the input side
    of the PSU
    wessie, Jan 10, 2004
  11. DangerScouse
    gomez Guest
    Is this the same batch/source of capacitors that have been responsible
    for Sky digiboxes slowly dying by creeping paralysis?
    gomez, Jan 10, 2004
  12. DangerScouse
    DangerScouse Guest
    wessie says...
    Hmm, I can't see any white powdery stuff, but there is a light brown
    patch on the top of the PSU halfway between the capacitors and the fan,
    don't suppose it would be unreasonable to assume that that is it?
    Ta.
    Lesley
    ZXR400SP
    BONY#54P BOB#18
    Un-cork me to reply
  13. DangerScouse
    Dan White Guest
    Very possibly.
    To summarise from memory: Scientist working for component company "A"
    defects to company "B" and nicks copies of the secret formula for their
    capacitor electrolyte.
    Unfortunately he neglects to take a copy of the formula for the stabilising
    agent for the electrolyte. Company "B" churns out *hundreds of millions* of
    said capacitors. Several months later, devices where the power is on
    continuously began to fail, followed by less frequently used devices.
    Good writeup in:
    http://www.spectrum.ieee.org/WEBONLY/resource/feb03/ncap.html#f1
  14. DangerScouse
    Dan White Guest
    Could well be. The electrolyte is like a brown cruddy substance, and the
    dodgy capacitors were typically the larger ones involved in voltage
    regulation/smoothing.
  15. DangerScouse
    DangerScouse Guest
    Dan White says...
    Looks like that's the problem then. The replacement PSU is older than
    the original, but looking at the write-up on the problem then it's
    possible that this one could go the same way at some point.
    Does it make any difference if the machine is on 24/7 or not?
    Lesley
    ZXR400SP
    BONY#54P BOB#18
    Un-cork me to reply
  16. DangerScouse wrote:
    Brown stuff spread out around the fan?
    I think you can guess what happened!
    While we've got the 'pooter experts reading,
    Anyone know of a "TV remote control" emulator that will
    run on a laptop with infrared port?
    Old Fart at Play, Jan 10, 2004
  17. DangerScouse
    Ben Guest
    I've got some software on my Ipaq called Nevo that does that.
    However, they make a big deal about the fact that the Ipaqs IR made a
    lot stronger in order to broadcast over a decent distance. A laptop
    IR may not be as strong as it's only designed to be used at short
    range.
    Ben, Jan 10, 2004
  18. DangerScouse
    Catman Guest
    Normally about 3 ft IME
  19. While recharging a flash gun in Spain many years ago[1] there was a
    mains spike and the main capacitor went all over the hotel bedroom. You
    would not believe hat a mess it made.
    [1] When you charged the flash battery the gun went live.
    Mick Whittingham, Jan 12, 2004
  20. DangerScouse
    Catman Guest
    *I* would
    I built some perspex fronted speakers some years ago. One memorable
    evening, they decided that the 110W RMS amps were too mcuh, and blew
    the caps in the cross over. Oh boy
    Catman, Jan 12, 2004
