Blocked Yamaha FZR600 - info needed.
Discussion in 'Motorbike Technical Discussion' started by dadiB, Nov 16, 2004.
  1. dadiB
    dadiB Guest
    Hi everybody
    I have recently bought Yamaha FZR600, year 90, type 3HF
    Unfortunatelly it is a version designed for Switzerland, therefore its power
    is blocked for 36.10 kM.
    Do you know what kind of blockage was used in that particular type of the
    bike?
    Is it just carburators, CDI module or something more?
    Thanks in advance for any info.
    Regards from Lausanne (Switzerland)
    Darek
    dadiB, Nov 16, 2004
  2. dadiB
    dadiB Guest
    I know about that, but as far as I know those are 3 possibilities:
    - simply - reduction on the carburetors,
    - more complicated - digital reduction (via CDI ignition module),
    - and the worst one, within the engine (unfortunatelly I don't know how to
    describe it in english)
    I hope that it is not so bad, but its always better to ask :)
    Thanks a lot!! And welcome everybody!
    Sorry, its was my typing mistake, it should be 36.10 kW (about 52 horse
    power).
    This motorcycle, while its unblocked, should have ~ 85-95 horse power.
    With beste regards
    Darek
    Suzi VS800 & Yamaha FZR600
    dadiB, Nov 16, 2004
  3. dadiB
    tallbloke Guest
    May be relevant maybe not, but found this for FZR400RR
    "Speed restricted to 115 but you can derestrict em by removing the tab in
    the speedometer that passes through a block at 115ish on the back of the
    unit but dont remove the tab that blocks it at0mph or the bike will go
    real slow. this method saves 60 notes on black boxes. in all I loved this
    bike and only got rid of it because I'd killed it from too much street
    extreme ."
    tallbloke, Nov 16, 2004
  4. Honda chose that route when the detuned the brilliant 17bhp CB125T of
    the mid-to-late 1970s into the dreadful 12bhp CB125 Super Dream.
    As well as smaller carbs and silencers that were just about solid
    baffle.
    The Older Gentleman, Nov 17, 2004
  5. The UK market FZR1000 of that sort of age used restrictor plates between the
    carburators and cylinder heads, I think these were part of the gasket. You
    could remove the restriction "simply" by taking off the carbs and cutting
    the restrictors away. Not difficult, just tedious. The carbs were already
    correctly jetted, just restricted n how much air they could flow.
    SteveM
    Stephen Malbon, Nov 17, 2004
