Blimey...
Discussion in 'UK Motorcycles' started by Lady Nina, Nov 29, 2004.
  1. Lady Nina
    Muck says...
    My tester doesn't even like touching my CB, he makes me test it myself
    while he watches over me.
    Lozzo, Nov 29, 2004
    #41
  2. Lady Nina
    Salad Dodger Guest
    Mine roadtested the KH500, but not as part of the test.
    It was a condition of the test - and he still failed it.
    | ___ Salad Dodger
    _/_____\_ GLXR1500SEVRRSP/CBR1100XXX/KH500A8/TS250C
    |_\_____/_| .....73063...../..17090.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 29, 2004
    #42
  3. Lady Nina
    Salad Dodger says...
    That's fucking ridiculous. 2K for a headlamp. I know they're big but
    that's outrageous.
    Lozzo, Nov 29, 2004
    #43
  4. Lady Nina
    Having sat on your CB, I can well understand that. :)
    Muck, Nov 29, 2004
    #44
  5. Lady Nina
    Salad Dodger Guest
    They were only around £450-500 to replace a broken one, though. If you
    could present the original.
    | ___ Salad Dodger
    #45
  6. Lady Nina
    Condition of the test? Was it rebuilt from a crash or something?
    Muck, Nov 29, 2004
    #46
  7. Lady Nina
    Salad Dodger Guest
    No - he just wanted a go in it.
    | ___ Salad Dodger
    #47
  8. Lady Nina
    This is the old "We won't supply parts for imports" cartel in operation?
    Lozzo, Nov 29, 2004
    #48
  9. Lady Nina
    Salad Dodger Guest
    I couldn't possibly comment.
    Yes.
    | ___ Salad Dodger
    #49
  10. Lady Nina
    Oh to be an MOT tester.
    Muck, Nov 29, 2004
    #50
  11. Lady Nina
    Greybeard Guest
    Ah, it should have been underwired, that'd have sorted it ;o)
    Greybeard, Nov 29, 2004
    #51
  12. If you have a 'flat dip' beam, i.e. without the tick, then that is
    acceptable. Most US spec bikes have a flat dip.
    If the 'tick dip' goes the wrong way, i.e. up on the right as viewed
    from on the bike, then that is not acceptable.
    ColonelTupperware,
    spouting bollocks on Usenet since 1997
    Usenet FAQ at
    http://www.its.caltech.edu/its/services/internetapps/news/news2.shtml
    UPCE FAQ at http://upce.org.uk/ UKRM FAQ at http://www.ukrm.net/faq/
    Colonel Tupperware, Nov 29, 2004
    #52
  13. Lady Nina
    Ben Blaney Guest
    I didn't think it would take 6 minutes for someone to pick up on the
    twin usage of the word "bike".
    UKRM really is going downhill.
    Ben Blaney, Nov 29, 2004
    #53
  14. Lady Nina
    careful, Ben.
    darsy, Nov 29, 2004
    #54
  15. Lady Nina
    tallbloke Guest
    C*nts the lot of 'em.
    tallbloke, Nov 29, 2004
    #55
  16. Lady Nina
    Wondering where on earth Ace got that idea.
    The last time I was involved with an MOT and a road test was with a
    Morris Minor van. The tester took it out for a spin with decelorometer:
    "because it's kinder to 'tired' brakes"
    sweller, Nov 29, 2004
    #56
  17. Lady Nina
    That's my experience.
    Usually he sets it up with the owner on the bike.
    #57
  18. Lady Nina
    Right hand dip headlamps can be temporarily altered for use in the UK by
    fitting masks or converter kits which remove the beam 'kick-up' to the
    right.
    A headlamp altered in this way is *not* *a* *reason* *for* *rejection* if
    a. the headlamp aim is not rejected for the reasons listed under diagram
    1 (except that the top of the beam image will be a straight line)
    b. the light output is not unduly
    reduced - not usually a problem with commercially produced kits
    c. the mask or converter is securely attached
    #58
  19. Lady Nina
    _Ginge Guest
    But, if it were to be taped in such a way as it again became flat rather
    than a tick, it would become acceptable.
    _Ginge, Nov 29, 2004
    #59
  20. Lady Nina
    Lady Nina Guest
    The issue seems to be that it is completely flat, not that it is a
    right hand dip. Anyway will be sorted tomorrow.
    Ta. Anymore problems and I'll wave the computer under their noses.
    #60
