Blimey
Discussion in 'UK Motorcycles' started by Ben, Jan 6, 2004.
  1. Ben
    Ben Guest
    Cool. Weather looks dry at the moment, so I'm on. Morning or
    afternoon? And are you happy with just a simple potter down to
    Stratford?
    Aye, more the merrier to witness me being slower than Ginge.
    Jon, Daz, you fancy it?
    Stick it on for a couple of days an it'll be fine.
    You can't bump start it with a totally flat battery as there is no
    power to the injectors and therefore no fuel.
    You would have been able to jump start it off your car though.
    Should do. Battery is pretty new.
    Ben, Jan 7, 2004
    #41
  2. Ben
    BRC Guest
    !!! Noo, Moosey must have bike
    BRC, Jan 7, 2004
    #42
  3. Ben
    Steve P Guest
    Morning would probably be better for me but either to be honest.
    Stratford is fine as I won't have *ages* but a couple of hours would be
    very nice.
    I give you 10 minutes before you are gi'ing it some :)
    I did get it to start but then it cut out while I was putting my gear on
    (lack of fuel I guess). It then half turned over before "bzzzt"ing
    again. At this point I was too knackered to be arsed bump starting it
    again. I'm going home at lunchtime to give it another go and just check
    there isn't anything else wrong although there doesn't seem any reason
    why there would be.
    Steve P, Jan 7, 2004
    #43
  4. Ben
    Ben Guest
    I'll drop you a line on Friday and we'll work out a time and a meeting
    place.
    Ben, Jan 7, 2004
    #44
  5. Ben
    Jon Guest
    Ben says...
    Streetbike have currently got the F.Fabbri ones in for the thou (light and dark tint).
    It's the same make that I had on the SV and has an excellent finish. 40 quid or
    thereabouts.
    Jon, Jan 7, 2004
    #45
  6. Ben
    Jon Guest
    Jon, Jan 7, 2004
    #46
  7. Ben
    Ben Guest
    Double-bubble?
    Will pop up and have a look at the weekend.
    Ben, Jan 7, 2004
    #47
  8. Ben
    Ben Guest
    Ben, Jan 7, 2004
    #48
  9. Ben
    Jon Guest
    Ben says...
    Yeah. They had at least a dark and a light tinted one in on Saturday - I
    bought the light tint one and it seems it fits 2001 model 600/1000 (I'm
    assuming that like the 600 the 2001/2002 thou is the same). So unless
    they've had a double-bubble rush on there should still be some there.
    The only minor thing I'm not keen on is that it has a small "Fabbri" logo on
    it (same as the one on the SV if you ever noticed). But you certainly won't
    cut your hand open on the finish like the powerbronze ones :) I can email a
    couple of pics if you like.
    Jon, Jan 7, 2004
    #49
  10. Ben
    Ben Guest
    600/750/1000 all that the same fitting. I'll pop up on Saturday if I
    have time.
    It's the cutting your hand bit open that I didn't like about the one I
    had on the 750. If you're out to play on Saturday morning I'll have a
    look at yours then.
    Ben, Jan 7, 2004
    #50
