Bleeding shock absorber hassles
Discussion in 'UK Motorcycles' started by TOG@Toil, Sep 17, 2010.
  1. TOG@Toil
    TOG@Toil Guest
    OK, so the pattern shocks for the GN250 supplied by Wemoto don't fit.
    They measure 335mm long, pin centre to pin centre, which is fully 20mm
    longer than the stock ones. And that's with the pre-load on the
    softest setting.
    You have to unbolt the shocks and let the swinging arm drop as far as
    it can before you can bolt them on, and then the lower shock mount
    clouts the silencer.
    I can understand used shocks having sagged a bit - maybe 5mm - but a
    20mm difference in length is silly.
    Hunting around eBay and elsewhere on the interweb for pattern shocks
    for the GN reveals lots of sets with the same 335mm length. They also
    tout these shocks as being suitable for a variety of things from
    ShiteOld750s downwards, so God knows what they'd be like on a very
    small light 250.
    Wemoto have some shocks which are recommended for a 175/200cc machine,
    with a 320mm measurement. They ought to do. At their request, before I
    send them back, I'm going to photograph the too-long shocks next to
    the OEM ones and also on the bike, so they can see the problem. Seems
    that like other suppliers, they're just told by the manufacturer that
    yeah, sure, these fit a GN250 and then somebody like me pops up and
    finds out they bloody don't.
  2. TOG@Toil
    crn Guest
    I did suggest Hagon, they have a a nice man on the end of the phone who
    knows such little gotchas.
    crn, Sep 17, 2010
  3. TOG@Toil
    The thing with Hagon is that they ask the length, the type/size of
    mounting then the weight and just send you a damper with a spring to
    suit the weight of the bike & rider. This isn't the same as supplying
    the correct shock absorbers.
    It might have worked in the mid '70s but things have moved onward at a
    decent pace and we should be able to expect better these days.
    Andy Bonwick, Sep 17, 2010
  4. TOG@Toil
    Stephen Guest
    I suspect that the cost from Hagon and Wemoto would be significantly
    different...
    A quick google suggests Hagon want about 120quid whereas Wemoto wanted
    70 quid...
    Stephen, Sep 17, 2010
  5. TOG@Toil
    TOG@Toil Guest
    Hagon's good, but their twin shocks are between two and three times
    the price of a Chinese (or Korean, or Taiwanese, or wherever) set. On
    a 20 year-old GN250, I'm not after the ultimate in damping and
    comfort: just something that will stop the seat pan from rubbing on
    the tyre.
  6. TOG@Toil
    TOG@Toil Guest
    Well, Wemoto seem to have acknowledged they've boobed and are taking
    the shocks back for a refund on the CC. They're flummoxed, because
    their supplier swears blind the shocks are for a GN250 but that's
    presumably because that is what the manufacturer told *him*, and down
    the line, nobody seems to have actually tried bolting the things on.
    Until me. :-/
    That's why they've asked for some digital pix so they can re-do their
    website catalogue.
    These are exactly the same units as I bought from Wemoto
    http://cgi.ebay.co.uk/220669416827
    And these, while different, quote the same length
    http://cgi.ebay.co.uk/370407448886
    As do these
    http://cgi.ebay.co.uk/140451633875
    And these, incredibly, cite the same shocks as also being suitable for
    a Suzuki GS1000G shafty!
    http://cgi.ebay.co.uk/350172089976
  7. TOG@Toil
    crn Guest
    And all of the hassle with the Wemoto parts is worth ??????
    crn, Sep 17, 2010
  8. TOG@Toil
    Followed by a full retraction when he realises he's got the wrong
    exhaust fitted.
    Krusty, Sep 17, 2010
  9. TOG@Toil
    Surely you don't think he's got a cheap replacement exhaust and that's
    what's causing the problem? It could even be that the shocks on the
    bike are a pair that have been lifted off another bike and because
    they kind of fitted they were left there....
  10. TOG@Toil
    It did cross my mind that a previous owner may have fitted a different
    exhaust (or attached the hanger to the wrong side of the bracket), &
    stuck shorter shocks on to suit. But I'm sure TOG will have checked
    that. Won't he...?
  11. TOG@Toil
    So if a girl had owned the bike and it had been a bit too tall for her
    a logical solution would be to deliberately fit shorter shocks but
    that'd cause a problem if a future owner wanted to change them.
    Nah, couldn't happen.
  12. TOG@Toil
    Pete Fisher Guest
    I seem to recall a "Bugger. GN250 exhaust doesn't fit" thread, but I
    don't remember what the eventual outcome was. I *think* he was going to
    get a system from Wemoto, so that thickens the plot somewhat.
    | Pete Fisher at Home: |
    Pete Fisher, Sep 17, 2010
  13. TOG@Toil
    TOG@Toil Guest
    Also supplied by Wemoto.....:)
  14. TOG@Toil
    TOG@Toil Guest
    The exhaust is an identical pattern to OE, supplied by Wemoto.
    XChinese copy, and absolutely identical in appearance (crappier
    chrome, though). Bolts straight on.
    Shocks are OE.
    Like I said, you have to put the bike on the centrestand and unbolt
    the shocks to let the swinging arm drop right down as far as it will
    go, unsupported, to get the new shocks on. That just isn't right.
  15. TOG@Toil
    TOG@Toil Guest
    Yes
  16. TOG@Toil
    TOG@Toil Guest
  17. TOG@Toil
    I hope you're currently googling for GN photos to check the exhaust,
    cos this could be the best laugh I've had in ages.
  18. TOG@Toil
    Bum. Guess I'll have to find something else to laugh at then.
    <pokes sleeping cat>
    Hahahahaha!
  19. TOG@Toil
    I've had a quick google to see what was thrown up regarding shock
    absorber length on a GN250 and it's not looking good for Mr Murray.
  20. TOG@Toil
    TOG@Toil Guest
    Oh dear. Well, everything I've seen says 335mm as well..... But then
    one site also says that exactly the same shock is also suitable for a
    600lb Suzuki GS1000G, so don't trust it entirely.
