Bleeding front brakes
Discussion in 'Australian Motorcycles' started by DaveB, Feb 7, 2004.
  1. DaveB
    DaveB Guest
    Can anyone tell me if you're bleeding front brakes on a twin disk bike
    (FJ1200) do you bleed them separately, or do you need to do them both at
    the same time (and if that's the case how the hell do you do it with one
    pair of hands)?
    Dave B.
    DaveB, Feb 7, 2004
  2. DaveB
    Fwoar Guest
    seperately - but do them within the same service
    Start with the left caliper as it usually has a longer line.
    finish with the right caliper
    pump - pump - pump - release etc etc
    Till you ave the desired feeling ( take this anyway you wish! )
    Daron
    Fwoar, Feb 7, 2004
  3. DaveB
    atec77 Guest
    I normally do one at a time . the one closest to the master cylinder
    first in this case
    atec77, Feb 7, 2004
  4. DaveB
    FuTAnT Guest
    Hey Dave
    Just do one at a time and there is no probs. Use a syringe and a bit of tube
    to suck the old shite fluid out of the resevoir before you start as well,
    then fill up with fresh. Saves you atleast pumping the resevoir full of old
    stuff too.
    Cam
    '03 954
    FuTAnT, Feb 7, 2004
  5. Bleed separately.
    Not sure how far the brake lever is from the calipers, on the FJ, but I
    have had no trouble (apart from a dicky master cylinder) bleeding the
    front brakes on either the Red Baron or Suzie.
    Cheers
    PeterC [aka MildThing]
    '81 Suzuki GS450-s
    '87 BMW K100RT
    www.dmcsc.org.au
    Peter Cremasco, Feb 8, 2004
  6. DaveB
    Theo Bekkers Guest
    "DaveB" wrote
    Rules for all bleeding brakes is to do the one with the longest line
    from the master cylinder first and work towards the master cylinder.
    Same as in cars. An auto-bleeder is a damn good investment for about
    $15. Had mine at least 20 years.
    Theo
    Theo Bekkers, Feb 10, 2004
  7. DaveB
    Theo Bekkers Guest
    "atec77" wrote
    Wrong!
    Go to the back of the class.
    Theo
  8. DaveB
    atec77 Guest
    nah its not , I do them opposite to you , with a power bleeder , now
    think it through as you knew Id be difficult.( think up)
    atec77, Feb 10, 2004
  9. DaveB
    Theo Bekkers Guest
    :) OK. I'll give you that one. Motorcycle brakes can be a pain to
    bleed because of the vertical brake-line runs. I bleed mine from the
    bottom, by injecting brake fluid into the bleed nipple from the
    calliper end using a large syringe (Helen's a phlebotomist), and start
    (of course) from the furthest point.
    Theo
  10. You troll......
    Hammo
    Hamish Alker-Jones, Feb 11, 2004
  11. Ooooooh eeeeerrrrrrr!!!
    Hammo
  12. DaveB
    Theo Bekkers Guest
    "Hamish Alker-Jones" wrote
    Nice editing.
    Theo
    Theo Bekkers, Feb 11, 2004
