Bleeding epic
Discussion in 'UK Motorcycles' started by Pete Fisher, May 20, 2010.
  1. Pete Fisher
    Pete Fisher Guest
    Today I finally got round to fitting the front master cylinder piston
    kit and new caliper seals on the SO YZ250.
    The caliper job was easier than I expected, though I had to use my
    compressor to get the pistons out and scratched my head a while as to
    how to apply the air to the caliper. In the end I took off the quick
    connector from my rattle gun and found that applying the end of that to
    the banjo connection and pushing down hard on the connector gave a good
    enough seal and a controlled blast as required.
    I knew that when it came to refilling the system with brake fluid it was
    likely to be tricky from when I borrowed the lad's spare YZ85 master
    cylinder. With a completely empty system it was even worse. SO Morini
    Grimecas are so easy in comparison. I suppose I should get a Mityvac,
    but it's a job I don't intend to do regularly. In the end I had to leave
    the caliper off its mountings and hanging down as low as it would go
    whilst I laboriously tried to work fluid through. The air turned blue
    with some examples from Nige's repertoire. It took ages until a few
    drips emerged from the bleed nipple, and at last a decent dribble I
    suppose it's because the hole in the reservoir through which all fluid
    has to reach the parts is tiny and the hose, being on a crosser is v.
    long. Put the caliper on properly and after feeding it with even more
    fluid got a decent spurt on pulling the lever. Hooked up my one-man
    bleeding kit tube and finally started to get some pressure and
    encouraging bubbles. Eureka a working brake, and even better one that
    doesn't drag. So it looks like it was the caliper seals after all. Just
    as well, as a new caliper was going to be £350 and the refurbishment has
    only cost about £25, including a new actuating rod and nut for the
    master cylinder as the thread was chewed up on the old one.
    Oh, and I got the (Motoplat) flywheel magneto stator off the GFR
    (fortunately already featuring alignment marks). The rotor was on bloody
    tight, but the puller eventually shifted it from its 16 years marriage
    to the taper with a bit of soft hammer assistance. West Country Windings
    say they can definitely rewind the ignition bit, which looks
    suspiciously like the Bosch 'charging coil' on my old Rotax 250 MX
    motor, though hopefully with not such tiny gauge fragile windings as on
    that.
    A good days fettling - beer has been consumed.
    | Pete Fisher at Home: |
  2. Pete Fisher
    Really all you need is a 50p syringe from the chemist. Use it to fill up
    the lines in reverse, having loosened the banjo at the master cylinder.
    Making sure the m/c is full of course. Do the same to the caliper through
    the brake line hole then close the bleed screw. Attach caliper to brake
    line. Bleeding the system will now proceed with zero aggravation and there
    wont be much air left to remove anyway.
    Hog, May 21, 2010
