Bleeding brakes.
Discussion in 'UK Motorcycles' started by Eiron, May 31, 2011.
  1. Eiron
    Eiron Guest
    I looked at an old dismantled rear caliper yesterday from a SOSuzuki.
    It's clear that the outer bleed nipple is best bled on the sidestand
    but the inner one needs the bike to be upright, or preferably leant
    to the right a bit.
    That might explain why mine has always been spongy.
    Eiron, May 31, 2011
  2. Eiron
    TOG@Toil Guest
    For the life of me, I can't see why it'd make a bit of difference. OK,
    in theory air might be prevented from travelling up towards the
    nipple, but I've never heard of anyone ever having problems due to how
    the bike is placed on a stand. Especially on a rear brake, where the
    hose runs are so much shorter. Decent bleeding technique will work[1].
    If it worries you, bleed the 'lower' nipple first and then the
    'higher' one.
    If your brake feels spongey, I seriously doubt it's due to the bleed
    nipple positioning.
    [1] Happy to be corrected by anyone with first-hand experience of such
    a problem, mind.
    TOG@Toil, May 31, 2011
  3. Eiron
    Eiron Guest
    Happy to correct you.
    If the vent to the bleed nipple isn't at the highest point of the slave
    cylinder,
    then you'll never get all the air out.
    And it's not always obvious (without dismantling) where the vent joins
    the cylinder.
    Eiron, May 31, 2011
  4. Eiron
    TOG@Toil Guest
    So, like I said, bleed them properly.
    <Shrug>
    I just think you're highlighting a problem that doesn't seem to exist.
    Wouldn't be the first time, mind.
  5. Eiron
    Mark Olson Guest
    IME there's a fair amount of swirling around happening inside the
    caliper during bleeding, and the fluid is somewhat viscous, so unless
    the bleed nipple is actually at the bottom of the cylinder the air will
    eventually get carried along by the fluid.
    Mark Olson, May 31, 2011
  6. Not my experience I'm afraid, but it does seem to be rear brake calipers
    that cause the problems. I once spent over an hour trying to bleed one of
    my Guzzi's rear brake calipers; clear, bubble free fluid came out but
    there was virtually no pressure. I tried a MityVac, I tried pumping it at
    the pedal, I tried fast pumps, slow pumps, tapping it to dislodge
    bubbles, the lot. Eventually I unbolted it and held it up while tilted so
    that the bleed nipple was definitely uppermost, then bled it; clear
    within a couple of minutes.
    PipL alter ego, May 31, 2011
  7. Eiron
    Mark Olson Guest
    How far from the highest point was the bleeder?
  8. Hm. My experience has been as Olson's. Oddly, I've found, more than
    once, that spongey brakes have been down to worn pads. Yeah, yeah, I
    know that hydraulic systems are supposed to be self-adjusting, but it
    doesn't seem to work that way, always.
    I remember one Suzuki whose brakes I bled and bled, and which remained
    spongey, until I changed the rather worn pads. And it felt fine after
    that.
    The Older Gentleman, May 31, 2011
  9. Odd. I've had spongy brakes from *new* pads, where the calipers and discs
    were worn, so the entire pressure was on just a few high points on the
    pad surface. As the pads bedded in, the lever firmed up.
    PipL alter ego, Jun 1, 2011
  10. Not very: the nipple's on top of the caliper at the rear: can't picture
    it exactly at the moment but ISTR that the entire caliper is tilted very
    slightly down due to the the angle of the swing arm.
  11. The perversity of machinery.
    The Older Gentleman, Jun 1, 2011
  12. Indeed.
    Grimly Curmudgeon, Jun 2, 2011
