just got bike built and onto road but brakes feel full of air. I tried bleeding them but the tube going into the jar of DOT4 never has any air in it but the brake lever doesn't get any stiffer. where am I going wrong the master cylinder is pumping fluid (clear without bubbles) but only gets any feeling if I very,very slowly release the lever after releasing the pressure at the calliper. do I have to do both callipers at once or do I release the pressure at the bango on the master cylinder to check for no air. someone suggested draining the system and starting afresh. is this good advice. Robin
