Hi, I'd like to wire in my Givi top box so the brake lights on the box work. I figured it would be straightforward enough to just splice in the two wires to the wires in the brake light housing. However... when I got that far, I noticed that there are in fact *three* wires going into the housing[1] There's a blue, a brown and a green and yellow striped one. My GCSE physics and common sense tells me that they are Neutral, Live and Earth respectively. However, the brown and green/yellow stripe wires appear to go into the bulb housing, whilst the blue is connected to the outside edge of the housing. At this point I backed away and decided to consult UKRM before I unwittingly shorted out the entire bike. Could it be that the neutral is connected to the side of the bulb through the housing, and the "earth" is going through to the inside of the housing for another reason. Or are bike manufacturers sadistic enough to alter the wiring colours just to confuse me. Advice appreciated[2]. [1] Well actually six, as there are two bulbs. [2] Aside from "Step away from the bike you clueless fuckwit". I've had that already...
