Bl**dy 'L - this seems very cheap for an RE-5?
Discussion in 'Classic Motorbikes' started by Iain Ogilvie, Apr 22, 2006.
  1. Because an engine-driven pump will meter the oil more accurately tht you
    can. And in the case of Suzukis, will deliver the two-stroke oil
    directly to the bearings. How are you going to do that with pre-mix?
    Have you *never* put your bike in a false neutral?
    Simplicity is great. I like simplicity. I have a very simple low-powered
    Ducati which utterly rocks. But you are confusing simplicity with
    primitiveness.
    The Older Gentleman, Apr 26, 2006
    #41
  2. The CB750 handled poorly, agreed. So did the Wing.
    However, the CB750 comprehensively kicked the British arse until it
    hurt. And handling defects are reasonably simply and cheaply corrected -
    a change of bars, rear shocks and some heavier fork oil makes a
    surprising difference. And I've owned Honda fours, which I'll wager you
    haven't.
    Rather easier than trying to engineer an ancient parallel twin so it
    doesn't leak oil, shake itself to bits and blow up.
    #42
  3. *Yawn*
    I remember them saying this 30 years ago about CB400s, Suzuki GTs,
    Yamaha RDs and the rest. And the answer has turned out to be: *lots*.
    #43
  4. The Japanese *understood* customer satisfaction and built a superb parts
    operation.
    You are *appallingly* ignorant.
    #44
  5. Iain Ogilvie
    Paul - xxx Guest
    Anton Gijsen came up with the following;:
    Last time I saw a Bantam being actually used on the road as intended was ..
    er .. dunno. Maybe 1983
    I see lots of small, old jap bikes, sheeit I even ran (until it got nicked)
    a 22 year (A reg) old DT 125 LC, which had a superb engine.
    Paul - xxx, Apr 26, 2006
    #45
  6. also in due course the Japanese sorted the handling too, took a bit longer,
    I grant you and there are still inexplicable dogs. By this time the British
    industry had basically folded up. The modern incarnation of Triumph is
    doing deservedly well, it seems, but how much success would it have had if
    it had simply revived the old models?
    Austin Shackles, Apr 26, 2006
    #46
  7. Austin Shackles, Apr 26, 2006
    #47
  8. Iain Ogilvie
    Buzby Guest
    Blimey! What do they make [1] on the IoM?
    [1] apart from enormous banking fees
    Buzby, Apr 26, 2006
    #48
  9. Iain Ogilvie
    Mups Guest
    I tried my best to break the RS but it refused to die. The only bits I've
    bought for it was some plugs,points and a spare piston kit which was never
    used.
    I really wouldn't want to sell it in the state its currently in. I took it
    to Frankfurt and back in a weekend and then just dumped it in the garage
    and haven't touched it since. If you want a restoration project then fine
    but its not really in a road-worthy state.
    As it is about 100 quid or so.
    I'd recommend an RD500 with a SS stage 3 tune of course.
    http://www.churchstone.com/rd500.JPG
    I still miss that bike.
    Mups, Apr 26, 2006
    #49
  10. Iain Ogilvie
    Mups Guest
    Oh, I keep that around for old times sake...
    Mups, Apr 26, 2006
    #50
  11. Iain Ogilvie
    But what about the mostrosity sitting on top of it?
    _______
    \`\ | /`/ GSX-R1000K3
    Ace, Apr 26, 2006
    #51
  12. Iain Ogilvie
    Mups Guest
    Heh, It was the 80's you know. <thinks> Long blond wavy hair. Who'd have
    something like that in this day and age..
    Mups, Apr 26, 2006
    #52
  13. Iain Ogilvie
    Hopefully without the monstrosity sitting on its head...
    _______
    Ace, Apr 26, 2006
    #53
  14. None - that was tried before and failed dismally.
    GS850x2 XS650 SE6a
    Every post contains nutri-cermide-R for your reading pleasure.
    Folding@Home Team UKRM
    Grimly Curmudgeon, Apr 26, 2006
    #54
  15. Iain Ogilvie
    Peter Guest
    snips
    First I ever saw would have been red or perhaps green-liveried 125s
    ridden by GPO [General Post Office- predecessor of Royal Mail and BT]
    telegram boys in the 1950s.
    Certainly saw red GPO machines, always with leg-guards, and seem to
    remember a pale green GPO livery as well. Always wondered how many the
    GPO took, and to what extent that helped BSA survive at that stage.
    Peter, Apr 26, 2006
    #55
  16. Now who was just criticising others' reading comprehension?
    <gd&r>
    Dr Ivan D. Reid, Apr 26, 2006
    #56
  17. ^^^^
    Must you *always* bring in religion? (MSOHPR)
    #57
  18. Iain Ogilvie
    Paul - xxx said...
    Some lad rags an RXS100 up and down our road all day every day.
    Lozzo, Apr 26, 2006
    #58
  19. Iain Ogilvie
    Buzby said...
    PFM brake discs. Much better design and manufacture than the AP Racing
    ones it had.
    Lozzo, Apr 26, 2006
    #59
  20. Iain Ogilvie
    Champ said...
    Lets all hope she doesn't.
    Lozzo, Apr 26, 2006
    #60
