Bindit Experts.
Discussion in 'UK Motorcycles' started by steve auvache, Mar 19, 2005.
  1. Iffy starting (no nice comforting 7/8th's of the system is working fine
    thank you solenoid clunking noises) that is cured by pulling in the
    clutch and letting it go quick, switch innit? Where is the fucking
    thing? It's not on the lever and I can't see where the cable disappears
    at all.
  2. steve auvache
    spida Guest
    And yet normally, you are so lucid. btw, I've just returned from a
    'Minehead and back' followed by much beer and still you make no sense.
    Ditch it and buy a proper bike.
    spida, Mar 19, 2005
  3. spida wrote
    Ditch it? I have only just bought the fucking thing. Besides I rather
    fancy myself as the last owner and am prepared to do whatever it takes
    to run it finally and irrevocably into the ground. A hard job I know
    but someone has to do it and in these times of national crisis I feel it
    is only right and proper we all do our bit where we can.
  4. steve auvache
    spida Guest
    Crisis? what crisis. Anyway, what can you do to a Bandit that wasn't
    designed in as a fault by Suzuki.
    spida, Mar 19, 2005
  5. spida wrote
    Nope I give in, what can you do to a Bandit that wasn't designed in as a
    feature by Mr Suzuki?
  6. ogden wrote
    Wouldn't it be more fun to braze them together with the Ronson blowtorch
    thingy what I have bought and never used except for lighting barbecues
    with?
    and burning ants.
    Gaffa tape, please.
    I try but I know that it was done with the best intentions and somehow I
    keep finding it in my heart to forgive him. Mind you I haven't tried to
    take the plugs out yet so a change of heart could easily be on the
    cards. Especially if they stole trade secrets from Honda.
  7. steve auvache
    spida Guest
    They do have character, I will say that. At 12k rpm or so, mine had an
    exhaust note that sent shivers up your back, but after 10k miles the
    suspension was totally shagged, the faux chrome was peeling and the
    gear box had more neutrals than a Swiss pacifist convention - and the
    headlight - oh ****, the headlight.
    spida, Mar 19, 2005
  8. spida wrote
    I'd noticed that. I keep sticking my hand over the front to see if it
    is working.
  9. steve auvache
    spida Guest
    I still have nightmares; I remember creaming past a queue of traffic,
    late at night, not realising how much I was relying on the headlights
    of the cars I was passing until I got to the front - I tried parking,
    dipped and full beam but couldn't find an apex anywhere - in the end I
    stopped at a laybye and waited until I could join the end of the queue
    again. The GSXR is no better - at night, I follow my missus on her VFR
    - maybe it's a Suzuki thing.
    spida, Mar 19, 2005
  10. steve auvache
    jsp Guest
    The little switch mechanism engages on the underside of the clutch
    lever. It is quite possible to remove it and just make the connection
    permanent.
    John
    SV650
    Black it is
    and naked
    jsp, Mar 19, 2005
  11. steve auvache
    My switch is on the lever, there are two connectors that go onto the
    switch. I just pulled these off and stuck them of a small blade fuse and
    cable wrapped the wires against the bar. No more pulling the clutch in
    when starting.
    Muck, Mar 20, 2005
