Binding Brakes
Discussion in 'UK Motorcycles' started by John Kendall, Apr 8, 2005.
  1. John Kendall
    John Kendall Guest
    Hi All,
    I've got a bit of an issue with the Divvie, The front brakes are binding
    a bit. Now I've stripped down and cleaned both sets of Callipers,
    Replaced the pistons, replaced all the seals, put new pads in, polished
    the sliders, got rid of all the crap off every surface, and they are
    still binding a bit. Any suggestions (Other than buy new complete
    calipers, They're £200 a side!!!!)
    Thanks
    John
  2. John Kendall
    John Kendall emerged from their own little world to say
    shit in the master cylinder return valve
    wessie, Apr 8, 2005
  3. John Kendall
    Piss in the reservoir.
    Pip, Apr 8, 2005
  4. <All together now>
    Do you think that'll help?
    The Older Gentleman, Apr 8, 2005
  5. John Kendall
    John Kendall Guest
    Well it's quite cold out, so I haven't tried it yet......
    John
  6. In uk.rec.motorcycles, Pip amazed us all with this pearl of wisdom:
    Spunk on the plunger.
    Whinging Courier, Apr 8, 2005
  7. John Kendall
    Howard Guest
    Might not be relevant , but my (1982) brakes were binding, not
    suddenly but eventually they locked up entirely.
    Everything cleaned(x3) or replaced but I missed a <1mm hole in
    the piston assembly that released the pressure after braking.
    All safe now.
    Howard, Apr 9, 2005
  8. John Kendall
    Martin Guest
    does it have slide pins? I found that on my bindit the slide pins had
    worn ever so slightly and a small edge was stopping the pads from
    returning smoothly.
    Martin:
    VTR1000 Firestorm
    Martin, Apr 9, 2005
  9. John Kendall
    Stu Guest
    and they are
    Jon,
    You have to be really scrupulous getting the muck out of the groove the
    piston seal sits in. You get a build up of muck that pushes the seal out -
    by less than 1mm - but in many different spots. This is enough to make the
    seal "grab" the piston and stop it returning properly. A big clue is that
    the piston is difficult to push back in when you think you've cleaned it.
    A Dremel with it's small wire brush is excellent, as well as a small bradawl
    to scrape the stuff out, as it can be pretty solid.
    Stu
    Stu, Apr 10, 2005
