Binding brakes. :-(
Discussion in 'UK Motorcycles' started by MarkFraser, Jun 8, 2011.
  1. MarkFraser
    MarkFraser Guest
    My Fiance's Diversion failed it's MOT on binding front brakes.
    So, took the callipers off the forks leaving the hoses connected.
    Whipped the pads out and pumped the pistons out a fair way. That was
    enough access to clean the pistons up in situ with a dry cloth which
    seemed to get them pretty shiney. After this they didn’t seem to be
    binding but I didn't really check as that's always been enough before.
    I could push the pistons back into the calliper and pump them out ok.
    As I wheeled it out of the Garage for re-test this morning they were
    certainly binding again. Put the bike back in the garage un-retested.
    Given I'm reluctant to do a complete overhaul what's the FOAK's advice
    on perfect non-binding brake?
  2. MarkFraser
    Malc Guest
    IIRC there was something in the Haynes manual about lubing the pistons
    on Diversions with something (could be Copaslip) because they were
    liable to binding. But it could be the product of a duff memory so
    take this advice with as much of a pinch of salt as you feel it
    deserves.
    Malc, Jun 8, 2011
  3. MarkFraser
    MarkFraser Guest
    I've got a vague recollection that in the past I've used brake fluid
    on the pistons as a cleaner. I think it would also lube their travel
    over the dust seals a bit.
    Can someone confirm that the master cylinder is not a likely candidate
    and cleaning the pistons is highly likely to sort it out?
  4. MarkFraser
    Simon Wilson Guest
    DON'T use Copaslip - it can make rubber things swell and make it worse.
    Unlikely to be the master cylinder.
    The problem is likely to be caused by corrosion crud build up behind the
    piston seals. It does need a total strip, remove the seals, clean out
    with a dremel brush and then put it all back together. No need for new
    seals ime - they seem to last a long time.
    Simon Wilson, Jun 8, 2011
  5. MarkFraser
    Mark Olson Guest
    Dunno about how likely it was, but I've had a master cylinder
    return hole get plugged by old crudded up fluid, which nearly
    locked the front caliper solid as it heated up. In my defence
    it was on the way home from picking up the SOB. Check the
    reservoir and poke a soft wire through the return port.
    Mark Olson, Jun 8, 2011
  6. Simon Wilson escribió:
    When I was a car mechanic, it was standard practice to spread the stuff over
    just about everything.
    Copaslip and WD40 - all anyone needs for anything. Oh, and maybe oxy-
    acetylene.
    Paul Carmichael, Jun 8, 2011
  7. MarkFraser
    MarkFraser Guest
    Thanks to all, I think I'll give the pistons a good clean with brake
    fluid in the hope that lubricates and gets every speck off.
  8. And gaffrer tape. Don't forget gaffer tape.
    Cue "if it moves and it shouldn't, Gaffer tape. If it doesn't and it
    should WD40"
    cheers
    Spanners
    Spinning Spanners, Jun 8, 2011
  9. MarkFraser
    Simon Wilson Guest
    Cable ties, don't forget cable ties. "If you see one, snip it".
  10. MarkFraser
    Catman Guest
    Dangerous game.
    #www.cuore-sportivo.co.uk
    Catman, Jun 8, 2011
  11. MarkFraser
    Nah, I snip cable ties before breakfast and it's never done me any
    har-aarrr-aaarrr-aaaarrrrgggghhh-NO, PIP GERROFF!
    CT, Jun 8, 2011
  12. MarkFraser
    petrolcan Guest
    petrolcan, Jun 8, 2011
  13. Paul Carmichael, Jun 8, 2011
  14. MarkFraser
    Simon Wilson Guest
    Where's the fun in that?
  15. MarkFraser
    Hog. Guest
    Get a nice spray of brake cleaner. Pump the pistons out as far as you can
    without dislodging the seals and use the cleaner (and a soft brush) to get
    everything really clean. Then use red brake grease around the seals,
    pistons and the inside of the dust seal (if it has one).
    Make sure the brake fluid is clean and fresh. It's good to pump the pistons
    out and lever them right back in again a few times (once lubed). It doesn't
    do any harm to pump them out again, loosen the bleed nipples and cycle fluid
    by levering the piston in again.
    If that doesn't work then it's down to stripping the calipers and master
    cylinder I'm afraid. If you go that far then just renew all the seals.
    Hog., Jun 8, 2011
  16. MarkFraser
    Pete Jones Guest
    Order a genuine seal kit for the caliper (£17 from Wemoto) and overhaul
    it. Both my Diversions have needed this doing as they seem to just
    attract the grot. I tried cleaning and pumping pistons in and out but
    this only worked for a short while.
    The genuine seal kit also includes the red rubber grease which is used
    to fit the seals and pistons.
    Pete Jones, Jun 8, 2011
  17. MarkFraser
    zymurgy Guest
    Pah, Copaslip's so passe.
    Aluminium zeta grease is where it's at nowadays ..
    Paul.
    zymurgy, Jun 8, 2011
  18. MarkFraser
    Ian Field Guest
    Correct.
    Use the proper brake seal "red grease" - if you have trouble getting it try
    vintage car dealers/spares stockist.
    If you still can't get any get a tube of silicon grease from Maplin or other
    electronic component stockist.
    Ian Field, Jun 8, 2011
  19. MarkFraser
    There's plenty of it for sale on ebay
    http://shop.ebay.co.uk/i.html?_nkw=red+rubber+grease+&_cqr=true&_nkwusc=
    red+rubber+greease&_rdc=1
    Lozzo
    they churn out)
    Lozzo, Jun 9, 2011
