Bill Walker really is a Convict
Discussion in 'Texas Bikers' started by Arresting Officer, Apr 20, 2005.
  1. No, because .10 cents is one-tenth of a cent. What would have been so
    hard about "10 cents", or even "ten cents"? You could have even said
    "$0.10", which while awkward, would have at least been correct.
    Scott Gardner, Apr 25, 2005
  2. On Mon, 25 Apr 2005 00:27:05 -0500, "Brian Walker"
    Yes, but the end result was .104 DOLLARS, not cents. The "50" had
    units of dollars, and the "479.64" was a unitless factor, so the
    answer ".104" should have had units of dollars as well.
    I see where you're coming from, but your equation was still wrong.
    Two correct variations would have been:
    $50 today / 479.64 = .10 dollars in 1967
    -or-
    $50 today / 479.64 = 10 cents in 1967
    Whether it's a case of getting the incorrect answer, or getting the
    right answer and expressing it incorrectly, both you and Andrew were
    still off by a factor of 100. According to you, Andrew's error made
    him a "fucking dumbass" - what does your error of an equal magnitude
    make you?
  3. "$50 / 479.64 = 10 cents" is a perfectly true statement (ignoring the
    rounding error). Just because it combines the division and the
    dollars-to-cents conversion into one statement doesn't make it
    incorrect.
    Likewise, "2 pounds / 32 = 1 ounce" would be correct as well. If you
    have two pounds of something and divide it into thirty-two equal
    portions, each portion will be one ounce.
    Your *numbers* may have been correct, but you fucked up the units, so
    it's still wrong.
    While it's true that 50 divided by 479.64 is equal to .104, it should
    have been .104 DOLLARS, since the first number had units of dollars
    and the other had no units. By leaving the numbers the same and
    putting "cents" where it should have said "dollars", you made your
    answer incorrect by a factor of 100.
    That's like saying "500 pounds / 5 = 100 ounces". The *numbers* part
    is right (500/5=100), but the *units* part, and therefore the whole
    answer, is still wrong.
  4. Hey, you admit that you were "jacked up" in expressing your end
    result. - that's the only point I was trying to make.
    And to your credit, the difference between ten cents and a tenth of a
    cent is a lot more subtle than the difference between $23,982 and
    $239.82.
  5. If by "dumbing down", you mean "being consistent with your units",
    then yes, I guess you will.
  6. Arresting Officer
    Kitchen Man Guest
    $50 today / 479.64 ~= .10 would have worked, the dollar sign being
    assumed through the whole of the equation.
    Er, sorry. You're two decimal places off, just like Andrew was. The
    difference is, Andrew said "I made a mistake" and you are clinging to
    your error like a poop turd on a butt hair. These little things speak
    to character.
    Kitchen Man, Apr 25, 2005
  7. Arresting Officer
    BJayKana Guest
    You left off the part i wrote about "...support, join and only complain
    when you lose something.". like I mentioned the other day, when you
    attributed part of what Morgan wrote to me (by deleteing his name), you
    might want to take some quoting lessons from BJayKana, a web tv'er.
    Would you consider it deragoratory if I stated "Don would rather curse
    the dark than light a single candle"?
    ~~~~~~~(calgary)------------
    On my newsreader your comment was one single line that seemed to extend
    to infinity. I suspect it had something to do with the way you posted or
    copied it. Chasing your quote was a PITA. You might check that out. Ask
    Bjay for help if it is beyond your skills.
    ~~~~~~~~~bjay here~~~~~~~~~~
    Well Guys, I heard my name mentioned.
    I took it as a compliment from ya both, I THINK~~~?
    I would be glad to help either of ya, with
    the task of old fashion type ''News Group
    Quoting''......hehheheeh... Because its a task, and it's all done by
    hand....hehehe
    --bjaykana--
    'Ya'll take care'' --BJAY--
    BJayKana, Apr 25, 2005
  8. Arresting Officer
    Wakko Guest
    I had discussed with Bill that a pic of Bill accepting the badge would make
    for a good ebay auction to raise money for some worthy MC cause, be it MSF,
    MRF, TMRA, ABATE or whatever.
    Wakko, Apr 25, 2005
  9. Arresting Officer
    Kitchen Man Guest
    I'm pointing out that you made a mistake and refuse to admit it. That
    only makes me a dumbass because you don't have the character to do
    anything other than insult someone who points out an error.
    Convince me that you actually thought Andrew meant $23,000. After
    all, he already admitted his mistake, as soon as it was pointed out.
    You don't have enough character to do so. Do you think that mistakes
    are based on someone knowing what you meant to say when you say the
    wrong thing? How well did that work for you in school?
    Prove it.
    It isn't hard to spend 9/10ths of a cent somewhere, though, is it? So
    how does that have any relevance to your mistake?
    That makes no sense. Stating a mistake in different terms does not
    create a new mistake, or prove intent. You've got to do better than
    that. So far, I have a pretty good idea who the better man is here.
  10. Arresting Officer
    Henry Guest
    Like I said a while back, Ralph sells his ribs at the Ithaca
    Farmer's Market during the summer, which is a great place to
    spend and hour or two. Maybe we could get Dement to leave the
    smog of the big city, pick up Jimmy R. and join you, Ari, Steve,
    me and anyone else who's interested.
    (apology accepted in advance.)
    And while you're at it, maybe even read something that's written
    by credible folks who don't have a history of lying and a clear
    incentive to lie!
    "Our lives begin to end the day we become silent about things that
    matter." -- Martin Luther King Jr.
    "God told me to strike at al Qaeda and I struck them. And then
    he instructed me to strike at Saddam, which I did."
    -- George W. Bush
    "Hence today I believe that I am acting in accordance with the
    will of the Almighty Creator: by defending myself against the
    Jew, I am fighting for the work of the Lord."
    -- Adolf Hitler
    http://www.commondreams.org/
    http://www.truthout.org/
    http://thirdworldtraveler.com/
    http://counterpunch.org/
    http://responsiblewealth.org/
    "To announce that there must be no criticism of the President,
    or that we are to stand by the President, right or wrong, is
    not only unpatriotic and servile, but is morally treasonable
    to the American public."
    -- Theodore Roosevelt (1918)
    "You know, when bu$h said that he's against nation building,
    I didn't realize that he meant only the United States"
    -- Al Franken
    Don't let bu$h do to the United States what his very close
    friend and top campaign contributor, Ken Lay, did to Enron...
    Henry, Apr 25, 2005
  11. "Turby"
    SNIP
    True but last I checked the State department scum
    bags had changed things so that AMERICAN CITIZENS
    must have a passport to get back into the U.S. of
    A. What I want to know is WHY they think the can
    make changes that ought be made in congress. It
    was unilateral and unconstitutional. Burn the
    bastards out and shoot them when they come out of
    their hidey holes!
    Keith Schiffner
    RCOS #7
    Assistant to the Assistant Undersecretary of the
    Ministry of Silly Walks.
    "terrorist organization" is a redundancy
    Keith Schiffner, Apr 26, 2005
  12. Arresting Officer
    Wakko Guest
    Not in September last year. All I needed was a DL, altho I also carried a
    birth cert.
    Wakko, Apr 26, 2005
  13. This has been in the last 2-3 months iirc. Either
    way the psychopaths in DC are getting out of
    control.
    Keith Schiffner
    RCOS #7
  14. I've never travelled to Mexico or Canada, so I'm ignorant of the way
    things used to be. If Americans didn't have to present a passport to
    get back into the country, how did they prove their U.S. citizenship
    to be re-admitted? Was a driver's license sufficient? Aren't those
    fairly easy to fake (or at least harder than a U.S. passport)?
    Scott Gardner, Apr 26, 2005
  15. Err, make that last bit "or at least EASIER than a U.S. passport".
  16. "Scott Gardner"
    SNIP
    Pretty much it was DL for years between Canada and
    Mexico. Then you had to have the BC...it's getting
    stupid. If I had Bill Gates money I'd go to Canada
    with nothing buy my DL, BC and then come back. Oh
    what a fun fight that would be, I just can't
    afford the lawyers to fight that one for me.
    "Some days it's worth it to make a stand against
    stupidity"
    Keith Schiffner
    RCOS #7
  17. I was wondering about that, too. I've have calipers bind up and not
    release when I let go of the lever, and one time I had a front brake
    that was dragging slightly until it heated up the fluid in the piston,
    causing it to drag more and more until it finally became noticable,
    but I've never had a brake spontaneously lock itself up.
  18. Arresting Officer
    Wakko Guest
    Can you pitch a tent between the two border guard booths?
    Wakko, Apr 26, 2005
  19. Arresting Officer
    Andrew Guest
    I've done it before with a Birth Certificate, and even once with just a
    voter's registration card and driver's license. Now we carry the
    passports whenver we go to Canada or Mexico.
    Andrew
    00 Daytona
    00 Speed Triple
    RCOS #7
    Andrew, Apr 26, 2005
  20. Arresting Officer
    Andrew Guest
    I think it depends on how hot & sexy the border agent is.
    Andrew
    00 Daytona
    00 Speed Triple
    RCOS #7
