Bikesafe
Discussion in 'UK Motorcycles' started by Ben, Jun 9, 2007.
  1. Ben
    I concur: more from experience of Honda NX650s & ATs than a Tiger, but the
    geometry is similar.
    Even with the BMW funny front end, which offsets some of the huge weight
    transfer, use of the rear helps keep the bike more settled. Especially
    approaching roundabouts at the end of motorway slip roads where you need to
    scrub off lots of speed quickly
    wessie, Jun 18, 2007
  2. Ben
    That's what Tiggers do best...
    If by 'off the throttle' you mean just by holding the throttle open,
    then no, it's not normal - at least not with the standard gearing.
    However if you're chopping it then wacking it open again, or yanking on
    the bars, then that's normal.
    Krusty
    www.MuddyStuff.co.uk
    Off-Road Classifieds
    '02 MV Senna '03 Tigtona 955i '96 Tiger '79 Fantic Hiro 250
    Krusty, Jun 18, 2007
  3. Ben
    I meant shutting it and opening it again quickly, bouncing the front
    end up off the forks, rather than clutching it up. I did it by
    accident at first[0], but it's really easy and repeatable - I was
    quite surprised how light the front end goes on such a heavy[1] bike.
    My old R1150GS whilst similar on paper, never felt quite so flighty.
    [0] overtaking a bus about 200m from Phil's house.
    [1] actually, it's not that heavy when riding, only when pushing the
    twatting thing around, though I reckon that's because of the high CoG
    rather than just the weight itself.
    darsy, Jun 18, 2007
  4. Ben
    indeed. Similar-ish on my old R30 too, though it had *much* firmer
    front suspension than either the Tiger of the RGS.
    Yup - though as I mentioned to Krusty, I found the rear most useful in
    scrubbing off the last 20mph when coming to a standstill, because
    using the front alone meant a big bounce-back effect when I stopped,
    which isn't the best for a short-arse on a tall bike.
    darsy, Jun 18, 2007
  5. Ben
    Heh, I concur again.
    Due to a wonky knee I now ride with the seat in the high position. I've
    also fitted Migsel's lowered pegs. Whilst this has improved my comfort, as
    I don't have to bend the knee so much, I have a higher incidence of comedy
    balance moments. I'm just about getting used to the changed footpeg/brake
    pedal position. However, if there is a camber or slope at a junction I
    sometimes have to put my right foot down. As you say, bringing the bike to
    a standstill just on the front brake is not ideal, especially if wearing
    cordura trousers as you tend to slide forward. I rock at front brake hill
    starts fortunately.
  6. Ben
    Ah ok - yes that's very normal (helped by the soft springs, of course).
    A bit too light at times. Sliding the forks up 10mm or so is quite a
    popular change.
    Indeed. Many, many people have dropped them whilst pushing them around.
    One thing you definitely don't want to do on a Tig is stall it whilst
    doing a tight turn.
    Krusty
  7. Ben
    I presume you know it's very easy to lower Tigs by swivelling the rear
    eccentrics 180 degrees & sliding the forks up? You just need to space
    the chain guard up a bit, & cut a chunk out of the centre stand if you
    use it.
    Krusty
  8. Ben
    I can imagine that would result in a comedy bike-pinning-you-to-the-
    ground moment.
    Probably it would help if I did some upper-body muscle work.
    darsy, Jun 18, 2007
  9. Ben
    Rich B Guest
    Yes, tried it many times. The amount of braking is quite reasonable
    and very controllable (ABS stops it locking, and I'd rather not have
    it on the rear, but there you go). For firmer suspension and a
    lighter bike, I would probably think "tiny" was appropriate. For a
    heavy, soft lump like the Bandit (bless it, I love it) it's quite a
    usable piece of kit.
    Not sure I am with you here. If what you are used to in "normal"
    riding is to use both brakes equally all the time, then I would
    agree. (Or, as one apparently experienced rider on the course did,
    only use the back brake in town.) But if your "normal" riding is to
    vary the balance of the brakes with speed, road surface, rain, debris
    etc., then on a dry road and an emergency stop it would be natural to
    use the front to its maximum and ignore the rear. I've had a couple
    of stops this year that were "quicker than I would ideally have
    planned", and in each case I had no difficulty in leaving the rear
    brake well alone.
    Rich B, Jun 18, 2007
  10. Ben
    Yes, I've seen the instructions - I'm not sure if I'll need to bother,
    though - the height doesn't really bother me.
    darsy, Jun 18, 2007
  11. Ben
    On tall bikes, I tend to always put my right foot down, and use the
    left for gear shifts....
    darsy, Jun 18, 2007
  12. Ben
    Rich B Guest
    Bad form, but that should read "use only the back brake in town".
  13. Ben
    When riding something like a Honda Dominator I would mainly rely on the
    rear brake in town. Stop, start traffic[0] on a bloated pogo stick gets
    tiresome if you are frequently banging your bollocks into the tank.
    IIRC, as it's 12 years since I sold it, a set of rear pads lasted about
    7000 miles on my Dommie.
    So, whilst your theory is noted, I would contend that this rider might just
    be someone who rides, or has ridden, a bike with long travel suspension.
    [0] Not stopping is the ideal but inevitably some **** blocks progress.
  14. Ben
    frag Guest
    wessie banged the rocks together and they said :
    I find on my AT the rear brake works better than the front at anything
    upto 50mph or so.
    frag, Jun 18, 2007
  15. Ben
    frag Guest
    Champ banged the rocks together and they said :
    Use it more.
    On my old 9R the rear brake did as yours does, next to nothing. After a
    few months of using it the effectiveness was a *lot* more, it was
    useful.
    I'm not sure if its because the rear brake piston puts a lot less
    pressure on the pads, so they take ages to bed in / burn off
    contamination (the current 9Rs rear is also useless), but it did take
    bloody ages for them to start working. I just came to the conclusion
    the manufacturers knew riders didn't use them apart from the odd hill
    start, so they didn't need to do anything much.
    frag, Jun 18, 2007
  16. Ben
    snip>
    "I don't need a back brake, I just bang it down through the gears and
    dump the clutch."
    Slipper clutches are great fun.
    Andy Bonwick, Jun 18, 2007
  17. Ben
    deadmail Guest
    I guess the K1100 and 75 come into the "heavy things with softer
    suspension category" and I only use the back brake to:
    1. Stabilise the bike at low speeds (sub walking pace I suppose)
    2. Hold the bike stationary on hills
    3. Steady it a bit if it's a bit 'bouncy' on corners but then it's just
    the merest of touches.
    4. Brake when going down steep hills at lowish speeds particularly when
    the surface is bad (e.g. my driveway).
    That's about all I use it for (that I can think of), if I want to stop
    it's a job for the front brakes.
    deadmail, Jun 18, 2007
  18. Ben
    deadmail Guest
    Hmmm... the only time I've only used the rear brake is when the front
    disks are so warped it's uncomfortable to brake using them...
  19. Ben
    Rich B Guest
    Yup. But you knew that. I'm not sure about it, TBH. I can see the
    advantage in a general way, and I'm happy to have it on my car. I can see
    an advantage in helping to stop the front washing out if you had to brake
    really hard in the wet. On the back, I'm not so sure. On those (hopefully
    rare) occasions when you are faced with the choice of sliding down the road
    or hitting a lorry, a deliberately locked back wheel could be what saves
    you. And with ABS that ain't possible - I've tried. It's an odd feeling
    too - not the rapid judder you get from a car ABS, more a gentle on and off
    at about 0.5 second intervals, and a distinct reduction in braking force.
    Not keen.
  20. Ben
    Rich B Guest
    Twas a CBR600RR. He also thought that it was illegal to cross solid *and
    broken* white centre lines, if that helps with the picture.
