Bike Won't Start: Has spark, No Gas, BUT has rebuilt carb
Discussion in 'Motorbike Technical Discussion' started by Tim B, Nov 19, 2003.
  1. Tim B
    Tim B Guest
    1985 XT 350 won't start...
    I had rebuilt top end and timed and everything and got it to start a few
    weeks ago but I didn't have a clutch hub for it so I could start it but it
    wasn't going anywhere. I got the clutch parts required installed them all
    and now my bike won't start?
    I've got spark on the plugs but it doesn't pull any gas into the cylinder.
    When I kick start the engine it pushes a bit of air out the opposite way
    through the carbs and barely any air into the cylinder? Thing is I didn't
    change the cam's and the engine is still TDC when cams are at TDC position?
    Any idea whats causing this? Help Please!
    Tim
    Tim B, Nov 19, 2003
  2. Carb bolted on where the exhaust pipe should be?
    The Older Gentleman, Nov 19, 2003
  3. stuck or badly adjusted valve(s) ?
    r_kleinschmidt, Nov 19, 2003
  4. Tim B
    David Guest
    Tim I would re check the installation of the cam chain. If you can feel air
    being pushed out the carbs the valve timing is wrong. I.e the intake vavles
    are open while the piston is rising in the bore. I've seen several bikes
    where it is easy to install the chain with the cam exactly 180 degrees off
    which will produce the results you are describing. Do you have manual for
    your bike. If not let me know I can scan the pages out of mine and email
    them to you.
    Sorry to see the not so amusing remarks from "The Oldee Gentleman" . I've
    seen his stupid comments on this use group before. He should really change
    his handle to "The Old Ass Hole" Don't loose heart there are those out there
    that are decent and will try to help you out.
    87 Yamaha XT350
    75 BMW R75/6
    97 BMW R11GS
    67 BSA Lightning
    David, Nov 20, 2003
  5. Tim B
    Tim B Guest
    WOW! Thank you sooo much for you help! I can't tell you how much I
    appreciate kind people like yourself helping me out when I'm in my hour of
    need. You must be the most popular person in your group of peers judging by
    your kindness. Thank you soo much.
    Oh and while I'm checking, could you do me a favour and check to make sure
    your ASS isn't installed where you head should be?
    Thanks!
    Tim B, Nov 20, 2003
  6. Whoopie! Rattle launched on first reply!
    The Older Gentleman, Nov 20, 2003
