Bike won't start after carb cleaning.
Discussion in 'Motorbike Technical Discussion' started by Eat Dirt, Apr 8, 2008.
  1. So that is the way it should be done, whatever Berg thinks.
    The Older Gentleman, Apr 20, 2008
    #41
  2. Eat Dirt
    P.J.Berg Guest
    Coming from the man who insists the cold start function(Enrichment
    circuit) only works at idle with butterflies closed...
    J.
    P.J.Berg, Apr 20, 2008
    #42
  3. Eat Dirt
    Ian Singer Guest
    From page 5-12 of GS650G manual:
    "To check the float height, invert the carburetor body holding the float
    arm pin so that the pin will not slip off. With the float arm kept free,
    measure the height (A) while the float arm is just in contact with the
    needle valve by using the calipers. Bend the tongue (1) as necessay to
    bring the height (A) to this value."
    No None of us are quite right. It is supposed to be inverted but the
    float arm is not supposed to be pressing against the needle valve due to
    its weight. Last time I took a carb apart it would have taken a a pin
    punch to move the pin and there was no way it would fall out. I tried
    punching it out and broke the carb.
    Ian Singer
    See my homepage at http://www.iansinger.com
    hosted on http://www.1and1.com/?k_id=10623894
    All genealogy is stored in TMG from http://www.whollygenes.com
    Charts and searching using TNG from http://www.tngsitebuilding.com
    I am near Toronto Canada, can I tell where you are from your reply?
    Ian Singer, Apr 20, 2008
    #43
  4. Please show me where I ever posted that. I think you have me confused
    with another poster.
    #44
  5. Eat Dirt
    Ian Singer Guest
    No didnt see any scan. Attachments probbaly got lost.
    You do want to turn the carb over but you do not want it to depress the
    spring.
    Ian Singer
    #45
  6. Eat Dirt
    Ian Singer Guest
    OK thats totally different to picture in my GS650G manual which does
    show it inverted and not slanted.
    Ian Singer
    Ian Singer, Apr 21, 2008
    #46
  7. Eat Dirt
    P.J.Berg Guest
    Yes, exactly!
    J.
    P.J.Berg, Apr 21, 2008
    #47
  8. Eat Dirt
    Eat Dirt Guest
    As promised, here's an update in the event someone is curious as to
    how I fixed the backfire issue.
    Just now I finally got to put the pipes back on the bike as I had
    decided to paint them, once I had them off the bike. On a site note
    painting them with Temclad heat resistant flat black was a good move.
    It looks so much better now.
    Anyhow, the problem with the backfiring was due to air escaping from
    where the pipe connects to the engine. This is an aftermarket pipe and
    I couldn't just use a standard part from the many the local wrecker
    had. So instead I had to become creative with muffler tape. Walmart
    sells them for like $4. I also replaced the brass rings (washers) with
    new ones ($5 for the pair). That's all it took. The muffler tape
    provided just the right amount of sealing to make the whole thing work
    well. No backfiring at all and I can't feel any air escaping. All I
    can see is a bit of smoke (from the burning tape which is normal)
    being pushed away as I revved the engine.
    Thanks to all here for the help. Bike sounds incredibly smooth now.
    Carbs are nice and clean, got the muffler issue resolved and now all
    it needs is insurance and a plate. Somehow I have a feeling I'll be
    enjoying this bike more than the person it was intended. What treat it
    is to make turns with this light bike.
    Eat Dirt, Apr 26, 2008
    #48
