Bike Towed Trailer
Discussion in 'Australian Motorcycles' started by GWD, Oct 2, 2011.
  1. GWD
    GWD Guest
    Well you would certainly keep up with the Ural. Nearly anything on
    Earth could do that :)
    I had this plan for the headline to read: " CANCER VICTIM IN LATE 60'S
    RIDES SOLO AROUND AUS".
    I seem to be gathering a retinue though, so the "Solo" bit is starting
    to look a little unlikely. You have about a year to work on your
    "sickie" story :). You would be welcome of course.
    GWD, Oct 15, 2011
    #61
  2. In aus.motorcycles on Sat, 15 Oct 2011 21:48:16 +1100
    Learn to slipstream trucks. Worked a treat on the MZ. Top speed went
    from 100kmh to 110!
    Zebee
    Zebee Johnstone, Oct 15, 2011
    #62
  3. GWD
    GWD Guest
    Nah - trucks only do 100 - I thought everyone knew that :)
    GWD, Oct 15, 2011
    #63
  4. GWD
    Nev.. Guest
    If you're travelling alone, you can reduce the volume of clean clothes
    and underwear you're required to carry by probably 75% or more. 2 pairs
    of jocks will do if you're planning to wash at least once a week :)
    Top heavy can easily be solved by the way you pack. A rider or pillion
    sitting on the seat shouldn't make the bike top heavy, so therefore
    packing 50-90kg of luggage and putting it where the pillions bum would
    normally go shouldn't create a topheavy situation (but in terms of
    balance when the bike is stationary, the less weight on the bike, the
    easier it is to save it if it starts to go over in a carpark or at the
    servo. Panniers achieve a simliar weight distribution. Keeping the
    weight forward of the rear axle is probably more important than how high
    or low it is carried. Ie put all the heavy shit in panniers or on the
    seat and light shit in the topbox will create a much better weight
    distribution than if it was reversed.
    A trailer probably doesn't apply to that axle rule because is has it's
    own axle. A trailer probably isn't the simplest cheapest or simplest
    solution to set up initially, but it sure does make packing easier, you
    can jam a whole lot of shit in there without too much thought and get
    moving.
    Nev..
    Nev.., Oct 17, 2011
    #64
  5. GWD
    Nev.. Guest
    Nev.., Oct 17, 2011
    #65
  6. GWD
    Nev.. Guest
    Before you did a lap of Australia on the Ural I'd read the book by Carla
    King about her trip around North America on a Ural outfit.
    "American Borders: Breakdowns in Small Towns all Around the USA".
    http://www.carlaking.com/pages/store/products/csk/64
    Nev..
    Nev.., Oct 17, 2011
    #66
  7. GWD
    Nev.. Guest
    Realise this thread is a bit stale, but noone else said anything about
    your timing so I will. Most people doing a lap of the country aim to
    complete their lap by Sept/Oct rather than starting at that time.
    You're going to be risking much wetter climate up north and hotter
    temperatures down south. That might not bother you that much but it's
    worth considering, especially if you decide to take the Ural.
    Nev..
    Nev.., Oct 20, 2011
    #67
  8. GWD
    Diogenes Guest
    Bloody 'ell, Nev. I do declare there are times you make a lot of
    sense.
    Onya bike
    Gerry
    Diogenes, Oct 20, 2011
    #68
  9. There's a bloke over here who seems to be on a quest to collect every
    GPX250 ever made. I'll have to give him your address. :)
    Peter Cremasco, Oct 22, 2011
    #69
  10. GWD
    GWD Guest
    Sensible comments all.
    I will ponder this
    GWD, Oct 24, 2011
    #70
  11. GWD
    Diogenes Guest
    While you're pondering, how close did the bushfie get?
    Hope you're OK.
    Onya bike
    Gerry
    Diogenes, Oct 24, 2011
    #71
  12. GWD
    GWD Guest
    It was a bit scary for a while but it stayed well away from us - due
    to the efforts of the RFDS. There was a lot of equipment both on the
    ground and in the air.
    Thanks for the concern
    GWD, Oct 24, 2011
    #72
  13. GWD
    Diogenes Guest
    Onya bike
    Gerry
    #73
