Bike Towed Trailer
Discussion in 'Australian Motorcycles' started by GWD, Oct 2, 2011.
  1. GWD
    CrazyCam Guest
    Hi George.
    If you are determined to camp, I,too, vote for the Ural.
    The BM would be fine for, as you say, blasting from Motel to Motel.
    Stuffing about with old ammo boxes in place of elegant panniers would be
    like trying to use a thoroughbred race horse in place of a camel.
    Totally silly given you HAVE a camel in your shed anyway.
    Personally, I'd take the BM and stop at motels, but <shrug> I'm just a
    thirsty wimp.
    BTW, being somewhat speed limited might not be a bad thing.
    Imagine being half way round and then having your licence eaten by the
    cops. ;-)
    regards,
    CrazyCam
    CrazyCam, Oct 8, 2011
    #41
  2. GWD
    Moike Guest
    +1 on the Ural.
    When Goaty and I did our trip to Perth a few years back, we found 85-90
    k/h a much more reasonable speed than the 110+ you could generally get
    away with. This was partly due to Goaty's trailer toting Vulcan getting
    145k to reserve on one stretch, but more to a couple of close encounters
    with skittish wildlife lurking under roadside bushes, and witnessing
    what happens when a vehicle wanders just off the tarmac on a road with
    deep sand shoulders. Sustained high-speed outback travel has a range of
    hazards. We didn't get monstered by trucks etc. most of the other
    traffic was doing much the same speed.
    The upside is getting to have a look around, and arriving relaxed at the
    end of a ride that was maybe 20 minutes longer each day.
    If the Ural has the reliability, and the range to cover the distances
    between fuel stops, (max about 280k) I'd say it's a no-brainer.
    Moike
    Moike, Oct 8, 2011
    #42
  3. GWD
    GWD Guest
    Well, thanks Moike, Mr Humble, Zebee, Cam...
    The eloquent case you all make for the Ural is appreciated. Yes the
    Ural is reliable and easily mend able on the run, and with the
    external Jerry Cans should easily do the required 300 or so between
    fuel stops
    Zebee:
    I can relate to your comments regarding the Ural as a conversation
    starter - it certainly is that. My first big trip was through the
    Darling Downs a day after I had purchased it. The most common comment
    was: "Great restoration job mate. How old is she?"
    This was followed by a look of real disappointment at my reply: "Two
    days, mate." Never-the-less this was always followed by coffee and a
    pie and a nice talk about the local area.
    Cam:
    I take your point about bodgying up a perfectly good touring rig to
    try to turn it into something it isn't. I would truly hate to do that
    to the RT, so unless something fits off the shelf, my money stays in
    my wallet. Of course it would be tragic to have one's licence eaten by
    an over enthusiastic cop. This would be difficult to do on the Ural,
    but much easier on the RT. Just one more point to the Ural.
    Moike:
    I've done a hell of a lot of outback travel in 4wd cages but
    comparatively little on a bike. That's a reason why the load carrying
    solution for the RT has to have little effect on the longitudinal CoG.
    Maybe that is just one tall order too many that will favour the Ural.
    I haven't forgotten the trailer option, but I'm starting to wonder if
    it's worth the drama and expense.
    Ben:
    Yes, as per Zebee above, driving the Ural is one conversation starter
    after another, and that, as you indicate, is pretty important on a
    long trip.
    All and others too numerous to mention:
    Thanks for your input. I take all of your points, and whilst I have
    not made a decision, I will make one this week, and I suspect the Ural
    will get the nod when I consider the points you have all made.
    GWD, Oct 9, 2011
    #43
  4. GWD
    CrazyCam Guest
    Hi George.
    Out of curiosity, do you have anything in the way of a route plan for
    your "round the block" trip?
    regards,
    CrazyCam
    CrazyCam, Oct 9, 2011
    #44
  5. GWD
    GWD Guest
    Cam
    The general idea is to start late Sep or early Oct at the latest.
    Immediately head North to Townsville visiting Rellies and friends on
    the way (cooler month is better in FNQ). Spend a few days in
    Townsville with side trip to Rellies in Cairns. Then west to Mt Isa,
    Darwin, bitumen road to Perth with side trips to coastal areas of
    interest (Dampier,Broome, Monkey Mia, various National Parks and (just
    maybe) Ullaroo.
    I'll visit my sister in Mandurah for a few days with side trips to
    Margaret River and other places of interest.
    Then head East. I have to research this part of the journey as time
    might disallow much sight seeing. Weather ought to be nice and warm
    though.
    That's the vague outline with much filling in to do between now and
    next September.
    GWD, Oct 9, 2011
    #45
  6. GWD
    atec77 Guest
    80> I did Brisbane to Sa return on r65 with side-chair in 1980 , of
    course there was a room issue but adding some side bags solved it and
    taking two weeks stopping and visiting was a very enjoyable experience
    How little is needed can be quite surprising and happily I didn't need
    to worry about drive line problems and tyres
    atec77, Oct 9, 2011
    #46
  7. In aus.motorcycles on Sun, 09 Oct 2011 12:30:27 +1100
    I like trailers for big loads, way way nicer than having the stuff on
    the bike.
    Dedicated bike trailers are disgustingly expensive, but consider the
    smallest one of these:
    http://easytrailer.com.au/
    A towbar for your bike will be available from Classic Industries off
    the shelf, you'll have to wire it up yourself but it's not that hard.
    You'll also need waterproof lockable storage on the trailer, I
    suggest big plastic boxes from Bunnings popriveted to the plywood
    floor you bolt to the trailer, with hasps on. Won't keep the
    determined thief out but there are few of those and the expensive
    kit goes in the bike panniers.
    You should be able to have a towbar and trailer for under a grand
    rather than nearly 2 for trailer alone.
    I still reckon the Ural though! For one thing, if you do go offroad
    it will be a lot harder to fall off miles from any help, and any bush
    mechanic can fix the bastard.
    Zebee
    Zebee Johnstone, Oct 9, 2011
    #47
  8. I'd have a look at Touratech, Corbin and Hepco and Becker.
    Fraser
    Fraser Johnston, Oct 11, 2011
    #48
  9. GWD
    GWD Guest
    Looked at all. Plenty for GS but not RT.
    Thanks for the input
    GWD, Oct 11, 2011
    #49
  10. GWD
    GWD Guest
    Thanks - it's all grist for the mill. I liked the teardrop camper -
    might go well with the 4wd cage - not behind the RT though.
    Thanks again Zebee
    [/QUOTE]
    GWD, Oct 11, 2011
    #50
  11. In aus.motorcycles on Tue, 11 Oct 2011 17:53:36 +1100
    Heh... Was a guy used to go around South Oz using a 70s Jap bike with
    a chair and a big plywood box he used as a camper trailer. The side
    of the box unfolded and had legs, the tent poles slotted into
    carriers, so whole thing turned into a tent with bike inside.
    And then there's Frankenstein II who was a BMW R60 who travelled
    around Europe with custom made bodywork that was not only panniers but
    a fold out picnic table and chair....
    Still reckon the Ural will be way more fun myself. Easily carry all
    your stuff.
    You might want to consider something like pulling the seat out and
    seeing if a ute cover place can make you a fibreglass cover. Tonneau
    covers are notorious for leaking!
    Zebee
    Zebee Johnstone, Oct 11, 2011
    #51
  12. No worries. When you hit Perth hit me up and I'll buy you a beer.
    Maybe Theo would like to come along?
    Fraser
    #52
  13. GWD
    TimC Guest
    I got mine through mail order from motorcycle adventure:
    http://www.hepco-becker.com.au/
    They were pretty good.
    TimC, Oct 12, 2011
    #53
  14. GWD
    Theo Bekkers Guest
    "Fraser Johnston" wrote
    Sure would.
    Theo
    Theo Bekkers, Oct 13, 2011
    #54
  15. Sold!!! Maybe a run out to York or something?
    Fraser
    Fraser Johnston, Oct 13, 2011
    #55
  16. GWD
    GWD Guest
    I will be in about 12 months. We'll do a phone no swap before then.
    GWD, Oct 13, 2011
    #56
  17. Done!
    Fraser
    #57
  18. GWD
    bthumble Guest
    Certainly. My number is 0429 907 329. also works.
    bthumble, Oct 14, 2011
    #58
  19. GWD
    bthumble Guest
    If I had sufficient leave available, I'd buy a GPX250 and come with you! :)
    bthumble, Oct 15, 2011
    #59
  20. GWD
    bthumble Guest
    I think you should get #103, in case there's flooding. :)
    #60
