bike stalls with the lights on
Discussion in 'Australian Motorcycles' started by DaveZZR600, Feb 11, 2004.
  1. DaveZZR600
    DaveZZR600 Guest
    as per above, it`ll idle fine and even keep charge in the battery but when
    the bike is either warmed up or the lights are on , it coughs and misses.
    The revs die from 1400 to about 1000 and dies. doesnt do it at all when cold
    ( not the choke by the way). charge rate is good, battery almost brand new
    (3 months old) and in good nick, any ideas anyone?
    Cheers
    1991 ZZR 600
    1991 EB Falcon wagon
    1969 ZC Fairlane
    admin@loopback $LOGIN@localhost
    $LOGNAME@localhost $USER@localhost $USER@$HOST -h1024@localhost
  2. DaveZZR600
    sanbar Guest
    Regulator? Mine was dodgy and pretty much did what you have described,
    especially when placing a bit of load on the alternator.
    - sanbar
    sanbar, Feb 11, 2004
  3. DaveZZR600
    DaveZZR600 Guest
    that's what I thought too, although the voltage seems to be fairly constant,
    might need to go back out and check it again after this bloody cyclone goes
    away!!!
    Cheers
    1991 ZZR 600
    1969 ZC Fairlane
  4. DaveZZR600
    Johnnie5 Guest
    im thinking possibly you have some crap in the carbs
    and is partially blocking the pilot jet
    as you say it is ok when on choke as it will have a rich mixture then
    an easy check first of all is to drain the carb bowls through hose if your
    carbs have a outlet that you can fit a hose then drain it into a clear
    object so
    you can see the contents , wont guarantee no crap in there but its a
    possibility
    Johnnie5, Feb 11, 2004
  5. DaveZZR600
    X-No-archive: yes
    Any wonder it's upset after what it's been through the last couple of days!!
    I suggest a Bex in the petrol-tank and some nice rest in a darkened garage.
    Clem
    Knobdoodle, Feb 11, 2004
  6. Dave, I have the same symptoms on my VFR, and is 99% sure its the
    regulator/rectifier. Hope you get more change out of $300 than I would :(
    Shaw Goh \(NetPlus Micro Computers\), Feb 11, 2004
  7. DaveZZR600
    Frank Warner Guest
    Would not explain th eeffect of the lights being on...
    Frank Warner, Feb 11, 2004
  8. Running the light at idle will also put a bit more load on the engine, as
    the alternator is drained for more electron flow than it would really like
    to be putting out at the time.
    James Mayfield, Feb 12, 2004
  9. DaveZZR600
    sharkey Guest
    Check the chassis earth connection ... where the -ve battery
    lead connects up, that is. No reason, but it's easy to check
    and often causes Weird Things.
    -----sharks
    sharkey, Feb 12, 2004
  10. DaveZZR600
    paulc Guest
    I second this. My -ve lead (at the battery) had a lose connection. Caused
    a few weird things to happen.
    paulc, Feb 12, 2004
