Bike stalling?
Discussion in 'Australian Motorcycles' started by Uncle Bully, May 10, 2004.
  1. Uncle Bully
    Uncle Bully Guest
    Encountered my first show stopper today after 18 months on the GPX.
    Bike starts fine, revs fine in neutral, revs fine in gear with the clutch
    in, as soon as there is a hint of releasing the clutch it stalls. I was out
    there a good 10 minutes revving and stalling this morning before giving up
    and jumping on the bus. (I was already running late).
    It only happens in the cold, I'm wondering if it's a fuel delivery problem,
    or perhaps the stand switch is faulty and it doesn't realise the stand is
    up?
    Any ideas?
  2. Uncle Bully
    loftboy Guest
    Sounds like the sidestand switch is playing up.
    If you didn't already know, there is small switch at the base of the
    sidestand will kill the engine if you release the clutch in gear and
    the stand is down. They can be prone to gunking up & not release
    properly - give it a bit of a poke & prod, along with a squirt of
    RP7/WD40.
    loftboy, May 10, 2004
  3. Uncle Bully
    Johnnie5 Guest
    the hint here is it is when it is cold
    i would bet that you have some probs with the choke circuit
    Johnnie5, May 10, 2004
  4. Unscrew the switch off the clutch lever, and see if you still have the
    problem. If not, then it is the side-stand switch. If you do, however, still
    have the problem, then it is the fueling.
    The side stand switch can very easily get gunked up and it will cause you no
    end of troubles then. It sounds like it needs a thorough clean.
    James Mayfield, May 11, 2004
  5. On 10/5/04 7:23 PM, in article
    The rider....
    Hammo
    Hamish Alker-Jones, May 11, 2004
  6. Uncle Bully
    sharkey Guest
    .... and and affectionate tussle with a pair of sidecutters.
    Hate those bloody things.
    -----sharks
    sharkey, May 11, 2004
