Bike Recommendations
Discussion in 'Australian Motorcycles' started by Sandgroper, Dec 5, 2007.
  1. Sandgroper
    Sandgroper Guest
    Hi people ,
    I am in the market to get a new bike and want to get a naked bike with a
    more of an upright riding position.
    I have reduced the list down to 5 bikes , but I can't really get any
    satisfactory reviews of the bikes because they are either too old or from
    outside Aust where the road/weather conditions are different from Aust.
    So my list is :
    CB 900F Hornet
    CB 1300F ( naked , no faring )
    XJR 1300 Yamaha
    GSX 1400 Suzuki
    GSF 1250 Bandit ( naked , no faring )
    I have a bit of a preference towards the CB 900F and the CB 1300 and have
    ridden them , but I don't know anything about the other bikes.
    Has anybody got experience/comments/opinions of these bikes ?
    Thanks.
  2. Sandgroper
    JL Guest
    Owned a Bandit (1200S though not the new 1250), have ridden the XJR
    for quite a few miles and the CB900 and GSX1400 for a quick test ride.
    Are you definitely looking at the 1250 (ie less than 1 or2yr old IIRC)
    or are you looking at the older 1200 bandit - there's quite a
    difference I'm told - the new one is lighter, water cooled and better
    ergonomically. My only real complaint about the bandit was poor fuel
    economy (quite thirsty), and the seat slid you down towards to the
    tank. I'm told (although I didn't get around to doing anything about
    it to find out) that the emulsion tubes wear into an oval shape in the
    carbs and that's what causes the poor fuel economy (ie it's fixable)
    The short answer is none of them will let you down they're all pretty
    much bullet proof, none of them are particularly light or nimble, but
    short of chasing hard arsed sports bikes it'll do as much as most
    people want.
    I had to take the centre stand off the bandit as it had insufficient
    ground clearance with it on, however my bandit had better clearance
    than the GSX14 and possibly a smidgen more than the XJR. CB900 is the
    sportiest of the lot.
    All of them used old school long model run motors bar the CB900 so
    parts are easy and cheap.The 1250 however is I think a new motor so it
    wouldn't be as available or cheap (but I'm pretty sure based on your
    blurb that you meant the 1200).
    All of them bar the XJR have fairly rudimentary suspension, the XJR
    has entry level ohlins which put it well ahead of the rest. Money
    spent on suspension setup would be well spent.
    JL
    JL, Dec 5, 2007
  3. Sandgroper
    CrazyCam Guest
    Are you talking new new?
    If so you might have to grab a 900 Hornet while you can.
    It seems that Honda Oz are going back to importing the 600..... not that
    that would be a bad option.
    I suppose, if you are seven foot tall, built like a brick dunny and have
    an SO to match, you need to look at the big bore beasties, but the
    smaller nakeds are pretty good fun too.
    regards,
    CrazyCam
    CrazyCam, Dec 5, 2007
  4. I'd got the Hornet. Runout deals according to the guy at my Honda dealer
    today. $12k ride away was the figure mentioned before haggling.
    Fraser
    Fraser Johnston, Dec 5, 2007
  5. Sandgroper
    Sandgroper Guest
    Thanks for the reply.
    I am looking to buy a new bike , the Bandit that I was thinking of is the
    1200 without the faring that was around last year or so .
    What you have written is the type of info that I want to know , particularly
    for the Bandit and the XJR and CB900 , it will give me something to think
    about before I decide on what I am going to get.
    I have read quite awhile ago that the XJR has a old type of motor and it's
    old technology , but it's interesting about what you have said about the
    suspension.
    Basically the type of bike that I want is similar to the CB1300 , XJR 1300
    and the GSX 1400 , naked without faring and with of than upright riding
    position , I would have preferred a bike around the 750 - 900 cc range , but
    they don't really make them so I have to go up to the 1200 - 1400 cc bikes.
  6. Sandgroper
    Sandgroper Guest
    Yes , I am talking about a new bike.
    I can get a 900 Hornet for $12500 ride away with some extra stuff on it ( in
    Perth ) , yeah , they are good value at the moment.
    The 900 Hornet is a fairly quick and nimble bike and after riding the CB
    1300 , I have found that the CB 1300 has a few extra refinements and that
    the throttle is a lot smoother and less jerky than the 900.
    Basically I can't really decide on the 900 Hornet or the CB 1300 , they both
    have good qualities and a few things that I am not keen on , it would be
    good if all the good things could be combined into one bike.
    The 600 Hornet sounds interesting , I have heard that Honda will be
    importing them to Aust , but I would have to wait too long before they are
    put on the market.
    Thanks for your reply.
  7. Sandgroper
    Sandgroper Guest
    Yeah , I was quoted $12500 ride away for the 900 with a few extra bits and
    pieces on it in Perth.
    It looks like I will need to take the 900 for a demo ride to see how it
    goes , I have ridden a demo bike one about a dozen times when I have had my
    bike in for a service , but that was quite awhile ago .
  8. Go see Rowan at Rick Gills.
    Fraser
  9. In aus.motorcycles on Wed, 5 Dec 2007 17:24:56 +0900
    <innocent look> 850 Griso </innocent look>
    Zebee
    Zebee Johnstone, Dec 5, 2007
  10. Sandgroper
    justAL Guest
    The Triumph Street Triple. :)~~~
    justAL
    justAL, Dec 5, 2007
  11. Sandgroper
    Sandgroper Guest
    Thanks , but I don't believe a bike should have 3 cylinders.
  12. Sandgroper
    Toosmoky Guest
    Go away...
    Toosmoky, Dec 5, 2007
  13. Sandgroper
    justAL Guest
    The extra cylinder you're asking for is going to waste then!
    justAL
    justAL, Dec 5, 2007
  14. Sandgroper
    Boxer Guest
    Some of the best bikes do, Laverda Jota, triples are inherently smooth, BMW
    K75's were highly regarded and a favorite of ageing old farts now.
    Boxer
    Boxer, Dec 5, 2007
  15. Sandgroper
    Dial up what 2nd-hand 900 Hornets are selling for (the few that actually
    SELL!!) before you define that "bargain"......
    Knobdoodle, Dec 5, 2007
  16. Sandgroper
    As opposed to all that "new" technology like pistons and spark-plugs and
    stuff?
  17. Sandgroper
    Get fucked!
  18. Sandgroper
    Sandgroper Guest
    Maybe I should rephrase that to old design type of motor.
  19. In aus.motorcycles on Wed, 05 Dec 2007 23:43:06 +1100
    For some reason I thought the T had heated grips... but apparently
    not.
    Breva panniers fit fine although the bracketing is slightly uglier
    when removed as they have a longer bracing bar at the back.
    The official rack for the topbox (Breva or Norge) is ruinously
    expensive and you should probably find someone who has one and get the
    rack copied by a welder. If it's mate's rates it should come at less
    than the $500 they want for the rack.
    It is.... You also get a little more plastic. THe plastic at the
    back is useful as otherwise the rear tyre can throw mud at you in bad
    conditions and have a little get through, but a $250 hugger from
    Skidmarx in the UK (local agent streetfighter.com.au who also do a
    bigger screen) will solve that.
    I note that Aitkens (www.aitkens.com.au) still has the T demo on the
    floor with panniers fitted and maybe even topbox I can't recall.
    It won't have much if any warranty left and has some mileage on, but I
    bet if you offered 'em 18 with the amount of rego left (which is
    bugger all but you want to re-rego it anyway) they'll take it.
    Zebee
  20. Sandgroper
    Theo Bekkers Guest
    So did I. It doesn't?
    I got one from Mario. I think it was about $150-200. I'm using my 12 yo Givi
    box.
    Theo
    Theo Bekkers, Dec 5, 2007
