Bike missing at high revs
Discussion in 'UK Motorcycles' started by ku2t, Jul 20, 2006.
  1. ku2t
    ku2t Guest
    Any technical bods got an idea on this one:
    A mate has a stock '96 zzr600 which misses/gets jerky inbetween 10-11k
    and 13-14k
    He's run through 3 tanks to clean out any old petrol and tried redex.
    Anyone got any ideas?
    I start the ball rolling with: check plugs and leads - sounds
    electrical. I haven't got a clue when it comes to fuelling
    Cheers
    Kev
    ku2t, Jul 20, 2006
  2. ku2t
    Chris H Guest
    Dodgy connection(s) and resonance? Check sidestand cut-out switch (if
    it's got one), kill switch etc.
    Chris H, Jul 20, 2006
  3. Water in the fuel, perhaps. Is it carbed or injected? If carbed, that's
    the kind of thing that happens when the water in the carb bowls reaches
    a critical level.
    Also...
    Check all low tension connections to the ignition system, especially the
    skinny wires to the triggers on the crank end.
    Grimly Curmudgeon, Jul 20, 2006
