Bike lift
Discussion in 'UK Motorcycles' started by Timo at Work, Dec 1, 2005.
  1. Timo at Work
    Timo at Work Guest
    'tis the season when one has to think up Christmas presents so the
    thoughts invariably turned into the direction of the workshop.
    *Especially* given that I've got to finish two bikes in the next few
    months in order to gain back some more space in the garage.
    A quick google suggested the following URL:
    http://www.worldofpower.co.uk/acatalog/Motorcycle_Hydraulic_Lift.html
    and after a bit of thinking I've boiled it down to a choice between the
    MC402 and the MC365. The latter is a proper workbench which does lift
    higher but has the disadvantage of expecting the bike to have a centre
    stand (which two of my bikes don't have, so I have to add a paddock
    stand). The MC402 is probably better in that respect but I can't see
    that working too well with single-downtube frames.
    Can any of the grease monkeys add some comments from their experience?
  2. Timo at Work
    Go on, I'll bite. First check the overall height of extended lift
    plus bike and compare to internal height of garage.
    Apart from that, I'm saying **** all.
    Pip, Dec 1, 2005
  3. Timo at Work
    Timo at Work Guest
    I wasn't fishing...
    That said, the garage is high enough so I could stick the GS on the
    bench lift, raise it up fully and still sit on it. If I were daft
    enough, obviously...
    At the moment I'm leaning towards the quad-type lift (ie the non-bench
    one) as it'll be more suited to dropping out wheels, forks and all
    that...
  4. Timo at Work
    Learner Guest
    I have the MC480 (lower weight capacity version of the MC402). I use it
    for an XT600 which obviously has no centre stand.
    Good Points:
    Doesn't take up too much room when not in use
    Easy to use
    Bad Points:
    Bike is not very stable when on the stand - I'm always a bit worried
    it's going to end up on top of me if I get enthusiastic with the spanners.
    Works fine, just need to be a bit careful.
    Cheers,
    Learner
    Learner, Dec 1, 2005
  5. Timo at Work
    Vass Guest
    Vass, Dec 2, 2005
  6. Timo at Work
    Andy Bonwick, Dec 2, 2005
  7. Timo at Work
    Timo at Work Guest
    Timo at Work, Dec 2, 2005
