Bike did a wee
Discussion in 'UK Motorcycles' started by BGN, May 27, 2006.
  1. BGN
    Thursday afternoon? I'm away the following week.
    Was there a slightly more accurate description of the symptoms other than
    "done a wee"?
    sweller, May 28, 2006
  2. That must be Universal Salvage, from what they say on the page. They're
    ok to deal with.
    Grimly Curmudgeon, May 28, 2006
  3. Bad form, and all that, but I've had a close look and it's not US. Other
    direction.
  4. BGN
    BGN Guest
    I'm off until Wednesday, back to work on Thursday. I will contact my
    new manager on Tuesday to ask if I can swap my day off but otherwise,
    if the offer is still open, I'll need to arrange an alternative date
    with you if possible.
    If Mr. Courier or prawn would like to contribute to this I'd
    appreciate it. I'm not sure if a diagnosis was made but the bike is
    working now and survived a 12 or 14 mile round-trip to Halfauds and
    back, but I did keep the revs quite low and very little oil was blown
    out of the exhaust. I think rings were mentioned.
    BGN, May 28, 2006
  5. BGN
    I'm away in Scarborough the following week; I can do 12th or 13th June
    easy enough when I get back (pref. 12th as I have to be in London suited
    and booted for the evening of the 13th).
    My money's on head gasket if it's over pressuring the crankcase forcing
    emulsified oil into the airbox. Rings on average mileage Jap bikes don't
    really wear out.
    Before coming over here or doing any appreciable mileage check that the
    oil and coolant are not mixing. Is there excessive mayonnaise in the
    engine or oil in the coolant.
  6. In uk.rec.motorcycles, sweller belched forth and ejected the following:
    It wasn't, there was only petrol in the airbox - the result of an air
    filter dripping in the stuff.
    I reckon the thing just stalled and he panicked or the air filter thing.
    The engine wouldn't turn over at all to begin with so we took one of the
    plugs out and gave the back wheel a turn with it in 6th gear. A load of
    petrol shot out of the spark plug hole (Prawn videoed, then promptly
    lost the video of this event) and it then turned over with the key.
    Spark plug back in, tank reconnected and Bob's your cross-dressing
    Auntie.
    They're not mixing but if you fancy servinibg the thing then rather you
    than me, chum. I mean, have you actually seen what you need to do to get
    cylinder 2's plug out? Not only have you got to remove a lot of the
    plumbing but where Nick went DS, there's a bit of gravel stuck between
    the hex bit of the plug and the head. There's no quick way of getting
    that plug out, mate.
    Muhahaha!
    Whinging Courier, May 28, 2006
  7. BGN
    BGN Guest
    There was a **** load of coolant in the air box too mixed with petrol
    That must have been one hell of a stall that I couldn't undo and two
    blokes from the port authority couldn't figure out and the bloke from
    Carole Nash couldn't fix. It wouldn't even bump start. The soaked
    air filter can't have been doing much good either and would explain
    the loss of power just before I got to the port and the unwillingness
    to start at the petrol station en route.
    And then followed dinner which I thought was a nice touch. Mother
    hasn't commented but I think she likes you. I normally bring around
    really odd people which she doesn't converse with but she certainly
    got a natter on with you.
    What's "DS?"
    Thanks so much for your help today. As you said, even if it was going
    to be flogged on ebay, it's now a runner in need of attention instead
    of a non-runner which is probably worth a couple of hundred squid
    more.
    BGN, May 28, 2006
  8. BGN
    BGN Guest
    It did go ditch surfing on that side. But... I've been charged for
    two sets of new spark plugs since then at the ultra reliable Cheriton
    Motorcycles... if a stone is still stuck in one of them could that be
    indicative that very little work had actually been carried out in
    these services, and if that's true, would not having a proper service
    in 15,000 miles cause something similar to what I experienced on
    Friday on the ferry?
    Similar to the DS#7 in my sig.
    BGN, May 28, 2006
  9. In uk.rec.motorcycles, BGN belched forth and ejected the following:
    No there wasn't. It just stank of petrol.
    <Deep gravelly voice>
    OH!
    Indeed, completely unexpected and a nice surprise. You never told me you
    Mum was a darlin' :)
    Yes, she did rather.
    Ditch surfing.
    And to quote prawn, it's now worth three hundred pounds and a penny :eek:)
    Whinging Courier, May 29, 2006
  10. BGN
    BGN Guest
    Yes, blue petrol...
    Minus £5.99 for the oil. Oh, and in all the excitement of surviving
    the journey to Halfauds I bought "Motorcycle Gear Oil" instead of oil
    oil so I'll get that exchanged today.
    BGN, May 29, 2006
  11. BGN
    BGN Guest
    I've searched for 'head gasket' on ebay in the motorcycle section with
    no hits, but looking at the car section the head gasket appears to be
    nothing more than a few slithers of cork, card board and perhaps some
    plastic.
    I'll do a 40 mile bimble today, if it's not pissing with rain and see
    if anything mayonnaise-like appears in the sight glass. It hasn't in
    the past and I can't see it there now. Even after Friday's
    unfortunate events the sight glass still shows black oil.
    <http://www.bitzforbikes.co.uk/myproducts.php?BikeID=181&year=6656&ProdTypeID=5>
    Should I purchase one of these (Complete Gasket Kit £62.95) or is it
    easier and cheaper to source the parts locally? Also, after seeing
    the LHS spark plug yesterday it was smothered in oil, probably from
    last week, so that probably needs replacing and the oil's due for
    replacement with the filter and the coolant is now just water, yada
    yada yada yada...
    <sigh> Are you sure you want to do this?
    BGN, May 29, 2006
  12. You're supposed to use that for waterproofing your leathers, you muppet.
    The Older Gentleman, May 29, 2006
  13. BGN
    BGN Guest
    On Mon, 29 May 2006 10:35:53 +0100,
    During prawn and MC's visit yesterday I think the general theme of
    clothes waterproofing was to get as much petrol flung out of the
    engine into the air as possible.
    BGN, May 29, 2006
  14. BGN
    Large cornflake box, using the old gasket as a template. YKIMS. It did
    to me, anyway, and the TZR managed about 2000 miles before blowing up
    again.
    ogden, May 29, 2006
  15. BGN
    Ralf Mayer Guest
    I wonder why no one pointed it out yet, so I will do it:
    Please be very careful riding the bike with the gasket ready to blow.
    Should water enter the combustion chamber, you will learn pretty quickly
    that liquids are nice to adjust to any shape, but cannot be compressed at
    all, which the upwards moving piston will try to do anyway... the engine and
    back wheel will seize quite fast.
    So be prepared to grab the clutch at any time... Although I doubt anyone
    *could* grab the clutch in the time needed to not fall off. After having
    water break into it, major damage to the rest of the engine is almost
    certain - so please, consider if you really want to drive before having it
    sorted out.
    Ralf Mayer, May 29, 2006
  16. Ralf Mayer wrote
    NAHAY?
    steve auvache, May 29, 2006
  17. BGN
    Ralf Mayer Guest
    I did browse a couple of acronym dictionaries and did a google on this one,
    with no results... You will have to use a more understandable way to make
    me look stupid.
    (But I still feel proud to have managed to figure out TIUTA without asking!)
  18. Ralf Mayer wrote
    No need mate, no need, you are doing all the work yourself.
    and do you?
  19. In uk.rec.motorcycles, Ralf Mayer belched forth and ejected the
    following:
    That actually sounds very like the symptoms he had on the ferry.
    Hey, Nick, it could be a HG after all.
  20. BGN
    Yes, but it's looking like in a week or two.
    sweller, May 29, 2006
